Share
REF SS05108M300
Suunto SM-36 Tank Pressure Gauge 4000
Highly accurate tank pressure gauge
RELIABLE AND ACCURATE TANK PRESSURE GAUGE
The extremely compact Suunto SM-36 tank pressure gauge incorporates a safety-pin-type tube and a gear mechanism, which provide outstanding accuracy and durability. The clear and bright phosphorescent dial face provides excellent readability, even in demanding conditions.
The SM-36 pressure gauge is suitable for 300 bar/4000 psi tanks and is available with either bar or psi display (360 bar or 5000 psi max display). The SM-36 pressure gauge can be fitted with the Suunto Combos or it can be attached directly to an HP hose.
PRODUCT HIGHLIGHTS
  • Outstanding quality, reliability, and accuracy
  • Easy-to-read display
  • For tanks with pressure up to 300 bar/4000 psi
  • Made in Finland
  • Outstanding build quality, reliability and accuracy
  • With Miflex Carbon HD high pressure hose
  • Easy-to-read display even in demanding conditions
  • Suitable for tanks with pressure up to 4000 psi
  • With protective rubber sleeve
  • Made in Finland
What's in the box?
Suunto SM-36/4000
Weight 68 g
Weight 2,4 oz
No manuals found for this product.
HOW TO VIDEOS
Check out our videos.
DEALER AND SERVICE LOCATOR
Open the dealer locator
WRITE TO US
SIGN IN
REGISTER
What is MySuunto?
SUBMIT A QUESTION
CALL US
Warranty Period
For all Suunto Spartan watches purchased in 2016 the Warranty Period has been extended to three (3) years.
Exclusions and Limitations
Limitation of Liability
Suunto warrants that during the Warranty Period, as defined below, Suunto or Suunto Authorized Service Center will, at its sole discretion, remedy defects in materials or workmanship free of charge either by a) repairing, or b) replacing with similar product, or c) refunding, subject to the terms and conditions of this International Limited Warranty. This International Limited Warranty does not cover a) wear and tear, b) rough handling, c) modifications, d) exposure to chemicals, or e) misuse. Unless otherwise provided in applicable mandatory legislation, a) this International Limited Warranty is valid and enforceable regardless of the country of purchase, and b) to access the International Limited Warranty service, registration to www.suunto.com/mysuunto and proof of purchase is required. This International Limited Warranty does not affect your legal rights, granted under applicable mandatory legislation on the sale of consumer goods.
Warranty Period
International Limited Lifetime Warranty:
The International Warranty Period is limited until such reasonable time as the product is no longer reasonably usable due to wear and tear.
International Limited 2-year Warranty:
Applicable to Suunto AIM, Arrow, Orca-Pioneer and KB compasses.
The International Limited Warranty period is two (2) years from the date of original retail purchase.
TO THE MAXIMUM EXTENT PERMITTED BY APPLICABLE MANDATORY LAWS, THIS INTERNATIONAL LIMITED WARRANTY IS YOUR SOLE AND EXCLUSIVE REMEDY AND IS IN LIEU OF ALL OTHER WARRANTIES, EXPRESSED OR IMPLIED. SUUNTO SHALL NOT BE LIABLE FOR SPECIAL, INCIDENTAL, PUNITIVE OR CONSEQUENTIAL DAMAGES. SUUNTO SHALL NOT BE LIABLE FOR DELAY IN RENDERING WARRANTY SERVICE.
IMPORTANT:
Australia
Austria
Belgium
Bulgaria
Croatia
Cyprus
Czech Republic
Denmark
Estonia
Finland
France
Germany
Greece
Hungary
Ireland
Italy
Latvia
Lithuania
Luxemburg
Malaysia
Malta
Netherlands
New Zealand
Norway
Poland
Portugal
Romania
Singapore
Slovakia
Slovenia
Spain
Sweden
Switzerland
United Kingdom
United States
