Share
REF SS014587000 / This product is no longer in production
Suunto Cobra3
Advanced air-integrated dive computer with electronic 3D compass
Suunto Cobra3 is an all-in-one console-mounted dive computer. It features air-integration, an electronic 3D compass, an easy-to-read matrix display, and simplified four-button operation.
Air integration
Suunto Cobra3 monitors and displays your tank pressure, tracks your rate of air consumption, and continuously calculates your remaining air time. It also provides visual and audible alarms for depth and pressure and warns you when you're running low on air.
Clear navigation
Suunto Cobra3 features a unique electronic 3D compass that can be tilted up to 45 degrees in any direction, making it easier to read the figures clearly and accurately under water.
Effortless operation
The easy-to-read dot matrix display and electro-luminescent backlight mean all your dive-critical information – including bearing, tank pressure, depth, and dive time – will all be shown clearly. And with the simplified four-button operation, the computer is easy to operate even when wearing gloves.
Multi-mode versatility
With its Nitrox, Air, and Gauge modes and gas-switching capabilities, Suunto Cobra3 delivers everything you need to maximize bottom time and make the most of every dive. When using enriched air, Suunto Cobra3 can be programmed for nitrox mixtures between 21% and 100% oxygen. You can also adjust oxygen partial pressure between 0.5 and 1.6 bar. In Gauge mode, it can also be used as a depth gauge and timer with profile memory.
Flexible decompression
Using the Suunto Deep Stop RGBM algorithm, Suunto Cobra3 enables continuous decompression for optimal ascent time. For deeper dives, the Deep Stop option adds further protection with a series of deep stops between your maximum depth and ceiling.
When in Nitrox mode, you can accelerate decompression by switching to a gas mix with a higher oxygen percentage. With Suunto Cobra3 it's quick and easy to switch between enabled gas mixes while diving.
Plan and review
You can test upcoming dives and view no-decompression and decompression time data for different depths before getting in the water with the built-in dive simulator. When the dive is over, get detailed graphical logs and dive data on your computer using Suunto DM4 software.
PRODUCT HIGHLIGHTS
  • Air, nitrox, and gauge modes
  • 3D compass
  • Suunto RGBM
  • Easy-to-read matrix display
  • Air integrated for tank pressure information
  • Tiltable electronic 3D compass to keep you on course
  • User-friendly design featuring easy-to-read matrix display and simplified four-button operation
  • Three dive modes and gas-switching capability for a range of dive situations
  • Continuous decompression with the Suunto RGBM algorithm
  • Built-in dive simulator for planning upcoming dives
  • Optional computer interface for detailed graphical logbooks and dive data analysis
Measurements 73  x  165  x  35  mm
Weight 210 g
Measurements 2,87  x  6,5 x  1,38 "
Weight 7,41 oz
Bezel material: Composite
Glass material: Acrylic
Case material: Composite
Strap material: Elastomer
Declination correction yes
Suunto Cobra3 – Technical specifications
Weight 210 g
Water resistance 100 m (ISO 13319)
Battery life in time mode 3 years
Battery life 100 dives/year 1.5 years
Battery type CR 2450
User replaceable battery
Time, date
Alarm clock 1 daily alarm
Languages EN
Backlight electro-luminescent
Configurable backlight duration: 5, 10, 20, 30, 60 s
Display type matrix
Display resolution 49 x 22
Metric and imperial units
Data transfer USB cable (optional)
Compatible with DM5
Compatible with Suunto Movescount with DM5
Digital compass
Tilt compensation up to 45°
Direction scale degrees
Needle compass rose
Globally balanced
Compass accuracy 10°
Compass resolution
Operating temperature 0° C to +40° C / +32° F to +104° F
Storage temperature -20 ° C to +50 ° C / -4° F to +122° F
DIVING FUNCTIONS
Maximum operating depth (EN 13319) 100 m
Nitrox (and air)
Gauge
Dive time 0 to 999 min
Surface time 0 to 99 h 59 min
No fly time
Safety Stop
Deep Stop
Ascent time display 0 - 99 min (- - after 99)
CNS/OTU (OLF) calculation
Hose air integration
Decompression model SUUNTO RGBM
Personal adjustment 0 - 2
Altitude adjustment 0 - 300 m / 300 -1500 m / 1500 - 3000 m
Gases up to 2 gases (Oxygen 21 - 99%)
Gas max pO2 1.2 - 1.6
Gas switching
No-decompression planner
Logbook memory ~42 h (20 s sampling rate)
Logbook bookmarks
Logbook sampling rates 1, 10, 20, 30, 60 s
Dive History lifetime
Dive time
Maximum depth
Tank pressure
High pO2 (hyperoxic)
Too fast ascent
Decompression ceiling violation
CNS/OTU (OLF) 80% / 100%
Switch gas (better gas is available)
OUTDOOR FUNCTIONS
Temperature display range -20° C to +50° C (+/- 2° C) / -9° C to +122° F (+/- 3.6° F)
Temperature resolution 1° C / 1.5° F
Temperature
USER GUIDES
Use Adobe Reader for viewing.
HOW TO VIDEOS
Check out our videos.
DEALER AND SERVICE LOCATOR
Open the dealer locator
Dive computer and device battery change
Suunto recommends dive computer and device batteries be changed by an authorized service center. You can find your nearest service center using the Suunto dealer locator – simply select service center and the product category. You can also get your Suunto product repaired with our online service request. The available countries are listed in the online service request page.
The benefits of using an authorized Suunto service center include:
  • In addition to the battery, O-rings, gaskets and other mechanical parts that are worn or damaged are also replaced.
  • Replacement batteries are new (full capacity) and parts conform to Suunto specifications, ensuring the battery lasts as specified and product integrity remains in tact.
  • The dive computer won’t be damaged by sudden ESD (electrostatic discharge), since the battery change is performed in an ESD safe environment.
  • After servicing, products are tested to ensure they function properly and are water resistant.
  • Servicing is performed by Suunto trained personnel, with proper tools and original Suunto spare parts ensuring the best care for your computer.
  • Suunto products repaired by an authorized service provider are covered by a three (3) month service warranty from the date of repair.
Suunto DM5 for planning and tracking your dives – for PC and MAC
Suunto DM5 allows you to download your dive logs for advanced analysis and upload detailed dive plans to your dive computer. The program is free to download. Suunto DM5 is available in English, Dutch, French, Finnish, German, Japanese, Korean, Spanish and Chinese. The minimum OS requirements are: Mac 10.7 or Windows XP. Read more about DM5.
The benefits of using Suunto DM5 include:
  • With the Suunto DM5 graphical dive planner, you can easily create dive profiles, manage gases as well as backup plans. When you are done, transfer planned gases and other dive-critical information to your dive computer (selected models only). You can also print gas mixing instructions from DM5.
  • After the dive you can transfer your dive logs to DM5. Your dives are stored in the logbook where you can review, analyze and organize them by date, mode and gear. The tagging function makes it easy to mark your dives and organize them according to your personal preferences. In addition you can select several dives to compare them with each other.
  • You can also save your dives in Suunto Movescount and share them with your friends.
Download Suunto DM5 for free here:
FOR WINDOWS
FOR MAC
WRITE TO US
SIGN IN
REGISTER
What is MySuunto?
SUBMIT A QUESTION
CALL US
Warranty Period
Exclusions and Limitations
Limitation of Liability
SUUNTO LIMITED WARRANTY
Warranty Period
Limited Lifetime Warranty:
Limited 2-year Warranty:
IMPORTANT:
Australia
Austria
Belgium
Bulgaria
Croatia
Cyprus
Czech Republic
Denmark
Estonia
Finland
France
Germany
Greece
Hungary
Ireland
Italy
Latvia
Lithuania
Luxemburg
Malaysia
Malta
Netherlands
New Zealand
Norway
Poland
Portugal
Romania
Singapore
Slovakia
Slovenia
Spain
Sweden
Switzerland
United Kingdom
United States
