Share
REF SS010600210 / This product is no longer in production
Suunto Vector Khaki
Legendary outdoor sports watch with a solid track record of high-altitude performance
Availability: In stock
Express delivery: 600
Satisfied or your money back
THE ORIGINAL MOUNTAIN WATCH
After a decade of travels, adventures and courageous expeditions, the Suunto Vector is still the most legendary watch with altimeter, barometer and compass. With technology and durability that can take on the harshest of environments, the Suunto Vector is the choice of professionals.
PRODUCT HIGHLIGHTS
  • Altimeter, barometer, compass
  • Robust and light
  • Trusted by professionals
  • Weather trend indicator
  • Temperature
  • Altitude difference measurement
  • Altitude log
  • Vertical speed
  • Multiple watch
  • Date and time functions
  • User-replaceable battery
What's in the box?
Suunto Vector Khaki, Quick guide
Measurements 51,4  x  45,6  x  15,3  mm
Weight 54 g
Measurements 2,02  x  1,8 x  0,6 "
Weight 1,9 oz
Bezel material: Composite
Glass material: Acrylic
Case material: Composite
Strap material: Elastomer
Declination correction yes
Suunto Vector Khaki – Technical specifications
Weight 54 g
Water resistance 30 m (according to ISO 6425)
Battery life in time mode 12 months
Battery type CR2430
User replaceable battery
Time, date
Alarm clock coming to Spartan
This feature is coming later for Suunto Spartan watches, follow the updates on www.suunto.com/spartangetsstronger.
up to 3 daily alarms
Countdown timer
Stopwatch timer
Languages EN
Backlight electro-luminescent
Display type 7 segments
Metric and imperial units
Digital compass
Tilt compensation bubble level
Direction scale degrees
Needle north-south indicator
Compass accuracy
Compass resolution
OUTDOOR FUNCTIONS
Barometric altitude
Altitude difference
Log recording rate 20 s / 1, 10, 60 min
Resolution 5 m
Range -500 - 9000 m
Sea level pressure
Temperature
Temperature display range -20° C to +60° C / -4° F to +140° F
Pressure resolution 1hPa/0.05 inHg
Temperature resolution
Max weather recording length 4 days
TRAINING INSIGHT
USER GUIDES
Use Adobe Reader for viewing.
HOW TO VIDEOS
Check out our videos.
DEALER AND SERVICE LOCATOR
Open the dealer locator
WRITE TO US
SIGN IN
REGISTER
What is MySuunto?
SUBMIT A QUESTION
CALL US
Warranty Period
Exclusions and Limitations
Limitation of Liability
SUUNTO LIMITED WARRANTY
Warranty Period
Limited Lifetime Warranty:
Limited 2-year Warranty:
IMPORTANT:
Australia
Austria
Belgium
Bulgaria
Croatia
Cyprus
Czech Republic
Denmark
Estonia
Finland
France
Germany
Greece
Hungary
Ireland
Italy
Latvia
Lithuania
Luxemburg
Malaysia
Malta
Netherlands
New Zealand
Norway
Poland
Portugal
Romania
Singapore
Slovakia
Slovenia
Spain
Sweden
Switzerland
United Kingdom
United States
