Share
REF SS018402000 / This product is no longer in production
Suunto D6i Elastomer
Serious features and air integration in a rugged steel casing
SERIOUS DIVE FEATURES IN A RUGGED STEEL CASING
Suunto D6i is the watch-sized dive computer of choice for those who take their diving seriously. With a new tilt-compensated 3D digital compass and wireless air integration, it’s a great tool when other people rely on your diving skills. Trusted by professional divers, its good looks make it a great addition to your more civilian wardrobe too. D6i White, D6i Elastomer and D6i All Black now come with a comfortable silicone strap.
PRODUCT HIGHLIGHTS
  • 5 modes including freediving
  • Gas-switching between up to 3 gases
  • 3D compass, optional wireless air integration
  • Suunto RGBM
Suunto D-Series software update
Suunto D-Series software update, January 2016
The software update brings usability and performance improvements to the Suunto DX, Suunto D6i, Suunto D6i Novo, Suunto D4i and Suunto D4i Novo. Read more about this software update.
  • Steel case and sapphire crystal glass with antireflective coating
  • Full continuous decompression algorithm - Suunto RGBM
  • Gas-switching between up to three gases
  • Five modes: air, nitrox, gauge, free and off
  • Innovative apnea timer, and a timer in air/nitrox modes
  • Integrated tilt-compensated 3D digital compass
  • Updateable firmware
  • Optional wireless air integration – current cylinder pressure, remaining air time
  • Built-in dive planner
  • Detailed graphical logs and dive data on your PC/Mac using Suunto DM5 software
What's in the box?
Suunto D6i with black elastomer strap, D-series USB cable and black extension strap, dive manuals on DVD, Quick Guide and dive legal leaflet with warranty information
Measurements 48,5  x  45,6  x  15,9  mm
Weight 113 g
Measurements 1,91  x  1,8 x  0,63 "
Weight 3,99 oz
Bezel material: Stainless steel
Glass material: Sapphire crystal
Case material: Steel
Strap material: Elastomer
Suunto D6i Elastomer – Technical specifications
Weight 113 g
Water resistance 150 m (ISO 6425, EN 13319)
Battery life in time mode 2 years
Battery life 100 dives/year 1.5 years
Battery type CR 2450
Time, date
Alarm clock coming to Spartan
This feature is coming later for Suunto Spartan watches, follow the updates on www.suunto.com/spartangetsstronger.
1 daily alarm
Dual time
Stopwatch timer
Languages EN
Backlight electro-luminescent
Configurable backlight duration: off, 5, 10, 20, 30, 60 s
Display type matrix
Display resolution 49 x 22
Metric and imperial units
Data transfer USB cable
Connectivity (between devices) inductive
Compatible with DM5
Compatible with Suunto Movescount with DM5
Digital compass
Tilt compensation up to 45°
Direction scale degrees
Needle compass rose
Compass accuracy
Compass resolution
Operating temperature 0° C to +40° C / +32° F to +104° F
Storage temperature -20 ° C to +50 ° C / -4° F to +122° F
DIVING FUNCTIONS
Maximum operating depth (EN 13319) 100 m
Nitrox (and air)
Freedive
Gauge
Dive time 0 to 999 min
Surface time 0 to 99 h 59 min
No fly time
Safety Stop
Deep Stop
Ascent time display 0 - 199 min (- - after 199)
CNS/OTU (OLF) calculation
Wireless air integration optional
Decompression model SUUNTO RGBM
Personal adjustment 0 - 2
Altitude adjustment 0 - 300 m / 300 -1500 m / 1500 - 3000 m
Gases up to 3 gases (Oxygen 21 - 99%)
Gas max pO2 1.2 - 1.6
Gas switching
Timer
No-decompression planner
Logbook memory ~140 h (20 s sampling rate)
Logbook bookmarks
Logbook sampling rates 10, 20, 30, 60 s (1, 2, 5 s freediving)
Dive History lifetime
Dive time
Maximum depth
Tank pressure
High pO2 (hyperoxic)
Too fast ascent
Decompression ceiling violation
Deepstop violation
CNS/OTU (OLF) 80% / 100%
Switch gas (better gas is available)
Apnea timer (O2/CO2 tables)
Freedive number
Freedive day history
Freedive total history lifetime
Depth notify yes (5)
Surface time notify
OUTDOOR FUNCTIONS
Temperature display range -20° C to +50° C (+/- 2° C) / -9° C to +122° F (+/- 3.6° F)
Temperature resolution 1° C / 1.5° F
Temperature
TRAINING INSIGHT
USER GUIDES
Use Adobe Reader for viewing.
HOW TO VIDEOS
Check out our videos.
DEALER AND SERVICE LOCATOR
Open the dealer locator
Dive computer and device battery change
Suunto recommends dive computer and device batteries be changed by an authorized service center. You can find your nearest service center using the Suunto dealer locator – simply select service center and the product category. You can also get your Suunto product repaired with our online service request. The available countries are listed in the online service request page.
The benefits of using an authorized Suunto service center include:
  • In addition to the battery, O-rings, gaskets and other mechanical parts that are worn or damaged are also replaced.
  • Replacement batteries are new (full capacity) and parts conform to Suunto specifications, ensuring the battery lasts as specified and product integrity remains in tact.
  • The dive computer won’t be damaged by sudden ESD (electrostatic discharge), since the battery change is performed in an ESD safe environment.
  • After servicing, products are tested to ensure they function properly and are water resistant.
  • Servicing is performed by Suunto trained personnel, with proper tools and original Suunto spare parts ensuring the best care for your computer.
  • Suunto products repaired by an authorized service provider are covered by a three (3) month service warranty from the date of repair.
Suunto DM5 for planning and tracking your dives – for PC and MAC
Suunto DM5 allows you to download your dive logs for advanced analysis and upload detailed dive plans to your dive computer. The program is free to download. Suunto DM5 is available in English, Dutch, French, Finnish, German, Japanese, Korean, Spanish and Chinese. The minimum OS requirements are: Mac 10.7 or Windows XP. Read more about DM5.
The benefits of using Suunto DM5 include:
  • With the Suunto DM5 graphical dive planner, you can easily create dive profiles, manage gases as well as backup plans. When you are done, transfer planned gases and other dive-critical information to your dive computer (selected models only). You can also print gas mixing instructions from DM5.
  • After the dive you can transfer your dive logs to DM5. Your dives are stored in the logbook where you can review, analyze and organize them by date, mode and gear. The tagging function makes it easy to mark your dives and organize them according to your personal preferences. In addition you can select several dives to compare them with each other.
  • You can also save your dives in Suunto Movescount and share them with your friends.
Download Suunto DM5 for free here:
FOR WINDOWS
FOR MAC
WRITE TO US
SIGN IN
REGISTER
What is MySuunto?
SUBMIT A QUESTION
CALL US
Warranty Period
Exclusions and Limitations
Limitation of Liability
SUUNTO LIMITED WARRANTY
Warranty Period
Limited Lifetime Warranty:
Limited 2-year Warranty:
IMPORTANT:
Australia
Austria
Belgium
Bulgaria
Croatia
Cyprus
Czech Republic
Denmark
Estonia
Finland
France
Germany
Greece
Hungary
Ireland
Italy
Latvia
Lithuania
Luxemburg
Malaysia
Malta
Netherlands
New Zealand
Norway
Poland
Portugal
Romania
Singapore
Slovakia
Slovenia
Spain
Sweden
Switzerland
United Kingdom
United States
