How can I fix connection problems with my Spartan and Suunto Movescount App (Android)?
If you were able to connect your watch and app, but the connection is failing now, the following steps may resolve the problems:
Make sure Bluetooth is activated on your mobile phone:
To prolong battery life, some mobile devices deactivate Bluetooth after a period of inactivity. Go to your device settings and make sure Bluetooth is activated.
Reset the connection between your watch and the app:
1. Open Settings on your watch and select Connectivity.
2. Go to Paired devices and select Mobile App, then select Forget.
3. In your mobile device settings, go to Bluetooth and remove your watch from the list by tapping the cog symbol to the right side of the watch name > select Unpair.
unpairunpair2
4. Restart your mobile device (recommended).
After this, pair your watch again as if you were connecting for the first time. Syncing and other actions should work as normal once pairing is completed.
Do not re-install the Suunto Movescount App:
If you re-install the app, all Moves pending to be transferred to Suunto Movescount will be lost, even if they are still in the watch. Re-installing the app does not resolve connectivity issues.
Help us improve the connectivity of Spartan watches with Suunto Movescount App:
To further develop our app, we would like to collect information about connection errors. For this purpose, we kindly ask you to send us diagnostic logs from your mobile phone after a connectivity problem has occurred. To send logs, open your Profile in the app, tap on Send Logs, and confirm by tapping with Send Logs.
send logssend logs2
FIND MORE SUPPORT FOR:
Suunto Spartan Trainer Wrist HR
Suunto Spartan Ultra
Suunto Spartan Sport Wrist HR
Suunto Spartan Sport Wrist HR Baro
