Share
REF SS019540000
Suunto Vyper
Rugged and versatile nitrox-capable dive computer
USB cable included in the package
THE ICONIC DIVE COMPUTER
Suunto Vyper is a rugged and versatile multi-mode dive computer that’s designed for a wide range of dive conditions.
PRODUCT HIGHLIGHTS
  • Air, nitrox, and gauge modes
  • Backlight
  • Suunto RGBM
  • Robust and durable
  • Air, Nitrox, and Gauge modes for a range of dive situations
  • Easy operation, whether wrist or console mounted
  • Continuous decompression with the Suunto RGBM algorithm
  • Built-in dive simulator and dive planner
  • Detailed graphical logs and dive data on your computer using Suunto DM5 software
What's in the box?
Suunto Vyper Silver, display shield, USB cable, dive manuals on DVD, Quick Guide and dive legal leaflet with warranty information
Measurements 63,2  x  60,6  x  28,7  mm
Weight 68 g
Measurements 2,49  x  2,39 x  1,13 "
Weight 2,4 oz
Bezel material: Composite
Glass material: Acrylic
Case material: Composite
Strap material: Elastomer
Suunto Vyper – Technical specifications
Weight 68 g
Water resistance 80 m (ISO 6425, EN 13319)
Battery life in time mode 3 years
Battery life 100 dives/year 2 years
Battery type CR 2450
User replaceable battery
Time, date
Alarm clock 1 daily alarm
Languages EN
Backlight electro-luminescent
Configurable backlight duration: 5 - 30 s
Display type 7 segments
Metric and imperial units
Data transfer USB cable
Compatible with DM5
Compatible with Suunto Movescount with DM5
Operating temperature 0° C to +40° C / +32° F to +104° F
Storage temperature -20 ° C to +50 ° C / -4° F to +122° F
DIVING FUNCTIONS
Maximum operating depth (EN 13319) 80m
Nitrox (and air)
Gauge
Dive time 0 to 999 min
Surface time 0 to 99 h 59 min
No fly time
Safety Stop
Ascent time display 0 - 99 min (- - after 99)
CNS/OTU (OLF) calculation
Decompression model SUUNTO RGBM
Personal adjustment 0 - 2
Altitude adjustment 0 - 300 m / 300 -1500 m / 1500 - 3000 m
Gases 1 gas (Oxygen 21 - 50%)
Gas max pO2 1.2 - 1.6
No-decompression planner
Logbook memory ~36 h (20 s sampling rate)
Logbook sampling rates 10, 20, 30, 60 s
Dive History lifetime
Dive time
Maximum depth
High pO2 (hyperoxic)
Too fast ascent
Decompression ceiling violation
CNS/OTU (OLF) 80% / 100%
OUTDOOR FUNCTIONS
Temperature display range -9° C to +50° C (+/- 2° C) / 16° F to +122° F (+/- 3.6° F)
Temperature resolution 1° C / 1.5° F
Temperature
TRAINING INSIGHT
USER GUIDES
Use Adobe Reader for viewing.
HOW TO VIDEOS
Check out our videos.
DEALER AND SERVICE LOCATOR
Open the dealer locator
Dive computer and device battery change
Suunto recommends dive computer and device batteries be changed by an authorized service center. You can find your nearest service center using the Suunto dealer locator – simply select service center and the product category. You can also get your Suunto product repaired with our online service request. The available countries are listed in the online service request page.
The benefits of using an authorized Suunto service center include:
  • In addition to the battery, O-rings, gaskets and other mechanical parts that are worn or damaged are also replaced.
  • Replacement batteries are new (full capacity) and parts conform to Suunto specifications, ensuring the battery lasts as specified and product integrity remains in tact.
  • The dive computer won’t be damaged by sudden ESD (electrostatic discharge), since the battery change is performed in an ESD safe environment.
  • After servicing, products are tested to ensure they function properly and are water resistant.
  • Servicing is performed by Suunto trained personnel, with proper tools and original Suunto spare parts ensuring the best care for your computer.
  • Suunto products repaired by an authorized service provider are covered by a three (3) month service warranty from the date of repair.
Suunto DM5 for planning and tracking your dives – for PC and MAC
Suunto DM5 allows you to download your dive logs for advanced analysis and upload detailed dive plans to your dive computer. The program is free to download. Suunto DM5 is available in English, Dutch, French, Finnish, German, Japanese, Korean, Spanish and Chinese. The minimum OS requirements are: Mac 10.7 or Windows XP. Read more about DM5.
The benefits of using Suunto DM5 include:
  • With the Suunto DM5 graphical dive planner, you can easily create dive profiles, manage gases as well as backup plans. When you are done, transfer planned gases and other dive-critical information to your dive computer (selected models only). You can also print gas mixing instructions from DM5.
  • After the dive you can transfer your dive logs to DM5. Your dives are stored in the logbook where you can review, analyze and organize them by date, mode and gear. The tagging function makes it easy to mark your dives and organize them according to your personal preferences. In addition you can select several dives to compare them with each other.
  • You can also save your dives in Suunto Movescount and share them with your friends.
Download Suunto DM5 for free here:
FOR WINDOWS
FOR MAC
WRITE TO US
SIGN IN
REGISTER
What is MySuunto?
SUBMIT A QUESTION
CALL US
Warranty Period
Exclusions and Limitations
Limitation of Liability
SUUNTO LIMITED WARRANTY
Warranty Period
Limited Lifetime Warranty:
Limited 2-year Warranty:
IMPORTANT:
Australia
Austria
Belgium
Bulgaria
Croatia
Cyprus
Czech Republic
Denmark
Estonia
Finland
France
Germany
Greece
Hungary
Ireland
Italy
Latvia
Lithuania
Luxemburg
Malaysia
Malta
Netherlands
New Zealand
Norway
Poland
Portugal
Romania
Singapore
Slovakia
Slovenia
Spain
Sweden
Switzerland
United Kingdom
United States
