Share
REF SS016421000 / Dieses Produkt wird nicht mehr hergestellt
Suunto Core Extreme Edition Everest
A limited edition of the award winning Suunto Core family
Preise und Verfügbarkeit werden geladen
Thrilling Moves with Apa Sherpa
In honor of the legendary mountaineer and Suunto Ambassador Apa Sherpa, Suunto launches a limited edition outdoor sports instrument, the Suunto Core Extreme Edition Everest. Celebrating Apa Sherpa’s world-record 20th summit of Mount Everest, the Core Extreme Edition Everest reflects the determination and strength of one of the world’s greatest living mountaineers.
Suunto will donate a portion of all proceeds of this product to the Apa Sherpa Foundation to help support the education of the children living in the remote village near the base camp of Mount Everest.
As a limited edition, Suunto is producing only 8,848 pieces of the Extreme Edition Everest to match the elevation of Mount Everest’s peak at 8,848 meters.
Add your own moves at www.movescount.com and join the Thrilling Moves competition!
Altimeter
The altimeter features a range up to 9000m (29 500 ft). It is ideally suited for all activities where knowing your altitude and ascent and descent rates is essential. The Core altimeter sports an altitude difference measurement that allows you to track your progress in terms of altitude climbed. The log recorder stores all your movements in altitude between the start and stop times, so you can re-live your trip at home - view graphs of changes in altitude during your treks, find out how much you climbed, the duration of ascents and descents, average ascent and descent speed and more.
Barometer
Suunto Core displays the current sea level pressure as a detailed graph, showing recording of the last 24 hours with a recording interval of 30 minutes. The weather trend indicator is a useful feature providing quick reference to check upcoming weather conditions. The storm alarm notifies you of a sudden drop in air pressure, which may be related to worsening weather conditions.
Automatic Alti/Baro switch
Suunto Core sports an Automatic Alti/Baro switch, a smart feature that senses your movement or lack thereof, switching between altimeter and barometer accordingly. When you’re climbing, it records changes in elevation. And when you stop to rest, it records changes in barometric pressure. A drop in air pressure while you’re sleeping under the stars will be recorded for what it really is: a change in barometric pressure, not altitude.
Compass
The digital compass displays the cardinal or half-cardinal point and the North. The declination adjustment function allows you to correct the difference between the true North and magnetic North. You can also set it to track a certain bearing, which helps you follow a chosen direction in the terrain. The compass features a one-touch function that allows you to sight lock and follow a bearing.
Depth meter
Intended for snorkeling, the Suunto Core depth meter provides information on current depth and the maximum depth reached during your snorkeling dive. The maximum depth of the device is 10m (32,8 ft).
Watch
Watch functions include time, dual time, date, alarm, sports chronograph, countdown timer and predicted times for sunrise and sunset for over 400 locations worldwide.
PRODUKTHIGHLIGHTS
  • Höhenmesser, Barometer, Kompass
  • Wetterfunktionen
  • Für alle Höhenlagen geeignet
  • A numbered, limited edition of 8848 pieces inspired by Mount Everest’s height of 8848 meters
  • Altimeter with altitude log memory and altitude difference measurement
  • Barometer with storm alarm and weather trend indicator
  • Automatic Alti / Baro switch
  • Compass with semi automatic calibration and a digital bearing
  • Depth meter
  • Multiple watch, date and alarm functions with dual time and countdown timer
  • Sunrise/Sunset times for over 400 locations worldwide
  • Digital thermometer
  • Menu based user interface in English, German, French and Spanish
  • User-replaceable battery
Abmessungen 49,1  x  49,1  x  14,5  mm
Gewicht 65 g
Abmessungen 1,93  x  1,93 x  0,57 "
Gewicht 2,29 oz
Lünettenmaterial: Aluminium
Glasmaterial: Mineralkristall
Gehäusematerial: Verbundwerkstoff
Armbandmaterial: Silikon
Suunto Core Extreme Edition Everest – Technische Daten
Gewicht 65 g / 2,29 oz
Wasserfestigkeit 30 m (nach ISO 6425)
Batterienutzungsdauer im Modus "Zeit" 12 Monate
Batterietyp CR 2032
Durch Benutzer auswechselbare Batterie
Zeit, Datum
Wecker 1 täglicher Alarm
Dualzeit
Countdown-Timer
Stoppuhr
Sprachen EN, DE, ES, FR
Hintergrundbeleuchtung elektrolumineszierend
Konfigurierbare Hintergrundbeleuchtung Aktivierung: 1 Taste, alle Tasten
Tastensperre
Displaytyp Matrix
Batterieanzeige Anzeige des Batterieladestands
Metrische und angelsächsische Maßangaben
Digitaler Kompass
Richtungsskala Grad
Nadel Nord-Anzeige
Kurshaltefunktion mit Richtungsweiser
Genauigkeit
Skaleneinteilung
Betriebstemperatur -20° C bis +60° C / -5° F bis +140° F
Aufbewahrungstemperatur -30° C bis +60° C / -22° F bis +140° F
TAUCHFUNKTIONEN
Tiefenmesser zum Schnorcheln 10 m
OUTDOOR-FUNKTIONEN
Barometrische Höhenmessung
Höhengrafik
Gesamtaufstieg/-abstieg luftdruckbasiert
Automatisches Höhenmesser-/ Barometerprofil
Höhendifferenz
Aufzeichnungsrate des Protokolls 1, 5, 10, 30, 60 s
Anzeigegenauigkeit 1 m
Anzeigebereich -500 - 9000 m
Luftdruck auf Meereshöhe
Luftdruckdiagramm auf Meereshöhe
Wettertrendanzeige
Temperatur
Temperaturanzeigebereich -20° C bis +60° C / -4° F bis +140° F
Sonnenaufgangs-/-untergangszeiten
Unwetterwarnung
Genauigkeit der Druckanzeige 1 hPa / 0,03 inHg
Genauigkeit der Temperaturanzeige
Max. Länge der Wetteraufzeichnung 7 Tage
BEDIENUNGSANLEITUNGEN
In den Bedienungsanleitungen sind alle Funktionalitäten Ihres Produktes übersichtlich beschrieben. Zudem erfahren Sie, wie Ihr Produkt eingesetzt wird und werden über die Handhabung und technischen Spezifikationen informiert.
Mit Adobe Reader ansehen.
Als PDF herunterladen
ANLEITUNGSVIDEOS
Finden Sie neue Funktionen heraus, holen Sie sich hilfreiche Tipps, sehen Sie sich die Schritt-für-Schritt-Anleitungen an und entdecken Sie, wie Andere Suunto Produkte verwenden.
Sehen Sie sich unsere Videos an.
HÄNDLER- UND SERVICESUCHE
Finden Sie ein autorisiertes Servicezentrum oder einen Suunto Händler in Ihrer Nähe.
Händlersuche öffnen
SCHREIBEN SIE UNS
Sie erhalten Support in Chinesisch, Deutsch, Englisch, Finnisch, Französisch, Italienisch, Japanisch, Russisch, Schwedisch und Spanisch.
1. Nehmen Sie über MySuunto Kontakt mit uns auf.
ANMELDEN
REGISTRIEREN
Was ist MySuunto?
2. Oder geben Sie nachstehend eine Nachricht ein (keine Registrierung erforderlich).
EINE FRAGE EINREICHEN
Wir bemühen uns nach besten Kräften, Ihnen innerhalb der nächsten Tage zu antworten. Bitte rufen Sie uns an, wenn Sie dringend Hilfe benötigen sollten.
RUFEN SIE UNS AN
Support in Englisch – rund um die Uhr:
Support an Werktagen von 9 Uhr bis 17 Uhr Ortszeit:
Sollte Ihr Land nicht aufgeführt sein, werden Anrufe nach dem internationalen Tarif Ihres Netzbetreibers abgerechnet. Ihr Anruf kann zur Qualitätskontrolle und zu Schulungszwecken überwacht oder aufgezeichnet werden.
SUUNTO EINGESCHRÄNKTE INTERNATIONALE GARANTIE
Suunto garantiert, dass während der Garantieperiode Suunto oder ein autorisiertes Suunto Servicezentrum (im folgenden Servicezentrum) nach eigenem Ermessen Material- oder Verarbeitungsfehler kostenfrei durch a) Reparatur, b) Ersatz oder c) Rückerstattung unter den Bedingungen dieser eingeschränkten internationalen Garantie behebt. Diese eingeschränkte internationale Garantie ist gültig und durchsetzbar, unabhängig vom Kaufland. Diese eingeschränkte internationale Garantie schränkt Ihre Rechtsansprüche nicht ein, die Ihnen gemäß einer verpflichtenden nationalen Rechtsprechung im Zusammenhang mit dem Verkauf von Verbrauchsgütern zustehen.
Garantiezeitraum
Der Zeitraum für die eingeschränkte internationale Garantie beginnt mit dem ursprünglichen Kaufdatum im Einzelhandel.
Sofern nicht anderweitig angegeben, beläuft sich der Garantiezeitraum für Produkte und Tauchsender auf 2 (zwei) Jahre.
Der Garantiezeitraum für Zubehör, einschließlich, aber ohne Einschränkung darauf, drahtloser Sensoren, Ladegeräte, Kabel, wiederaufladbarer Batterien, Schlaufen, Armbänder und Schläuche, beläuft sich auf 1 (ein) Jahr.
Für alle 2016 gekauften Suunto Spartan Uhren wurde der Garantiezeitraum auf 3 (drei) Jahre verlängert.
Ausschlüsse und Einschränkungen
Diese eingeschränkte internationale Garantie gilt nicht für:
  1. a) normale Abnutzung wie Kratzer, Abrieb, oder Farb- bzw. Materialveränderungen bei Bändern, die nicht aus Metall sind; b) Defekte, die durch groben Umgang entstanden sind; oder c) Defekte oder Beschädigung infolge von Handhabung entgegen dem vorgesehenen oder empfohlenen Verwendungszweck, aufgrund unsachgemäßer Pflege, Fahrlässigkeit und von Unfällen, wie Herunterfallen oder Quetschen;
  2. bedruckte Materialien und Verpackungen;
  3. Schäden oder angebliche Schäden, die durch Verwendung des Produkts mit Produkten, Zubehör, Software und/oder Serviceleistungen entstanden sind, die nicht von Suunto hergestellt oder bereitgestellt wurden;
  4. nicht-wiederaufladbare Batterien.
Suunto garantiert nicht, dass das Produkt oder Zubehör unterbrechungs- oder fehlerfrei funktioniert, oder, dass das Produkt oder Zubehör bei Verwendung von Soft- oder Hardware anderer Anbieter funktioniert.
Diese eingeschränkte internationale Garantie hat keine Geltung, wenn das Produkt oder Zubehör:
  1. außer dem vorgesehenen Gebrauch geöffnet wurde;
  2. mit nicht zugelassenen Ersatzteilen repariert, bzw. eine Wartung oder Reparatur in einem nicht autorisierten Servicezentrum durchgeführt wurde;
  3. die Seriennummer, wie von Suunto nach eigenem Ermessen festgestellt, auf beliebige Weise entfernt, verändert oder unleserlich gemacht wurde; oder
  4. Chemikalien ausgesetzt wurde, einschließlich, aber ohne Einschränkung darauf, u.a. Sonnenschutz- und Mückenschutzmitteln.
Inanspruchnahme von Suunto Garantieleistungen
Für die Beantragung einer Suunto Garantieleistung müssen Sie den Kaufbeleg vorlegen. Damit Sie Leistungen gemäß der internationalen Garantie weltweit erhalten können, müssen Sie Ihr Produkt auch online unter www.suunto.com/mysuunto registrieren. Die Anleitung für die Geltendmachung von Garantieleistungen finden Sie unter www.suunto.com/warranty, , alternativ können Sie Ihren autorisierten Suunto Händler kontaktieren oder das Suunto Contact Center anrufen.
Haftungsbegrenzung
In dem gemäß den geltenden zwingenden Rechtsvorschriften maximal zulässigen Umfang ist diese eingeschränkte internationale Garantie Ihr einziges und ausschließliches Rechtsmittel. Sie ersetzt alle sonstigen ausdrücklichen oder implizierten Garantien. Suunto übernimmt keinerlei Haftung für besondere und zusätzliche Schadensansprüche, Neben- oder Folgeschäden bzw. Bußzahlungen, einschließlich, aber ohne Einschränkung darauf, Verlust von erwartetem Gewinn, Datenverlust, Nutzungsausfall, Kapitalaufwendungen, Kosten für Ersatzausrüstungen oder -einrichtungen, Ansprüche Dritter, Sachschäden, die sich aus dem Kauf oder Gebrauch des Produkts oder aus einer Garantieverletzung, einem Vertragsbruch, Fahrlässigkeit, Produktfehlern oder rechtlichen und gesetzlichen Umständen ergeben. Dies gilt auch für den Fall, dass Suunto die Wahrscheinlichkeit dieser Schäden bekannt war. Suunto haftet nicht für Verzögerungen bei der Erbringung von Garantieleistungen.
Suunto garantiert, dass Suunto oder ein von Suunto autorisiertes Servicezentrum, wie unten definiert, Material- oder Verarbeitungsfehler, die während des Garantiezeitraums aufgetreten sind, gemäß den Bedingungen dieser eingeschränkten internationalen Garantie nach eigenem Ermessen kostenlos durch a) Reparatur, b) Ersatz durch ein ähnliches Produkt, oder c) Rückerstattung des Kaufpreises behebt. Diese eingeschränkte internationale Garantie gilt nicht für a) Abnutzung, b) unsachgemäße Behandlung, c) Veränderungen, d) Exposition gegenüber Chemikalien oder e) falschen Gebrauch. Sofern die geltenden zwingenden Rechtsvorschriften nichts anderweitiges bestimmen, a) ist diese eingeschränkte internationale Garantie unabhängig vom Erwerbsland gültig und durchsetzbar, und b) muss für die Gewährung von Garantieansprüchen aus der eingeschränkten internationalen Garantie das Produkt in www.suunto.com/mysuunto registriert sein und ein Kaufbeleg vorgelegt werden. Diese eingeschränkte internationale Garantie beeinflusst Ihre Rechtsansprüche nicht, die Ihnen gemäß geltenden zwingenden Rechtsvorschriften in Bezug auf den Kauf von Verbrauchsgütern zustehen.
Garantiezeitraum
eingeschränkte internationale lebenslange Garantie:
Gültig für Suunto A, M, MC, MB und Clipper Kompasse.
Der internationale Garantiezeitraum erstreckt sich über einen angemessenen Zeitraum und endet, wenn das Produkt aufgrund von Abnutzung nicht mehr sinnvoll einsetzbar ist.
Eingeschränkte internationale Garantie für 2 Jahre:
Gültig für Suunto AIM, Arrow, Orca-Pioneer und KB Kompasse.
Die eingeschränkte internationale Garantie wird für einen Zeitraum von 2 (zwei) Jahren ab Datum des Erstkaufs im Einzelhandel gewährt.
Haftungsbeschränkung
DIESE GARANTIE STELLT IM GESETZLICH ZULÄSSIGEN RAHMEN IHR EINZIGES UND AUSSCHLIESSLICHES RECHTSMITTEL DAR UND ERSETZT ALLE ANDEREN AUSDRÜCKLICHEN ODER STILLSCHWEIGENDEN GARANTIEN. SUUNTO HAFTET NICHT FÜR KONKRETE SCHÄDEN, ERSATZ BEILÄUFIG ENTSTANDENER SCHÄDEN, STRAFZUSCHLÄGE ZUM SCHADENERSATZ ODER FOLGESCHÄDEN. SUUNTO HAFTET NICHT FÜR VERZÖGERUNGEN BEI DER ERBRINGUNG VON GARANTIELEISTUNGEN.
Lassen Sie Ihr Suunto Produkt über eine Online-Serviceanfrage reparieren. Klicken Sie auf die nachstehende Registerkarte "Online-Serviceanfrage", um zu sehen, welcher Service in ihrem Land zur Verfügung steht.
Wenn Ihr Land nicht aufgeführt ist, oder Sie einen Kompass oder ein Präzisionsgerät haben, finden Sie das nächstgelegene Servicezentrum über die Suunto Händlersuche – Wählen Sie einfach das Servicezentrum und die entsprechende Produktkategorie aus.
Unsere Online-Serviceanfrage steht für die nachstehend aufgeführten Länder zur Verfügung. Wenn Ihr Land nicht aufgeführt ist, oder Sie einen Kompass oder ein Präzisionsgerät haben, finden Sie das nächstgelegene Servicezentrum über die Suunto Händlersuche – Wählen Sie einfach das Servicezentrum und die entsprechende Produktkategorie aus.
WICHTIG:
Für die Durchführung von Reparaturen können Sie ca. sieben Geschäftstage veranschlagen. Wenn die Reparatur nicht mehr unter die Garantie fällt, senden wir Ihnen vor Beginn der Reparatur einen Kostenvoranschlag zu. Wenn Sie unseren Kostenvoranschlag ablehnen, senden wir Ihnen das Produkt zurück und berechnen Ihnen für die Analyse und den Versand eine Pauschalsumme, die von Land zu Land variiert.
Anleitung zum Ausfüllen einer Online-Serviceanfrage:
  • 1. Sie benötigen eine gültige E-Mail-Adresse, die Seriennummer Ihres Produkts und einen Drucker.
  • 2. Wählen Sie Ihr Land in der Liste aus.
  • 3. Geben Sie die erforderlichen Daten ein. Die Versanddokumente werden automatisch zum Ausdrucken erstellt. Legen Sie diese dem Produkt bei, das Sie uns zusenden.
  • 4. Nachdem Sie die Bestätigung erhalten haben, rufen Sie den Kurier unter der angegebenen Nummer an und Ihr Produkt wird abgeholt.
  • 5. Legen Sie Ihrem Produkt keine Handbücher, Anleitungen oder Verkaufsverpackungen bei, da wir sie Ihnen nicht zurücksenden können.
  • 6. Wenn das Problem nicht unter die Garantie fällt, senden wir Ihnen die Zahlungsdetails per E-Mail zu. Zahlungen erfolgen sicher über PayPal.
  • 7. Sobald das Produkt repariert wurde, senden wir es an die von Ihnen in der Serviceanfrage angegebene Adresse zurück.
Australien
Österreich
Belgien
Bulgarien
Kroatien
Zypern
Tschechien
Dänemark
Estland
Finnland
Frankreich
Deutschland
Griechenland
Ungarn
Irland
Italien
Lettland
Litauen
Luxemburg
Malaysia
Malta
Niederlande
Neuseeland
Norwegen
Polen
Portugal
Rumänien
Singapur
Slowakei
Slowenien
Spanien
Schweden
Schweiz
Großbritannien
USA
Suunto verfügt über ein weit verzweigtes Netzwerk aus autorisierten Servicezentren in verschiedenen Ländern, die Ihnen bei Ihren Reparatur- und Wartungsangelegenheiten weiterhelfen können. Sie finden das nächstgelegene Servicezentrum mithilfe der Suunto Händlersuche: Wählen Sie einfach ein Servicezentrum und die Produktkategorie aus.
Sie können sich auch an den Suunto Kundendienst wenden, um Informationen zu den Unterstützungsmöglichkeiten bei Fragen zu Ihrem Produkt zu erhalten.
