Share
REF SS020393000
Suunto D4i Novo Blue
An easy-to-use dive computer with freedive mode and air integration
THE GREAT ALL-ROUNDER
The redesigned Suunto D4i comes in a range of fresh colors and with an all-new soft, comfortable silicone strap for that perfect fit. Lightweight and packed with handy features like freedive mode and optional wireless air integration, it’s got everything you need – wherever your diving may take you.
 PRODUCT HIGHLIGHTS
  • 4 modes incl. freediving
  • Light weight
  • Optional wireless air integration
  • Suunto RGBM
Suunto D-Series software update
Suunto D-Series software update, January 2016
The software update brings usability and performance improvements to the Suunto DX, Suunto D6i, Suunto D6i Novo, Suunto D4i and Suunto D4i Novo. Read more about this software update.
  • Full continuous decompression algorithm - Suunto RGBM
  • Four modes: air, nitrox, free and off
  • Innovative apnea timer, and a timer in air/nitrox modes
  • Updateable firmware
  • Optional wireless air integration – current cylinder pressure, remaining air time
  • Built-in dive planner
  • Detailed graphical logs and dive data on your PC/Mac using Suunto DM5 software
What's in the box?
Suunto D4i Novo Blue with blue silicone strap and a blue extension strap, D-series USB Cable, Scratch guards (2 pcs), safety leaflet, quick guide, dive legal leaflet with warranty information, Suunto logo sticker
Measurements 48.6  x  43.8  x  16  mm
Weight 92 g
Measurements 1.91  x  1.72 x  0.63 "
Weight 3.25 oz
Bezel material: Stainless steel
Lens material: Mineral crystal
Case material: Composite
Strap material: Silicone
Suunto D4i Novo Blue – Technical specifications
Weight 92 g
Water resistance 100 m (ISO 6425, EN 13319)
Battery life in time mode 2 years
Battery life 100 dives/year 1.5 years
Battery type CR 2450
Time, date
Alarm clock 1 daily alarm
Dual time
Stopwatch timer
UI languages EN
Backlight electro-luminescent
Configurable backlight duration: off, 5, 10, 20, 30, 60 s
Display type matrix
Display resolution 49 x 22
Metric and imperial units
Data transfer USB cable
Connectivity (between devices) inductive
Compatible with DM5
Compatible with Suunto Movescount with DM5
Operating temperature 0° C to +40° C / +32° F to +104° F
Storage temperature -20 ° C to +50 ° C / -4° F to +122° F
DIVING FUNCTIONS
Maximum operating depth (EN 13319) 100 m
Nitrox (and air)
Freedive
Gauge
Dive time 0 to 999 min
Surface time 0 to 99 h 59 min
No fly time
Safety Stop
Deep Stop
Ascent time display 0 - 199 min (- - after 199)
CNS/OTU (OLF) calculation
Wireless air integration optional
Decompression model SUUNTO RGBM
Personal adjustment 0 - 2
Altitude adjustment 0 - 300 m / 300 -1500 m / 1500 - 3000 m
Gases 1 gas (Oxygen 21 - 50%)
Gas max pO2 1.2 - 1.6
Timer
No-decompression planner
Logbook memory ~140 h (20 s sampling rate)
Logbook bookmarks
Logbook sampling rates 10, 20, 30, 60 s (1, 2, 5 s freediving)
Dive History lifetime
Dive time
Maximum depth
Tank pressure
High pO2 (hyperoxic)
Too fast ascent
Decompression ceiling violation
Deepstop violation
CNS/OTU (OLF) 80% / 100%
Apnea timer (O2/CO2 tables)
Freedive number
Freedive day history
Freedive total history lifetime
Depth notify yes (5)
Surface time notify
OUTDOOR FUNCTIONS
Temperature display range -20° C to +50° C (+/- 2° C) / -9° C to +122° F (+/- 3.6° F)
Temperature resolution 1° C / 1.5° F
Temperature
TRAINING/SPORTS FUNCTIONS
MANUALS
Find out everything you need to know, from set up to troubleshooting. Download the manual now.
Use Adobe Reader for viewing.
HOW TO VIDEOS
Explore new features, get useful tips, see step-by-step instructions and find out how others are using Suunto devices.
Check out our videos.
DEALER LOCATOR
Open the dealer locator
Dive computer and device battery change
Suunto recommends dive computer and device batteries be changed by an authorized service center. You can find your nearest service center using the Suunto dealer locator – simply select service center and the product category. You can also get your Suunto product repaired with our online service request. The available countries are listed in the online service request page.
The benefits of using an authorized Suunto service center include:
  • In addition to the battery, O-rings, gaskets and other mechanical parts that are worn or damaged are also replaced.
  • Replacement batteries are new (full capacity) and parts conform to Suunto specifications, ensuring the battery lasts as specified and product integrity remains in tact.
  • The dive computer won’t be damaged by sudden ESD (electrostatic discharge), since the battery change is performed in an ESD safe environment.
  • After servicing, products are tested to ensure they function properly and are water resistant.
  • Servicing is performed by Suunto trained personnel, with proper tools and original Suunto spare parts ensuring the best care for your computer.
  • Suunto products repaired by an authorized service provider are covered by a three (3) month service warranty from the date of repair.
Suunto DM5 for planning and tracking your dives – for PC and MAC
Suunto DM5 allows you to download your dive logs for advanced analysis and upload detailed dive plans to your dive computer. The program is free to download. Suunto DM5 is available in English, Dutch, French, Finnish, German, Japanese, Korean, Spanish and Chinese. The minimum OS requirements are: Mac 10.7 or Windows XP. Read more about DM5.
The benefits of using Suunto DM5 include:
  • With the Suunto DM5 graphical dive planner, you can easily create dive profiles, manage gases as well as backup plans. When you are done, transfer planned gases and other dive-critical information to your dive computer (selected models only). You can also print gas mixing instructions from DM5.
  • After the dive you can transfer your dive logs to DM5. Your dives are stored in the logbook where you can review, analyze and organize them by date, mode and gear. The tagging function makes it easy to mark your dives and organize them according to your personal preferences. In addition you can select several dives to compare them with each other.
  • You can also save your dives in Suunto Movescount and share them with your friends.
Download Suunto DM5 for free here:
FOR WINDOWS
FOR MAC
WRITE TO US
SIGN IN
REGISTER
What is MySuunto?
SUBMIT A QUESTION
CALL US
SUUNTO LIMITED WARRANTY
Suunto warrants that during the Warranty Period Suunto or a Suunto Authorized Service Center (hereinafter Service Center) will, at its sole discretion, remedy defects in materials or workmanship free of charge either by a) repairing, or b) replacing, or c) refunding, subject to the terms and conditions of this Limited Warranty. This Limited Warranty is only valid and enforceable in the country of purchase, unless local law stipulates otherwise.
Warranty Period
The Limited Warranty Period starts at the date of original retail purchase.
The Warranty Period is two (2) years for Products unless otherwise specified.
The Warranty Period is one (1) year for accessories including but not limited to wireless sensors and transmitters, chargers, cables, rechargeable batteries, straps, bracelets and hoses.
Exclusions and Limitations
This Limited Warranty does not cover:
This Limited Warranty is not enforceable if the Product or accessory:
You must provide proof of purchase to access Suunto warranty service. For instructions how to obtain warranty service, visit www.suunto.com/warranty, contact your local authorized Suunto retailer, or call Suunto Contact Center.
Limitation of Liability
To the maximum extent permitted by applicable mandatory laws, this Limited Warranty is your sole and exclusive remedy and is in lieu of all other warranties, expressed or implied. Suunto shall not be liable for special, incidental, punitive or consequential damages, including but not limited to loss of anticipated benefits, loss of data, loss of use, cost of capital, cost of any substitute equipment or facilities, claims of third parties, damage to property resulting from the purchase or use of the item or arising from breach of the warranty, breach of contract, negligence, strict tort, or any legal or equitable theory, even if Suunto knew of the likelihood of such damages. Suunto shall not be liable for delay in rendering warranty service.
Warranty Period
Limited Lifetime Warranty:
Limited 2-year Warranty:
IMPORTANT:
Australia
Austria
Belgium
Bulgaria
Cyprus
Czech Republic
Denmark
Estonia
Finland
France
Germany
Greece
Hungary
Ireland
Italy
Latvia
Lithuania
Luxemburg
Malta
Netherlands
New Zealand
Norway
Poland
Portugal
Romania
Slovakia
Slovenia
Spain
Sweden
Switzerland
United Kingdom
United States
