Share
REF SS020305000
Suunto EON Steel
The fully customizable dive computer with a bright color screen, extremely durable construction and mobile connectivity
Explore more – Full customization
A new era in Suunto dive computers has begun. With insight from over 80 years, Suunto introduces its next generation dive computer. The intuitive Suunto EON Steel combines advanced technology with a bright color screen, customizable features and display to show clearly what you need. With heavy-duty housing, a stainless steel bezel, mobile connectivity and user updatable software, Suunto EON Steel will dive with you for years to come.
Suunto focuses on dive computers so you can focus on your dive.
HIGHLIGHTS
  • Customize with features and Suunto CustomDisplay™
  • Wide-angle Suunto BrightSee™ color screen
  • User-updatable software and mobile connectivity
  • Extreme durability
Suunto EON Steel - made for divers by divers
The Suunto EON Steel was developed in close relationship with active divers. Watch the video and share the excitement.
Suunto EON Steel software update
Suunto EON Steel software update, March 2017
The software update 1.4 for Suunto EON Steel brings new features such as mobile connectivity between EON Steel and Suunto Movescount App and localization. Learn more about this software update.
EASE OF USE
  • Customize to match your evolving needs
  • Visually intuitive, consistent presentation
  • Simple, easy interaction with menus and buttons
  • Bright, high contrast display for easy reading in any dive conditions
  • Use with strap or bungee (included)
  • Flip display
EXTREME DURABILITY
  • Brushed stainless steel bezel
  • Highly durable and resistant Xensation™ glass
  • Robust mechanical construction
  • Extensively tested and built to last
  • Guaranteed to 150 m depth
  • Rechargeable battery: 20-40 hours of dive time with one charge (one week at liveaboard)
FOR ALL DIVING
  • Gauge/Air/Nitrox/Trimix/CCR (fixed point)
  • Suunto Fused™ RGBM for maximizing dive time
  • No-decompression dive planner
  • Monitor multiple tank pressures with the new Suunto Tank POD
  • Easy planning and customization with Suunto DM5
  • Upgrade with new features
What's in the box?
Suunto EON Steel, USB Cable, Quick Guide, Legal leaflet, Protective boot, Display scratch guard sticker, Bungee adapter and cord
Measurements 104.6  x  60.5  x  23.1  mm
Weight 347 g
Measurements 4.12  x  2.38 x  0.91 "
Weight 12.24 oz
Bezel material: Stainless steel
Glass material: Xensation Glass
Case material: Composite
Strap material: Elastomer
Suunto EON Steel – Technical specifications
Weight 347 g / 12.24 oz
Water resistance 150 m (ISO 6425, EN 13319)
Battery life in time mode 30 days
Battery type rechargeable lithium-ion
Firmware upgradable
Time, date
Stopwatch timer
Languages
EN, DE, ES, FI, FR, IT, KO, NL, NO, PL, PT, RU, SV, ZH
Backlight LED
Display type color TFT
Display resolution 320 x 240
Battery indicator icon + dive hours remaining
Metric and imperial units
Flip display
Data transfer USB cable
Connectivity (between devices) inductive
Compatible with Suunto Movescount with DM5
Compatible with DM5
Digital compass
Tilt compensation up to 45°
Direction scale degrees
Needle compass rose
Globally balanced
Compass accuracy +/- 15°
Compass resolution
Declination correction
Bearing lock with direction indicator
Operating temperature 0° C to +40° C / +32° F to +104° F
Storage temperature -20 ° C to +50 ° C / -4° F to +122° F
Recommended charging temperature 0° C to +45° C / +32° F to +113° F
DIVING FUNCTIONS
Maximum operating depth (EN 13319) 150 m
Trimix (mixed gas)
Nitrox (and air)
Gauge
Dive time 0 to 999 min
Surface time 0 to 100 h
No fly time
Safety Stop
Deep Stop
Ascent time display 0 - 999 min ( > after 999)
CNS/OTU (OLF) calculation
Decompression model SUUNTO FUSED RGBM
Custom displays 4 per dive mode
Visual style Classic/Graphical
Altitude adjustment 0 - 300 m / 300 -1500 m / 1500 - 3000 m
Gases up to 10 gases (Oxygen 5 - 99% / Helium 0 -95%)
Gas max pO2 manual 0.5 - 1.6 / fixed 1.6
Gas switching
Timer
Logbook memory 200 h
Logbook bookmarks
Logbook sampling rates 10 s
Dive History lifetime
Personal adjustment from -2 to 2
Wireless air integration optional (up to 10 different tanks with Suunto Tank POD)
Rebreather (CCR), fixed point
Gas time
Gas consumption (real-time)
No-decompression planner
Dive time
Maximum depth
Tank pressure
High pO2 (hyperoxic)
Low pO2 (hypoxic)
Too fast ascent
Decompression ceiling violation
Deepstop violation
Switch gas (better gas is available)
CNS/OTU (OLF) 80% / 100%
Gas time
Diluent switched automatically
Diluent high pO2
Diluent low pO2
ICD warning
Diluents up to 10 diluents (Oxygen 5 - 99% / Helium 0 - 95%)
Bailout
High/low setpoints
Custom setpoint
Manual/automatic setpoint switching
OUTDOOR FUNCTIONS
Temperature display range -20° C to +50° C (+/- 2° C) / -9° C to +122° F (+/- 3.6° F)
Temperature resolution 1° C / 1.5° F
Temperature
TRAINING FUNCTIONS
USER GUIDES
Use Adobe Reader for viewing.
Download PDF
HOW TO VIDEOS
Check out our videos.
DEALER AND SERVICE LOCATOR
Open the dealer locator
Suunto DM5 for planning and tracking your dives – for PC and MAC
Suunto DM5 allows you to download your dive logs for advanced analysis and upload detailed dive plans to your dive computer. The program is free to download. Suunto DM5 is available in English, Dutch, French, Finnish, German, Japanese, Korean, Spanish and Chinese. The minimum OS requirements are: Mac 10.7 or Windows XP. Read more about DM5.
The benefits of using Suunto DM5 include:
  • With the Suunto DM5 graphical dive planner, you can easily create dive profiles, manage gases as well as backup plans. When you are done, transfer planned gases and other dive-critical information to your dive computer (selected models only). You can also print gas mixing instructions from DM5.
  • After the dive you can transfer your dive logs to DM5. Your dives are stored in the logbook where you can review, analyze and organize them by date, mode and gear. The tagging function makes it easy to mark your dives and organize them according to your personal preferences. In addition you can select several dives to compare them with each other.
  • You can also save your dives in Suunto Movescount and share them with your friends.
Download Suunto DM5 for free here:
FOR WINDOWS
FOR MAC
WRITE TO US
SIGN IN
REGISTER
What is MySuunto?
SUBMIT A QUESTION
CALL US
SUUNTO INTERNATIONAL LIMITED WARRANTY - Suunto Sports Watches, Dive Computers and Precision instruments
Warranty Period
For all Suunto Spartan watches purchased in 2016 the Warranty Period has been extended to three (3) years.
Exclusions and Limitations
Limitation of Liability
SUUNTO INTERNATIONAL LIMITED WARRANTY - Suunto Field Compasses
Suunto warrants that during the Warranty Period, as defined below, Suunto or Suunto Authorized Service Center will, at its sole discretion, remedy defects in materials or workmanship free of charge either by a) repairing, or b) replacing with similar product, or c) refunding, subject to the terms and conditions of this International Limited Warranty. This International Limited Warranty does not cover a) wear and tear, b) rough handling, c) modifications, d) exposure to chemicals, or e) misuse. Unless otherwise provided in applicable mandatory legislation, a) this International Limited Warranty is valid and enforceable regardless of the country of purchase, and b) to access the International Limited Warranty service, registration to www.suunto.com/mysuunto and proof of purchase is required. This International Limited Warranty does not affect your legal rights, granted under applicable mandatory legislation on the sale of consumer goods.
Warranty Period
International Limited Lifetime Warranty:
The International Warranty Period is limited until such reasonable time as the product is no longer reasonably usable due to wear and tear.
International Limited 2-year Warranty:
Applicable to Suunto AIM, Arrow, Orca-Pioneer and KB compasses.
The International Limited Warranty period is two (2) years from the date of original retail purchase.
TO THE MAXIMUM EXTENT PERMITTED BY APPLICABLE MANDATORY LAWS, THIS INTERNATIONAL LIMITED WARRANTY IS YOUR SOLE AND EXCLUSIVE REMEDY AND IS IN LIEU OF ALL OTHER WARRANTIES, EXPRESSED OR IMPLIED. SUUNTO SHALL NOT BE LIABLE FOR SPECIAL, INCIDENTAL, PUNITIVE OR CONSEQUENTIAL DAMAGES. SUUNTO SHALL NOT BE LIABLE FOR DELAY IN RENDERING WARRANTY SERVICE.
Warranty Period
IMPORTANT:
Australia
Austria
Belgium
Bulgaria
Croatia
Cyprus
Czech Republic
Denmark
Estonia
Finland
France
Germany
Greece
Hungary
Ireland
Italy
Latvia
Lithuania
Luxemburg
Malaysia
Malta
Netherlands
New Zealand
Norway
Poland
Portugal
Romania
Singapore
Slovakia
Slovenia
Spain
Sweden
Switzerland
United Kingdom
United States
