Share
REF SS020654000 / This product is no longer in production
Suunto Ambit2 R Black
Integrated GPS watch with optimized features for running and optional heart rate monitoring
THE GPS FOR RUNNERS
Suunto Ambit2 R is optimized for your perfect running experience. Built-in GPS and accelerometer provide accurate pace, speed, cadence and distance, while full route navigation offers you the freedom to explore. Heart rate monitoring, training plans and running apps make it easy to improve and keep track of every aspect of your performance. Discover a new dimension of running!
PRODUCT HIGHLIGHTS
KEY TRAINING FUNCTIONS
  • Speed, pace and distance
  • Heart rate limits and graph in real time
  • Running cadence from the wrist
  • Training plans
  • ANT+ Foot POD support
ANT+™ logoThis product is ANT+™ certified.
Visit
www.thisisant.com/directory for a list of compatible products.
KEY OUTDOOR FUNCTIONS
  • Route navigation
  • Track back
  • GPS altitude
  • 3D compass
  • Suunto Apps
  • Customizable sport modes
  • Languages: DE, ES, IT, FI, SWE, IT, PT, NL
  • Water resistant to 50 m /164 f
What's in the box?
Suunto Ambit2 R Black, Ambit power cable, and Quick guide
Measurements 50  x  50  x  15.5  mm
Weight 70 g
Measurements 1.97  x  1.97 x  0.61 "
Weight 2.47 oz
Bezel material: Plastic
Glass material: Mineral crystal
Case material: Polyamide
Strap material: Elastomer
Declination correction adjustable
Suunto Ambit2 R Black – Technical specifications
Weight 70 g
Water resistance 50 m (according to ISO 6425)
Battery life in time mode 14 days
Battery type rechargeable lithium-ion
Firmware upgradable
Time, date
Alarm clock coming to Spartan
This feature is coming later for Suunto Spartan watches, follow the updates on www.suunto.com/spartangetsstronger.
1 daily alarm
Dual time
GPS timekeeping
Countdown timer
Stopwatch timer
Languages EN, DE, ES, FI, FR, IT, NL, PT, SV
Backlight LED
Configurable backlight brightness / mode
Button lock customizable
Invert display
Display type matrix
Display resolution 128 x 128
Battery indicator percentage / icon
Metric and imperial units
Autoscrolling of exercise displays
Memory left indicator
Data transfer USB cable
Connectivity (between devices) Suunto ANT, ANT+
Compatible with Suunto Movescount
Compatible with Suunto Apps
Max. nr. of apps per sport mode 5
Logging of app specific metrics
Most recommended apps by activity
Create own metrics with advanced formulas
Chrono, GPS, HR, weather and altitude data yes, excluding weather
Running, cycling, swimming data yes, excluding cycling power/swimming
Rich math functions, if/then-logic, sound, backlight, etc.
Digital compass
Tilt compensation full
Direction scale degrees / mils
Needle north indicator
Compass accuracy
Compass resolution
Recommended charging temperature 0° C to +35° C / +32° F to +95° F
OUTDOOR FUNCTIONS
Satellite systems GPS
GPS recording rate 1, 5, 60 s
Battery life (GPS active) 8, 12, 25 h
Coordinate systems WGS84 Hd.d°
WGS84 Hd°m' s.s''
WGS84 Hd°m.m
UTM
MGRS
British (BNG)
Finnish (ETRS-TM35FIN)
Finnish (KKJ)
Irish (IG)
Swedish (RT90)
Swiss (CH1903)
UTM NAD27 - Alaska
UTM NAD27 - Conus
UTM NAD83
New Zealand (NZTM2000)
Waypoint and visual route navigation
Max. nr. of Points of Interest (POIs) 100
Find back
Track back
Track logging, viewing and sharing
Route planning
Route points per route / POIs in watch 1000 / 100
GPS track analysis
GPS altitude
Altitude graph
Total ascent/descent GPS based
Vertical speed GPS based
Altitude difference yes** i
** available as Suunto Apps
Log recording rate 1, 10 s
Resolution 1 m
Range -500 - 9000 m
TRAINING INSIGHT
Distance based autolaps
Chrono
Laps > 1000
Autopause
GPS speed and distance Integrated
Foot POD support Suunto Foot POD / ANT+
RR interval
Heart rate in beats per minute
Heart rate in % of max hr
Real-time average and max heart rate
Heart rate limits
Heart rate zones * i
* available In Movescount.com
EPOC & V02 max values * i
Heart rate graph in real time
Calories
Peak Training Effect
Recovery time
Real time EPOC yes** i
Speed and heart rate-based guidance during exercise
Interval timers
Downloadable training plans
Fitness test yes** i
Log summary on the watch with lap details
Training analysis
Training logbook with story and image support
SPORT EXPERTISE
Customizable sport modes and displays coming to Spartan
10 modes / 8 displays per mode
Running pace
Suunto FusedSpeed™
Average pace in real time
Running cadence watch or Foot POD
Foot POD calibration manual or GPS
Average stride length yes** i
Ghost Runner yes** i
Marathon End-time Estimator yes** i
Lap comparisons by kilometer/mile * i
Cycling speed based on GPS
Average speed in real time based on GPS
Hill incline in real time yes, available as Suunto Apps
Openwater swim pace and distance
USER GUIDES
Use Adobe Reader for viewing.
HOW TO VIDEOS
Check out our videos.
DEALER AND SERVICE LOCATOR
Open the dealer locator
WRITE TO US
SIGN IN
REGISTER
What is MySuunto?
SUBMIT A QUESTION
CALL US
Warranty Period
Exclusions and Limitations
Limitation of Liability
SUUNTO LIMITED WARRANTY
Warranty Period
Limited Lifetime Warranty:
Limited 2-year Warranty:
IMPORTANT:
Australia
Austria
Belgium
Bulgaria
Croatia
Cyprus
Czech Republic
Denmark
Estonia
Finland
France
Germany
Greece
Hungary
Ireland
Italy
Latvia
Lithuania
Luxemburg
Malaysia
Malta
Netherlands
New Zealand
Norway
Poland
Portugal
Romania
Singapore
Slovakia
Slovenia
Spain
Sweden
Switzerland
United Kingdom
United States
