Find a dealer/service center
Suunto Spartan Sport Wrist HR Baro User Guide - 1.11
Display theme
Display theme
To increase the readability of your watch screen while exercising or navigating, you can change between light and dark themes.
With the light theme, the display background is light and the numbers dark.
With the dark theme, the contrast is reverse, with the background dark and the numbers light.
The theme is a global setting that you can change in your watch from any of your sport mode options or from the navigation settings.
To change display theme in sport mode options:
  1. Go to any sport mode and swipe up or press the lower button to open the sport mode options.
  2. Scroll down to Theme and press the middle button.
  3. Switch between Light and Dark by swiping up or down or by pressing the upper and lower buttons, and accept with the middle button.
  4. Scroll back up to exit the sport mode options, and start (or exit) the sport mode.
To change display theme in navigation settings:
  1. Swipe down or press the upper button to open the launcher.
  2. Scroll to Navigation and tap on the icon or press the middle button
  3. Scroll down to the theme setting as described above and change it as desired. Exit the navigation settings by keeping the middle button pressed.
  4. Exit the navigation settings by keeping the middle button pressed.
