REF SS05108M300
Suunto SM-36 Tank Pressure Gauge 4000
Highly accurate tank pressure gauge
RELIABLE AND ACCURATE TANK PRESSURE GAUGE
The extremely compact Suunto SM-36 tank pressure gauge incorporates a safety-pin-type tube and a gear mechanism, which provide outstanding accuracy and durability. The clear and bright phosphorescent dial face provides excellent readability, even in demanding conditions.
The SM-36 pressure gauge is suitable for 300 bar/4000 psi tanks and is available with either bar or psi display (360 bar or 5000 psi max display). The SM-36 pressure gauge can be fitted with the Suunto Combos or it can be attached directly to an HP hose.
PRODUCT HIGHLIGHTS
  • Outstanding quality, reliability, and accuracy
  • Easy-to-read display
  • For tanks with pressure up to 300 bar/4000 psi
  • Made in Finland
  • Outstanding build quality, reliability and accuracy
  • With Miflex Carbon HD high pressure hose
  • Easy-to-read display even in demanding conditions
  • Suitable for tanks with pressure up to 4000 psi
  • With protective rubber sleeve
  • Made in Finland
What's in the box?
Suunto SM-36/4000
Weight 68 g
Weight 2.4 oz
No manuals found for this product.
HOW TO VIDEOS
Explore new features, get useful tips, see step-by-step instructions and find out how others are using Suunto devices.
Check out our videos.
DEALER LOCATOR
Open the dealer locator
WRITE TO US
SIGN IN
REGISTER
What is MySuunto?
SUBMIT A QUESTION
NOTE: Support team is overloaded at the moment, thus the response time is currently several weeks. We are very sorry for this inconvenience. In case of urgent matters, please call.
CALL US
  • Australia +61 1800 240 498 (toll free)
  • New Zealand +64 988 75 223
  • United Kingdom +44 20 360 805 34
  • USA +1 855 258 0900 (toll free)
  • Austria +43 72 088 3104
  • Canada +1 800 267 7506 (toll free) - press 3 and then 1 for technical support (in English)
  • China +86-010-84 054 725
  • Finland +358 94 245 0127
  • France +33 48 168 0926
  • Germany +49 893 803 8778
  • Italy +39 029 475 1965
  • Japan +81 34 520 9417 from 10 am to 6 pm
  • Netherlands +31 10 713 7269 (in English)
  • Russia +7 499 918 7148
  • Spain +34 911 143 175
  • Sweden +46 85 250 0730
  • Switzerland +41 44 580 9988
Sports Watches, Dive Computers and Precision instruments
SUUNTO LIMITED WARRANTY
Suunto warrants that during the Warranty Period Suunto or a Suunto Authorized Service Center (hereinafter Service Center) will, at its sole discretion, remedy defects in materials or workmanship free of charge either by a) repairing, or b) replacing, or c) refunding, subject to the terms and conditions of this Limited Warranty. This Limited Warranty is only valid and enforceable in the country of purchase, unless local law stipulates otherwise.
Warranty Period
The Limited Warranty Period starts at the date of original retail purchase.
The Warranty Period is two (2) years for Products unless otherwise specified.
The Warranty Period is one (1) year for accessories including but not limited to wireless sensors and transmitters, chargers, cables, rechargeable batteries, straps, bracelets and hoses.
Exclusions and Limitations
This Limited Warranty does not cover:
This Limited Warranty is not enforceable if the Product or accessory:
You must provide proof of purchase to access Suunto warranty service. For instructions how to obtain warranty service, visit www.suunto.com/warranty, contact your local authorized Suunto retailer, or call Suunto Contact Center.
Limitation of Liability
To the maximum extent permitted by applicable mandatory laws, this Limited Warranty is your sole and exclusive remedy and is in lieu of all other warranties, expressed or implied. Suunto shall not be liable for special, incidental, punitive or consequential damages, including but not limited to loss of anticipated benefits, loss of data, loss of use, cost of capital, cost of any substitute equipment or facilities, claims of third parties, damage to property resulting from the purchase or use of the item or arising from breach of the warranty, breach of contract, negligence, strict tort, or any legal or equitable theory, even if Suunto knew of the likelihood of such damages. Suunto shall not be liable for delay in rendering warranty service.
Field Compasses
Warranty Period
Limited Lifetime Warranty:
Limited 2-year Warranty:
Get your Suunto product repaired with our online service request, available in the United States, Australia, New Zealand and in 29 European countries.
Online service request
IMPORTANT:
Repair is completed within approximately seven business days. If the product is not under warranty, we’ll send you a cost estimate before starting repair – if you choose not to have the product repaired, we’ll send it back to you but you’ll still be charged for the diagnosis and freight.
Australia
Austria
Belgium
Bulgaria
Cyprus
Czech Republic
Denmark
Estonia
Finland
France
Germany
Greece
Hungary
Ireland
Italy
Latvia
Lithuania
Luxemburg
Malta
Netherlands
New Zealand
Norway
Poland
Portugal
Romania
Slovakia
Slovenia
Spain
Sweden
Switzerland
United Kingdom
United States
Service centers
