Share
REF SS013315010 / This product is no longer in production
Suunto Core Black Yellow
The outdoor watch combining easy-to-use outdoor features (altimeter, barometer & compass) in a range of stylish design options.
Every great adventure starts from within. From a drive to seek out new places and discover new experiences. Your passion is our inspiration. Suunto Core is the essential outdoor watch with a pioneering spirit designed to bring out the explorer in you.
The award-winning Suunto Core gathers a range of data to help you navigate your way through the wilder parts of the world.
Altimeter
The altimeter features a range up to 9000 m (29 500 ft). It is ideally suited for all activities where knowing your altitude and ascent and descent rates is essential. The Core altimeter sports an altitude difference measurement that allows you to track your progress in terms of altitude climbed. The log recorder stores all your movements in altitude between the start and stop times, so you can re-live your trip at home - view graphs of changes in altitude during your treks, find out how much you climbed, the duration of ascents and descents, average ascent and descent speed and more.
Barometer
Suunto Core displays the current sea level pressure as a detailed graph, showing recording of the last 24 hours with a recording interval of 30 minutes. The weather trend indicator is a useful feature providing quick reference to check upcoming weather conditions. The storm alarm notifies you of a sudden drop in air pressure, which may be related to worsening weather conditions.
Automatic Alti/Baro switch
Suunto Core sports an Automatic Alti/Baro switch, a smart feature that senses your movement or lack thereof, switching between altimeter and barometer accordingly. When you’re climbing, it records changes in elevation. And when you stop to rest, it records changes in barometric pressure. A drop in air pressure while you’re sleeping under the stars will be recorded for what it really is: a change in barometric pressure, not altitude
Compass
The digital compass displays the cardinal or half-cardinal point and the North. The declination adjustment function allows you to correct the difference between the true North and magnetic North. You can also set it to track a certain bearing, which helps you follow a chosen direction in the terrain. The compass features a rotating bezel for traditional use (most variants), or a one-touch function that allows you to sight lock and follow a bearing.
Depth meter
Intended for snorkeling, the Suunto Core depth meter provides information on current depth and the maximum depth reached during your snorkeling dive. The maximum depth of the device is 10 m (32,8 ft).
Watch
Watch functions include time, dual time, date, alarm, sports chronograph, countdown timer and predicted times for sunrise and sunset for over 400 locations worldwide.
Suunto Core is available in a range of styles and materials.
PRODUCT HIGHLIGHTS
  • Altimeter, barometer, compass
  • Weather functions
  • Mountain & everywhere use
  • Altimeter with altitude log memory and altitude difference measurement
  • Barometer with storm alarm and weather trend indicator
  • Automatic Alti / Baro switch
  • Compass with semi automatic calibration and a digital bearing
  • Depth meter
  • Multiple watch, date and alarm functions with dual time and countdown timer
  • Sunrise/Sunset times for over 400 locations worldwide
  • Digital thermometer
  • Menu based user interface in English, German, French and Spanish
  • Available in a range of styles
  • Accessory straps
  • User-replaceable battery
Measurements 49.1  x  49.1  x  14.5  mm
Weight 63 g
Measurements 1.93  x  1.93 x  0.57 "
Weight 2.22 oz
Bezel material: Aluminum
Glass material: Mineral crystal
Case material: Composite
Strap material: Silicone
Suunto Core Black Yellow – Technical specifications
Weight 63 g / 2.22 oz
Water resistance 30 m (according to ISO 6425)
Battery life in time mode 12 months
Battery type CR2032
User replaceable battery
Time, date
Alarm clock 1 daily alarm
Dual time
Countdown timer
Stopwatch timer
Languages EN, DE, ES, FR
Backlight electro-luminescent
Configurable backlight activation: 1 button, all buttons
Button lock
Display type matrix
Metric and imperial units
Digital compass
Direction scale degrees
Needle north indicator
Compass accuracy
Compass resolution
DIVING FUNCTIONS
Depth meter for snorkeling 10 m
OUTDOOR FUNCTIONS
Barometric altitude
Altitude graph
Automatic alti/baro profile coming to Spartan
This feature is coming later for Suunto Spartan watches, follow the updates on www.suunto.com/spartangetsstronger.
Altitude difference
Log recording rate 1, 5, 10, 30, 60 s
Resolution 1 m
Range -500 - 9000 m
Sea level pressure
Sea level pressure graph
Weather trend indicator
Temperature
Temperature display range -20° C to +60° C / -4° F to +140° F
Sunrise/sunset times
Storm alarm
Pressure resolution 1 hPa / 0.03 inHg
Temperature resolution
Max weather recording length 7 days
USER GUIDES
Use Adobe Reader for viewing.
HOW TO VIDEOS
Check out our videos.
DEALER AND SERVICE LOCATOR
Open the dealer locator
WRITE TO US
SIGN IN
REGISTER
What is MySuunto?
SUBMIT A QUESTION
CALL US
Warranty Period
For all Suunto Spartan watches purchased in 2016 the Warranty Period has been extended to three (3) years.
Exclusions and Limitations
Limitation of Liability
Suunto warrants that during the Warranty Period, as defined below, Suunto or Suunto Authorized Service Center will, at its sole discretion, remedy defects in materials or workmanship free of charge either by a) repairing, or b) replacing with similar product, or c) refunding, subject to the terms and conditions of this International Limited Warranty. This International Limited Warranty does not cover a) wear and tear, b) rough handling, c) modifications, d) exposure to chemicals, or e) misuse. Unless otherwise provided in applicable mandatory legislation, a) this International Limited Warranty is valid and enforceable regardless of the country of purchase, and b) to access the International Limited Warranty service, registration to www.suunto.com/mysuunto and proof of purchase is required. This International Limited Warranty does not affect your legal rights, granted under applicable mandatory legislation on the sale of consumer goods.
Warranty Period
International Limited Lifetime Warranty:
The International Warranty Period is limited until such reasonable time as the product is no longer reasonably usable due to wear and tear.
International Limited 2-year Warranty:
Applicable to Suunto AIM, Arrow, Orca-Pioneer and KB compasses.
The International Limited Warranty period is two (2) years from the date of original retail purchase.
TO THE MAXIMUM EXTENT PERMITTED BY APPLICABLE MANDATORY LAWS, THIS INTERNATIONAL LIMITED WARRANTY IS YOUR SOLE AND EXCLUSIVE REMEDY AND IS IN LIEU OF ALL OTHER WARRANTIES, EXPRESSED OR IMPLIED. SUUNTO SHALL NOT BE LIABLE FOR SPECIAL, INCIDENTAL, PUNITIVE OR CONSEQUENTIAL DAMAGES. SUUNTO SHALL NOT BE LIABLE FOR DELAY IN RENDERING WARRANTY SERVICE.
IMPORTANT:
Australia
Austria
Belgium
Bulgaria
Croatia
Cyprus
Czech Republic
Denmark
Estonia
Finland
France
Germany
Greece
Hungary
Ireland
Italy
Latvia
Lithuania
Luxemburg
Malaysia
Malta
Netherlands
New Zealand
Norway
Poland
Portugal
Romania
Singapore
Slovakia
Slovenia
Spain
Sweden
Switzerland
United Kingdom
United States
