REF SS019172000
Suunto Elementum Terra Amber Rubber
Premium sports watch for urban and mountain life
THE PREMIUM OUTDOOR WATCH
Suunto Elementum Terra is a superbly crafted timepiece, exclusively manufactured in Finland. This urban inspired premium watch combines a heritage in craftsmanship with precision digital technology. While the Terra is perfect for urban use, it also measures altitude and weather trends and includes a unique 3D compass for adventures in the great outdoors. Designed with stainless steel casing and a sapphire crystal glass to withstand the elements.
PRODUCT HIGHLIGHTS
  • Finnish craftmanship
  • Stainless steel case with sapphire glass
  • Altimeter, barometer, compass
  • Altimeter
  • Barometric pressure & trend
  • 3D compass
  • Log: last 8 ascent / descent, max. altitude
What's in the box?
Suunto Elementum Terra Amber Rubber, Quick Guide, Cleaning cloth
Measurements 44.7  x  51.5  x  14.3  mm
Weight 97 g
Measurements 1.76  x  2.03 x  0.56 "
Weight 3.42 oz
Bezel Material: Steel
Lens material: Sapphire crystal
Case material: Stainless steel
Strap material: Silicone
Suunto Elementum Terra Amber Rubber – Technical specifications
Water resistance 100 m (according to ISO 6425)
Battery life in time mode 12 months
Battery type CR2032
Time, date
Alarm clock 1 daily alarm
Stopwatch timer
UI languages EN
Backlight electro-luminescent display
Button lock
Display type matrix
Metric and imperial units
COMPASS
Digital compass
Tilt compensation up to 45°
Direction scale degrees
Needle north indicator
Compass accuracy
Compass resolution
PHYSICAL SPECIFICATIONS
Operating temperature -10° C to +60° C / +14° F to +140° F
OUTDOOR FUNCTIONS
ALTIMETER
Barometric altitude
Automatic alti/baro profile
Log recording rate 1, 5, 10 s
Resolution 1 m
Range -500 - 9000 m
WEATHER
Sea level pressure
Weather trend indicator
Pressure resolution 1hPa/0.03 inHg
Temperature resolution
Max weather recording length last 6 hours
MANUALS
Find out everything you need to know, from set up to troubleshooting. Download the manual now.
Use Adobe Reader for viewing.
HOW TO VIDEOS
Explore new features, get useful tips, see step-by-step instructions and find out how others are using Suunto devices.
Check out our videos.
DEALER LOCATOR
Open the dealer locator
MESSAGE US
Get in touch through MySuunto.
SIGN IN
REGISTER
What is MySuunto?
EMAIL US
Email us at support@suunto.com.
State the product name, serial number and a detailed description of the issue. We will respond within 72 hours, unless the solution requires a more in-depth analysis.
CALL US
Support in English available 24/7:
Australia +61 1800 240 498 (toll free)
New Zealand +64 988 75 223
United Kingdom +44 20 360 805 34
USA +1 855 258 0900 (toll free)
Support available from 9 am to 5 pm local time:
Austria +43 72 088 3104
Canada +1 800 267 7506 (toll free) - press 3 and then 1 for technical support (in English)
China +86-010-84054725
Finland +358 94 245 0127
France +33 48 168 0926
Germany +49 893 803 8778
Italy +39 029 475 1965
Japan +81 34 520 9417 from 10 am to 6 pm
Netherlands +31 10 713 7269 (in English)
Russia +7 499 918 7148
Spain +34 911 143 175
Sweden +46 85 250 0730
Switzerland +41 44 580 9988
Sports Watches, Dive Computers and Precision instruments
SUUNTO LIMITED WARRANTY
Suunto warrants that during the Warranty Period Suunto or a Suunto Authorized Service Center (hereinafter Service Center) will, at its sole discretion, remedy defects in materials or workmanship free of charge either by a) repairing, or b) replacing, or c) refunding, subject to the terms and conditions of this Limited Warranty. This Limited Warranty is only valid and enforceable in the country of purchase, unless local law stipulates otherwise.
Warranty Period
The Limited Warranty Period starts at the date of original retail purchase.
The Warranty Period is two (2) years for Products unless otherwise specified.
The Warranty Period is one (1) year for accessories including but not limited to wireless sensors and transmitters, chargers, cables, rechargeable batteries, straps, bracelets and hoses.
Exclusions and Limitations
This Limited Warranty does not cover:
This Limited Warranty is not enforceable if the Product or accessory:
You must provide proof of purchase to access Suunto warranty service. For instructions how to obtain warranty service, visit www.suunto.com/warranty, contact your local authorized Suunto retailer, or call Suunto Contact Center.
Limitation of Liability
To the maximum extent permitted by applicable mandatory laws, this Limited Warranty is your sole and exclusive remedy and is in lieu of all other warranties, expressed or implied. Suunto shall not be liable for special, incidental, punitive or consequential damages, including but not limited to loss of anticipated benefits, loss of data, loss of use, cost of capital, cost of any substitute equipment or facilities, claims of third parties, damage to property resulting from the purchase or use of the item or arising from breach of the warranty, breach of contract, negligence, strict tort, or any legal or equitable theory, even if Suunto knew of the likelihood of such damages. Suunto shall not be liable for delay in rendering warranty service.
Field Compasses
Warranty Period
Limited Lifetime Warranty:
Limited 2-year Warranty:
Get your Suunto product repaired with our online service request, available in the United States and in 30 European countries.
Online service request
IMPORTANT:
Repair is completed within approximately seven business days. If the product is not under warranty, we’ll send you a cost estimate before starting repair – if you choose not to have the product repaired, we’ll send it back to you but you’ll still be charged for the diagnosis and freight.
  • 6. If the solution is not covered by the warranty, we’ll send you payment details by email. Payments are made securely via PayPal. In Norway and Switzerland the costs are handled directly through a credit card company.
Andorra
Austria
Belgium
Bulgaria
Cyprus
Czech Republic
Denmark
Estonia
Finland
France
Germany
Greece
Hungary
Ireland
Italy
Latvia
Lithuania
Luxemburg
Malta
Netherlands
Norway
Poland
Portugal
Romania
Slovakia
Slovenia
Spain
Sweden
Switzerland
United Kingdom
United States
Service centers
