Share
REF SS019497000 / This product is no longer in production
Suunto Vector Berry Purple
Legendary outdoor sports watch with a solid track record of high-altitude performance
THE ORIGINAL MOUNTAIN WATCH
After a decade of travels, adventures and courageous expeditions, the Suunto Vector is still the most legendary watch with altimeter, barometer and compass. With technology and durability that can take on the harshest of environments, the Suunto Vector is the choice of professionals.
PRODUCT HIGHLIGHTS
  • Altimeter, barometer, compass
  • Robust and light
  • Trusted by professionals
  • Weather trend indicator
  • Temperature
  • Altitude difference measurement
  • Altitude log
  • Vertical speed
  • Multiple watch
  • Date and time functions
  • User-replaceable battery
What's in the box?
Suunto Berry Purple, Quick guide
Measurements 51.4  x  45.6  x  15.3  mm
Weight 54 g
Measurements 2.02  x  1.8 x  0.6 "
Weight 1.9 oz
Bezel material: Composite
Glass material: Acrylic
Case material: Composite
Strap material: Elastomer
Declination correction yes
Suunto Vector Berry Purple – Technical specifications
Weight 54 g / 1.9 oz
Water resistance 30 m (according to ISO 6425)
Battery life in time mode 12 months
Battery type CR2430
User replaceable battery
Time, date
Alarm clock up to 3 daily alarms
Countdown timer
Stopwatch timer
Languages EN
Backlight electro-luminescent
Display type 7 segments
Metric and imperial units
Digital compass
Tilt compensation bubble level
Direction scale degrees
Needle north-south indicator
Compass accuracy
Compass resolution
OUTDOOR FUNCTIONS
Barometric altitude
Altitude difference
Log recording rate 20 s / 1, 10, 60 min
Resolution 5 m
Range -500 - 9000 m
Sea level pressure
Temperature
Temperature display range -20° C to +60° C / -4° F to +140° F
Pressure resolution 1hPa/0.05 inHg
Temperature resolution
Max weather recording length 4 days
TRAINING INSIGHT
USER GUIDES
Use Adobe Reader for viewing.
HOW TO VIDEOS
Check out our videos.
DEALER AND SERVICE LOCATOR
Open the dealer locator
WRITE TO US
SIGN IN
REGISTER
What is MySuunto?
SUBMIT A QUESTION
CALL US
Warranty Period
For all Suunto Spartan watches purchased in 2016 the Warranty Period has been extended to three (3) years.
Exclusions and Limitations
Limitation of Liability
Suunto warrants that during the Warranty Period, as defined below, Suunto or Suunto Authorized Service Center will, at its sole discretion, remedy defects in materials or workmanship free of charge either by a) repairing, or b) replacing with similar product, or c) refunding, subject to the terms and conditions of this International Limited Warranty. This International Limited Warranty does not cover a) wear and tear, b) rough handling, c) modifications, d) exposure to chemicals, or e) misuse. Unless otherwise provided in applicable mandatory legislation, a) this International Limited Warranty is valid and enforceable regardless of the country of purchase, and b) to access the International Limited Warranty service, registration to www.suunto.com/mysuunto and proof of purchase is required. This International Limited Warranty does not affect your legal rights, granted under applicable mandatory legislation on the sale of consumer goods.
Warranty Period
International Limited Lifetime Warranty:
The International Warranty Period is limited until such reasonable time as the product is no longer reasonably usable due to wear and tear.
International Limited 2-year Warranty:
Applicable to Suunto AIM, Arrow, Orca-Pioneer and KB compasses.
The International Limited Warranty period is two (2) years from the date of original retail purchase.
TO THE MAXIMUM EXTENT PERMITTED BY APPLICABLE MANDATORY LAWS, THIS INTERNATIONAL LIMITED WARRANTY IS YOUR SOLE AND EXCLUSIVE REMEDY AND IS IN LIEU OF ALL OTHER WARRANTIES, EXPRESSED OR IMPLIED. SUUNTO SHALL NOT BE LIABLE FOR SPECIAL, INCIDENTAL, PUNITIVE OR CONSEQUENTIAL DAMAGES. SUUNTO SHALL NOT BE LIABLE FOR DELAY IN RENDERING WARRANTY SERVICE.
IMPORTANT:
Australia
Austria
Belgium
Bulgaria
Croatia
Cyprus
Czech Republic
Denmark
Estonia
Finland
France
Germany
Greece
Hungary
Ireland
Italy
Latvia
Lithuania
Luxemburg
Malaysia
Malta
Netherlands
New Zealand
Norway
Poland
Portugal
Romania
Singapore
Slovakia
Slovenia
Spain
Sweden
Switzerland
United Kingdom
United States
