Suunto Spartan Trainer Wrist HR User Guide - 1.10
Display theme
Display theme
To increase the readability of your watch screen while exercising or navigating, you can change between light and dark themes.
With the light theme, the display background is light and the numbers dark.
With the dark theme, the contrast is reverse, with the background dark and the numbers light.
The theme is a global setting that you can change in your watch from any of your sport mode options or from the navigation settings.
To change display theme in sport mode options:
  1. From the watch face, Press the upper right button to open the launcher.
  2. Scroll to Excercise and or press the middle button.
  3. Go to any sport mode and press the lower right button to open the sport mode options.
  4. Scroll down to Theme and press the middle button.
  5. Switch between Light and Dark by pressing the upper right and lower right buttons, and accept with the middle button.
  6. Scroll back up to exit the sport mode options and start (or exit) the sport mode.
To change display theme in navigation settings:
  1. Press the upper right button to open the launcher.
  2. Scroll to Navigation and press the middle button.
  3. Scroll down to Navigation settings as described above and the middle button.
  5. Switch between Light and Dark by pressing the upper right and lower right buttons and accept with the middle button.
  6. Exit the navigation settings by keeping the middle button pressed.
