REF SS020657000
Suunto Ambit2 R White
Integrated GPS watch with optimized features for running and optional heart rate monitoring
THE GPS FOR RUNNERS
The Suunto Ambit2 R White comes with a fit designed for women.
Suunto Ambit2 R is optimized for your perfect running experience. Built-in GPS and accelerometer provide accurate pace, speed, cadence and distance, while full route navigation offers you the freedom to explore. Heart rate monitoring, training plans and running apps make it easy to improve and keep track of every aspect of your performance. Discover a new dimension of running!
PRODUCT HIGHLIGHTS
Software upgrade
Suunto Ambit2 R Software upgrade 2.0
The software upgrade 2.0 brings usability and navigation improvements for the Ambit2 R.See all software updates here.
KEY TRAINING FUNCTIONS
  • Speed, pace and distance
  • Heart rate limits and graph in real time
  • Running cadence from the wrist
  • Training plans
  • ANT+ Foot POD support
ANT+™ logoThis product is ANT+™ certified.
Visit
www.thisisant.com/directory for a list of compatible products.
KEY OUTDOOR FUNCTIONS
  • Route navigation
  • Track back
  • GPS altitude
  • 3D compass
  • Suunto Apps
  • Customizable sport modes
  • Languages: DE, ES, IT, FI, SWE, IT, PT, NL
  • Water resistant to 50 m /164 f
What's in the box?
Suunto Ambit2 R White, Ambit power cable, and Quick guide
Measurements 50  x  50  x  15.5  mm
Weight 70 g
Measurements 1.97  x  1.97 x  0.61 "
Weight 2.47 oz
Bezel Material: Plastic
Lens material: Mineral crystal
Case material: Polyamide
Strap material: Silicone
Declination correction adjustable
Suunto Ambit2 R White – Technical specifications
Water resistance 50 m (according to ISO 6425)
Battery life in time mode 14 days
Battery type rechargeable lithium-ion
Firmware upgradable
Time, date
Alarm clock 1 daily alarm
Dual time
GPS timekeeping
Countdown timer
Stopwatch timer
UI languages EN, DE, ES, FI, FR, IT, NL, PT, SV
Backlight LED
Configurable backlight brightness / mode
Button lock customizable
Invert display
Display type matrix
Display resolution 128 x 128
Battery indicator percentage / icon
Metric and imperial units
CONNECTIVITY
Data transfer USB cable
Connectivity (between devices) Suunto ANT, ANT+
Compatible with Movescount
SUUNTO APPS
Compatible with Suunto Apps
Max. nr. of apps per sport mode 5
Logging of app specific metrics
Most recommended apps by activity
Create own metrics with advanced formulas
Chrono, GPS, HR, weather and altitude data yes, excluding weather
Running, cycling, swimming data yes, excluding cycling power/swimming
Rich math functions, if/then-logic, sound, backlight, etc.
COMPASS
Digital compass
Tilt compensation full
Direction scale degrees / mils
Needle north indicator
Compass accuracy
Compass resolution
PHYSICAL SPECIFICATIONS
Recommended charging temperature 0° C to +35° C / +32° F to +95° F
OUTDOOR FUNCTIONS
GPS TRACKING & NAVIGATION
Satellite systems GPS
GPS recording rate 1, 5, 60 s
Battery life (GPS active) 8, 12, 25 h
Coordinate systems WGS84 Hd.d°
WGS84 Hd°m' s.s''
WGS84 Hd°m.m
UTM
MGRS
British (BNG)
Finnish (ETRS-TM35FIN)
Finnish (KKJ)
Irish (IG)
Swedish (RT90)
Swiss (CH1903)
UTM NAD27 - Alaska
UTM NAD27 - Conus
UTM NAD83
New Zealand (NZTM2000)
Waypoint and visual route navigation
Max. nr. of Points of Interest (POIs) 100
Find back
Track back
Track logging, viewing and sharing * i
* available In Movescount.com
Route planning * i
Route points per route / POIs in watch 1000 / 100
ALTIMETER
GPS altitude
Altitude graph
Total ascent/descent GPS based
Vertical speed GPS based
Altitude difference yes** i
** available as Suunto Apps
Log recording rate 1, 10 s
Resolution 1 m
Range -500 - 9000 m
TRAINING/SPORTS FUNCTIONS
SPEED AND DISTANCE
GPS track recording
Integrated GPS speed and distance
Suunto Foot POD Mini speed and distance
Suunto GPS Track POD speed and distance
ANT+ speed and distance POD
Distance based autolaps
HEART RATE
RR interval
Heart rate in beats per minute
Heart rate in % of max hr
Real-time average and max heart rate
Heart rate limits
Heart rate zones * i
EPOC & V02 max values * i
Heart rate graph in real time
Calories
Peak Training Effect
Recovery time
Real time EPOC yes** i
TRAINING, PLANNING & ANALYSIS
Chrono
Laps > 1000
Autopause
Autoscrolling of exercise displays
Memory left indicator
Speed and heart rate-based guidance during exercise
Interval timers
Personalized workout guidance yes** i
Fitness test yes** i
Training plans downloadable from Movescount
Log summary on the watch with lap details
Customizeable sport modes and displays 10 modes / 8 displays per mode
Training analysis* i
Exercise merging, splitting, summaries * i
Training logbook with story and image support * i
GPS track analysis* i
Compatible with Strava and other communities i
RUNNING
Running pace
Suunto FusedSpeed™
Average pace in real time
Running cadence watch or Foot POD
Foot POD calibration manual or GPS
Average stride length yes** i
Running efficiency yes** i
Ghost Runner yes** i
Marathon End-time Estimator yes** i
Lap comparisons by kilometer/mile * i
CYCLING
Cycling speed based on GPS
Average speed in real time based on GPS
Hill incline in real time yes** i
SWIMMING
Openwater swim pace and distance
MANUALS
Find out everything you need to know, from set up to troubleshooting. Download the manual now.
Use Adobe Reader for viewing.
HOW TO VIDEOS
Explore new features, get useful tips, see step-by-step instructions and find out how others are using Suunto devices.
Check out our videos.
DEALER LOCATOR
Open the dealer locator
WRITE TO US
SIGN IN
REGISTER
What is MySuunto?
SUBMIT A QUESTION
We will respond within 72 hours, unless the solution requires a more in-depth analysis.
CALL US
Support in English available 24/7:
  • Australia +61 1800 240 498 (toll free)
  • New Zealand +64 988 75 223
  • United Kingdom +44 20 360 805 34
  • USA +1 855 258 0900 (toll free)
Support available from 9 am to 5 pm local time:
  • Austria +43 72 088 3104
  • Canada +1 800 267 7506 (toll free) - press 3 and then 1 for technical support (in English)
  • China +86-010-84054725
  • Finland +358 94 245 0127
  • France +33 48 168 0926
  • Germany +49 893 803 8778
  • Italy +39 029 475 1965
  • Japan +81 34 520 9417 from 10 am to 6 pm
  • Netherlands +31 10 713 7269 (in English)
  • Russia +7 499 918 7148
  • Spain +34 911 143 175
  • Sweden +46 85 250 0730
  • Switzerland +41 44 580 9988
Sports Watches, Dive Computers and Precision instruments
SUUNTO LIMITED WARRANTY
Suunto warrants that during the Warranty Period Suunto or a Suunto Authorized Service Center (hereinafter Service Center) will, at its sole discretion, remedy defects in materials or workmanship free of charge either by a) repairing, or b) replacing, or c) refunding, subject to the terms and conditions of this Limited Warranty. This Limited Warranty is only valid and enforceable in the country of purchase, unless local law stipulates otherwise.
Warranty Period
The Limited Warranty Period starts at the date of original retail purchase.
The Warranty Period is two (2) years for Products unless otherwise specified.
The Warranty Period is one (1) year for accessories including but not limited to wireless sensors and transmitters, chargers, cables, rechargeable batteries, straps, bracelets and hoses.
Exclusions and Limitations
This Limited Warranty does not cover:
This Limited Warranty is not enforceable if the Product or accessory:
You must provide proof of purchase to access Suunto warranty service. For instructions how to obtain warranty service, visit www.suunto.com/warranty, contact your local authorized Suunto retailer, or call Suunto Contact Center.
Limitation of Liability
To the maximum extent permitted by applicable mandatory laws, this Limited Warranty is your sole and exclusive remedy and is in lieu of all other warranties, expressed or implied. Suunto shall not be liable for special, incidental, punitive or consequential damages, including but not limited to loss of anticipated benefits, loss of data, loss of use, cost of capital, cost of any substitute equipment or facilities, claims of third parties, damage to property resulting from the purchase or use of the item or arising from breach of the warranty, breach of contract, negligence, strict tort, or any legal or equitable theory, even if Suunto knew of the likelihood of such damages. Suunto shall not be liable for delay in rendering warranty service.
Field Compasses
Warranty Period
Limited Lifetime Warranty:
Limited 2-year Warranty:
Get your Suunto product repaired with our online service request, available in the United States and in 30 European countries.
Online service request
IMPORTANT:
Repair is completed within approximately seven business days. If the product is not under warranty, we’ll send you a cost estimate before starting repair – if you choose not to have the product repaired, we’ll send it back to you but you’ll still be charged for the diagnosis and freight.
  • 6. If the solution is not covered by the warranty, we’ll send you payment details by email. Payments are made securely via PayPal. In Norway and Switzerland the costs are handled directly through a credit card company.
Andorra
Austria
Belgium
Bulgaria
Cyprus
Czech Republic
Denmark
Estonia
Finland
France
Germany
Greece
Hungary
Ireland
Italy
Latvia
Lithuania
Luxemburg
Malta
Netherlands
Norway
Poland
Portugal
Romania
Slovakia
Slovenia
Spain
Sweden
Switzerland
United Kingdom
United States
Service centers
