Share
REF SS020679000
Suunto Ambit3 Sport Blue (HR)
The multisport GPS watch with heart rate monitoring and mobile connection
Watch the video of Suunto
Connected Family with Ambit3.
THE MULTISPORT EXPERIENCE
The desire to be faster is universal. Whether you’re pushing your limits on the trail, on your bike or in the water, the Suunto Ambit3 Sport GPS watch is your invaluable multisport tool to become the best you can be. Track your running performance and analyze sleep recovery. Use the Suunto Movescount App to plan your workouts. With the app you can adjust the watch on the go and relive and share your experience.
PRODUCT HIGHLIGHTS
  • The GPS watch with advanced run, cycle and swim functions
  • Smart mobile connection
  • Enrich, relive and share your moves
Software upgrade
Suunto Ambit3 Sport software update, December 2016
With the 2.4.1 software update you can view the full track of the route you have done in the move summary and in logbook. Additionally you can preview your planned route in route selection. The update brings also daily step count and other enhancements to the watch. Read the full description of this software update.
MULTISPORT
  • 15h battery with 5 sec-GPS accuracy (1 min-accuracy: 100h)
  • Speed, pace, distance and GPS altitude
  • Route navigation and track back
  • Compass
  • Heart rate in swimming**
  • Bike power support (Bluetooth Smart)
  • Multiple sports in one log
  • Interval workout planner*
  • Activity based recovery time
  • Quick recovery and sleep recovery tests (Firstbeat)**
  • Discover new routes with heatmaps on Suunto Movescount and Suunto Movescount App
  • Movescount training programs on the watch
  • Extended feature set through Suunto Apps
  • Languages: EN, CS, DA, DE, ES, FI, FR, IT, JA, KO, NL, NO, PL, PT, RU, SV, ZH
CONNECTIVITY
  • Upload and share your moves instantly*
  • Customize your watch on the go*
  • Time and GPS satellite data up to date on the go*
  • Use your phone as second watch display* (Add an extended battery pack for your smartphone to support even longer adventures.)
  • Integration with Strava and TrainingPeaks
ENRICH, RELIVE AND SHARE
  • Take photos during your Move showing your current speed, distance, and more*
  • Create a Suunto Movie of your Move with 3D map, key metrics and images*
  • Share your experience instantly to your social media networks*
*with the Suunto Movescount App
**with Suunto Smart Sensor
Note! The Ambit3 watches are Bluetooth Smart compatible, not compatible with ANT+™ (e.g. Suunto ANT PODs, Suunto Dual or Suunto ANT belt)
What's in the box?
Suunto Ambit3 Sport Blue, Suunto Smart Sensor and blue heart rate belt (size M), USB cable, quick guide, warranty leaflet
Measurements 50  x  50  x  15.5  mm
Weight 80 g
Measurements 1.97  x  1.97 x  0.61 "
Weight 2.82 oz
Bezel material: Steel and polyamide
Glass material: Mineral crystal
Case material: Polyamide
Strap material: Silicone
Suunto Ambit3 Sport Blue (HR) – Technical specifications
Weight 80 g / 2.82 oz
Water resistance 50 m (according to ISO 6425)
Battery life in time mode 14 days
Battery type rechargeable lithium-ion
Firmware upgradable
Time, date
Alarm clock 1 daily alarm
Dual time
GPS timekeeping
Countdown timer
Stopwatch timer
Backlight LED
Configurable backlight brightness / mode
Button lock customizable
Invert display
Display type matrix
Display resolution 128 x 128
Battery indicator percentage / icon
Metric and imperial units
Autoscrolling of exercise displays
Memory left indicator
Languages EN, CS, DA, DE, ES, FI, FR, IT, JA, KO, NL, NO, PL, PT, RU, SV, ZH
Compatible with Suunto Apps
Max. nr. of apps per sport mode 5
Most recommended apps by activity
Logging of app specific metrics
Create own metrics with advanced formulas
Chrono, GPS, HR, weather and altitude data yes, excluding weather
Running, cycling, swimming data
Rich math functions, if/then-logic, sound, backlight, etc.
Digital compass
Tilt compensation full
Direction scale degrees / mils
Needle north indicator
Compass accuracy
Compass resolution
Declination correction
Bearing lock with direction indicator
Recommended charging temperature 0° C to +35° C / +32° F to +95° F
Watch customization Wireless / USB cable
Compatible with Suunto Movescount App
Data transfer Wireless / USB cable
Connectivity (between devices) Bluetooth Smart
Phone notifications on the watch with Suunto Movescount App
Phone as secondary display of watch with Suunto Movescount App i
For availability information check www.suunto.com/software-updates
Smartphone compatibility iPhone, Android
Compatible with online sports communities Strava, TrainingPeaks, MapMyFitness and others (available in Suunto Movescount.com)
Activity monitoring
Step counter
daily steps
OUTDOOR FUNCTIONS
Satellite systems GPS
GPS recording rate 1, 5, 60 s
Battery life (GPS active) 10, 15, 100 h i
For more information www.suunto.com/software-updates
Coordinate systems WGS84 Hd.d°
WGS84 Hd°m' s.s''
WGS84 Hd°m.m
UTM
MGRS
British (BNG)
Finnish (ETRS-TM35FIN)
Finnish (KKJ)
Irish (IG)
Swedish (RT90)
Swiss (CH1903)
UTM NAD27 - Alaska
UTM NAD27 - Conus
UTM NAD83
New Zealand (NZTM2000)
Waypoint and visual route navigation
Max. nr. of Points of Interest (POIs) 250
Find back
Track back
Track logging, viewing and sharing in Suunto Movescount.com
Route planning in Suunto Movescount.com
Route points per route / POIs in watch 1000 / 250
GPS track analysis
GPS altitude
Altitude graph
Total ascent/descent
GPS based
i
only available with best GPS accuracy
Vertical speed GPS based
Altitude difference yes** i
** available as Suunto Apps
Log recording rate 1, 10 s
Resolution 1 m
Range -500 - 9999 m
TRAINING FUNCTIONS
Distance based autolaps
Chrono
Laps >1000
Autopause
GPS speed and distance Integrated
Foot POD support Bluetooth Smart
Bike POD support Bluetooth Smart
RR interval
Heart rate in beats per minute
Heart rate in % of max hr
Real-time average and max heart rate
Heart rate limits
Heart rate zones * i
* available In Movescount.com
EPOC & V02 max values * i
Heart rate graph in real time coming to Spartan
This feature is coming later for Suunto Spartan watches, follow the updates on www.suunto.com/spartangetsstronger.
Calories
Peak Training Effect
Recovery time
Real time EPOC yes** i
Speed and heart rate-based guidance during exercise
Records heart rate in swimming yes, with Suunto Smart Sensor
Interval timers
Downloadable training plans from Suunto Movescount.com
Workout Planner i
For compatibility information check www.suunto.com/software-updates
Fitness test yes** i
Log summary on the watch with lap details
Training analysis in Suunto Movescount.com
Training logbook with story and image support in Suunto Movescount.com
Photos with watch data overlays with Suunto Movescount App
Suunto Movies with Suunto Movescount App
Sleep recovery test (Firstbeat™) i
Quick recovery test (Firstbeat™)
SPORT EXPERTISE
Customizable sport modes and displays coming to Spartan
10 modes / 8 displays per mode
Change sport mode during exercise
Preconfigured multisport modes
Multisport exercise summary
Post-analysis of multisport exercise by sport
Running pace
Suunto FusedSpeed™
Average pace in real time
Running cadence watch or Foot POD
Average stride length yes** i
Ghost Runner yes** i
Lap comparisons by kilometer/mile * i
Marathon End-time Estimator yes** i
Running Performance (Firstbeat™) i
Running power with Stryd sensor
Foot POD calibration manual or GPS
Cycling speed
Average speed in real time
Multiple Bike POD support
Hill incline in real time yes, available as Suunto Apps
Bike Power (W), average and maximum (with power sensor) Bluetooth Smart
Bike Power 3s, 10s, 30s (with power sensor)
Bike Lap and Lap Maximum Power (with power sensor)
Power distribution and graphs
Peak Power Curve for peak power outputs
Normalized Power (Suunto Apps / TM by Training Peaks) yes** i
Aerodynamic drag in real time (with power sensor) yes** i
Cadence POD Support Bluetooth Smart
Pool swim pace and distance
Openwater swim pace and distance
Swimming time by pool length, lap, total
Swimming stroke rate, count and type
Swim styles detection with personal style teaching
Stroke efficiency (SWOLF)
Automatic intervals
Dynamic lap table with stroke, pace and duration * i
USER GUIDES
Use Adobe Reader for viewing.
HOW TO VIDEOS
Check out our videos.
DEALER AND SERVICE LOCATOR
Open the dealer locator
WRITE TO US
SIGN IN
REGISTER
What is MySuunto?
SUBMIT A QUESTION
CALL US
Warranty Period
For all Suunto Spartan watches purchased in 2016 the Warranty Period has been extended to three (3) years.
Exclusions and Limitations
Limitation of Liability
Suunto warrants that during the Warranty Period, as defined below, Suunto or Suunto Authorized Service Center will, at its sole discretion, remedy defects in materials or workmanship free of charge either by a) repairing, or b) replacing with similar product, or c) refunding, subject to the terms and conditions of this International Limited Warranty. This International Limited Warranty does not cover a) wear and tear, b) rough handling, c) modifications, d) exposure to chemicals, or e) misuse. Unless otherwise provided in applicable mandatory legislation, a) this International Limited Warranty is valid and enforceable regardless of the country of purchase, and b) to access the International Limited Warranty service, registration to www.suunto.com/mysuunto and proof of purchase is required. This International Limited Warranty does not affect your legal rights, granted under applicable mandatory legislation on the sale of consumer goods.
Warranty Period
International Limited Lifetime Warranty:
The International Warranty Period is limited until such reasonable time as the product is no longer reasonably usable due to wear and tear.
International Limited 2-year Warranty:
Applicable to Suunto AIM, Arrow, Orca-Pioneer and KB compasses.
The International Limited Warranty period is two (2) years from the date of original retail purchase.
TO THE MAXIMUM EXTENT PERMITTED BY APPLICABLE MANDATORY LAWS, THIS INTERNATIONAL LIMITED WARRANTY IS YOUR SOLE AND EXCLUSIVE REMEDY AND IS IN LIEU OF ALL OTHER WARRANTIES, EXPRESSED OR IMPLIED. SUUNTO SHALL NOT BE LIABLE FOR SPECIAL, INCIDENTAL, PUNITIVE OR CONSEQUENTIAL DAMAGES. SUUNTO SHALL NOT BE LIABLE FOR DELAY IN RENDERING WARRANTY SERVICE.
IMPORTANT:
Australia
Austria
Belgium
Bulgaria
Croatia
Cyprus
Czech Republic
Denmark
Estonia
Finland
France
Germany
Greece
Hungary
Ireland
Italy
Latvia
Lithuania
Luxemburg
Malaysia
Malta
Netherlands
New Zealand
Norway
Poland
Portugal
Romania
Singapore
Slovakia
Slovenia
Spain
Sweden
Switzerland
United Kingdom
United States
