Share
REF SS013311010 / This product is no longer in production
Suunto Core Steel Steel
Measurements 49.1  x  49.1  x  14.5  mm
Weight 200 g
Measurements 1.93  x  1.93 x  0.57 "
Weight 7.05 oz
Bezel material: Aluminum
Glass material: Mineral crystal
Case material: Composite
Strap material: Silicone
Suunto Core Steel Steel – Technical specifications
Weight 200 g / 7.05 oz
Water resistance 30 m (according to ISO 6425)
Battery life in time mode 12 months
Battery type CR2032
User replaceable battery
Time, date
Alarm clock 1 daily alarm
Dual time
Countdown timer
Stopwatch timer
Languages EN, DE, ES, FR
Backlight electro-luminescent
Configurable backlight activation: 1 button, all buttons
Button lock
Display type matrix
Metric and imperial units
Digital compass
Direction scale degrees
Needle north indicator
Compass accuracy
Compass resolution
DIVING FUNCTIONS
Depth meter for snorkeling 10 m
OUTDOOR FUNCTIONS
Barometric altitude
Altitude graph
Automatic alti/baro profile coming to Spartan
This feature is coming later for Suunto Spartan watches, follow the updates on www.suunto.com/spartangetsstronger.
Altitude difference
Log recording rate 1, 5, 10, 30, 60 s
Resolution 1 m
Range -500 - 9000 m
Sea level pressure
Sea level pressure graph
Weather trend indicator
Temperature
Temperature display range -20° C to +60° C / -4° F to +140° F
Sunrise/sunset times
Storm alarm
Pressure resolution 1 hPa / 0.03 inHg
Temperature resolution
Max weather recording length 7 days
USER GUIDES
Use Adobe Reader for viewing.
HOW TO VIDEOS
Check out our videos.
DEALER AND SERVICE LOCATOR
Open the dealer locator
WRITE TO US
SIGN IN
REGISTER
What is MySuunto?
SUBMIT A QUESTION
CALL US
Warranty Period
For all Suunto Spartan watches purchased in 2016 the Warranty Period has been extended to three (3) years.
Exclusions and Limitations
Limitation of Liability
Suunto warrants that during the Warranty Period, as defined below, Suunto or Suunto Authorized Service Center will, at its sole discretion, remedy defects in materials or workmanship free of charge either by a) repairing, or b) replacing with similar product, or c) refunding, subject to the terms and conditions of this International Limited Warranty. This International Limited Warranty does not cover a) wear and tear, b) rough handling, c) modifications, d) exposure to chemicals, or e) misuse. Unless otherwise provided in applicable mandatory legislation, a) this International Limited Warranty is valid and enforceable regardless of the country of purchase, and b) to access the International Limited Warranty service, registration to www.suunto.com/mysuunto and proof of purchase is required. This International Limited Warranty does not affect your legal rights, granted under applicable mandatory legislation on the sale of consumer goods.
Warranty Period
International Limited Lifetime Warranty:
The International Warranty Period is limited until such reasonable time as the product is no longer reasonably usable due to wear and tear.
International Limited 2-year Warranty:
Applicable to Suunto AIM, Arrow, Orca-Pioneer and KB compasses.
The International Limited Warranty period is two (2) years from the date of original retail purchase.
TO THE MAXIMUM EXTENT PERMITTED BY APPLICABLE MANDATORY LAWS, THIS INTERNATIONAL LIMITED WARRANTY IS YOUR SOLE AND EXCLUSIVE REMEDY AND IS IN LIEU OF ALL OTHER WARRANTIES, EXPRESSED OR IMPLIED. SUUNTO SHALL NOT BE LIABLE FOR SPECIAL, INCIDENTAL, PUNITIVE OR CONSEQUENTIAL DAMAGES. SUUNTO SHALL NOT BE LIABLE FOR DELAY IN RENDERING WARRANTY SERVICE.
IMPORTANT:
Australia
Austria
Belgium
Bulgaria
Croatia
Cyprus
Czech Republic
Denmark
Estonia
Finland
France
Germany
Greece
Hungary
Ireland
Italy
Latvia
Lithuania
Luxemburg
Malaysia
Malta
Netherlands
New Zealand
Norway
Poland
Portugal
Romania
Singapore
Slovakia
Slovenia
Spain
Sweden
Switzerland
United Kingdom
United States
