Share
REF SS05108M200
Suunto SM-36 Tank Pressure Gauge 300
Highly accurate tank pressure gauge
RELIABLE AND ACCURATE TANK PRESSURE GAUGE
The extremely compact Suunto SM-36 tank pressure gauge incorporates a safety-pin-type tube and a gear mechanism, which provide outstanding accuracy and durability. The clear and bright phosphorescent dial face provides excellent readability, even in demanding conditions.
The SM-36 pressure gauge is suitable for 300 bar/4000 psi tanks and is available with either bar or psi display (360 bar or 5000 psi max display). The SM-36 pressure gauge can be fitted with the Suunto Combos or it can be attached directly to an HP hose.
PRODUCT HIGHLIGHTS
  • Outstanding quality, reliability, and accuracy
  • Easy-to-read display
  • For tanks with pressure up to 300 bar/4000 psi
  • Made in Finland
  • Outstanding build quality, reliability and accuracy
  • With Miflex Carbon HD high pressure hose
  • Easy-to-read display even in demanding conditions
  • Suitable for tanks with pressure up to 300 bar
  • With protective rubber sleeve
  • Made in Finland
What's in the box?
Suunto SM-36/300
No manuals found for this product.
HOW TO VIDEOS
Check out our videos.
DEALER AND SERVICE LOCATOR
Open the dealer locator
WRITE TO US
SIGN IN
REGISTER
What is MySuunto?
SUBMIT A QUESTION
CALL US
Warranty Period
Exclusions and Limitations
Limitation of Liability
SUUNTO LIMITED WARRANTY
Warranty Period
Limited Lifetime Warranty:
Limited 2-year Warranty:
IMPORTANT:
Australia
Austria
Belgium
Bulgaria
Croatia
Cyprus
Czech Republic
Denmark
Estonia
Finland
France
Germany
Greece
Hungary
Ireland
Italy
Latvia
Lithuania
Luxemburg
Malaysia
Malta
Netherlands
New Zealand
Norway
Poland
Portugal
Romania
Singapore
Slovakia
Slovenia
Spain
Sweden
Switzerland
United Kingdom
United States
