Share
REF SS021259000
Suunto Ambit3 Run White (HR)
The GPS watch for running with heart rate monitoring and mobile connection, designed for women
Availability: In stock
Free shipping on all orders over 50
Satisfied or your money back
THE RUNNING EXPERIENCE
Wherever you run, the Suunto Ambit3 Run is optimized for your perfect running experience. The running performance and sleep recovery measurements combined with full route navigation give you the tools to progress and explore. Use the Suunto Movescount App to plan your workouts. With the app you can adjust the watch on the go and relive and share your experience.
PRODUCT HIGHLIGHTS
  • The runner's solution for advanced training
  • Smart mobile connection
  • Enrich, relive and share your moves
  • Soft silicone strap for excellent fit
Suunto Movescount
Suunto Movescount is a growing outdoor sports community with a sports diary and unique personalization options to enrich your Suunto sports watch functionality. Join the Suunto Movescount sports community with the free Suunto Movescount App. Use it as a stand-alone sports app or pair it with Suunto Ambit3, Spartan, Traverse GPS watches or Bluetooth Smart heart rate monitors.
Software upgrade
Suunto Ambit3 Run software update, June 2017
The 2.4.17 update brings an updated step counter & minor technical improvements. Read more about this software update.
RUNNING AND TRAINING
  • 15h battery with 5 sec-GPS accuracy (1 min-accuracy: 100h)
  • Speed, pace, distance and GPS altitude
  • Route navigation and track back
  • Running cadence from the wrist
  • Running performance indication (Firstbeat)**
  • Interval workout planner*
  • Movescount training programs on the watch
  • Discover new routes with heatmaps on Suunto Movescount and Suunto Movescount App
  • Activity based recovery time
  • Quick recovery and sleep recovery tests (Firstbeat)**
  • Extended feature set through Suunto Apps
  • Languages: EN, CS, DA, DE, ES, FI, FR, IT, JA, KO, NL, NO, PL, PT, RU, SV, ZH
CONNECTIVITY
  • Upload and share your moves instantly*
  • Customize your watch on the go*
  • Time and GPS satellite data up to date on the go*
  • See calls, messages and push notifications on the watch*
  • Integration with Strava and TrainingPeaks
ENRICH, RELIVE AND SHARE
  • Take photos during your Move showing your current speed, distance, and more*
  • Create a Suunto Movie of your Move with 3D map, key metrics and images*
  • Share your experience instantly to your social media networks*
*with the Suunto Movescount App
**with Suunto Smart Sensor
Note! The Ambit3 watches are not compatible with ANT+™ (e.g. Suunto ANT PODs, Suunto Dual or Suunto ANT belt)
What's in the box?
Suunto Ambit3 Run White, Suunto Smart Sensor Black, USB cable, Quick Guide, Warranty Leaflet
Measurements 50  x  50  x  15.5  mm
Weight 72 g
Measurements 1.97  x  1.97 x  0.61 "
Weight 2.54 oz
Bezel material: Polyamide
Glass material: Mineral crystal
Case material: Polyamide
Strap material: Silicone
Suunto Ambit3 Run White (HR) – Technical specifications
Weight 72 g / 2.54 oz
Water resistance 50 m (according to ISO 6425)
Battery life in time mode 14 days
Battery type rechargeable lithium-ion
Time, date
Alarm clock 1 daily alarm
Dual time
GPS timekeeping
Countdown timer
Stopwatch timer
Languages EN, CS, DA, DE, ES, FI, FR, IT, JA, KO, NL, NO, PL, PT, RU, SV, ZH
Backlight LED
Configurable backlight brightness / mode
Button lock customizable
Invert display
Display type matrix
Display resolution 128 x 128
Battery indicator percentage / icon
Metric and imperial units
Autoscrolling of exercise displays
Memory left indicator
Firmware upgradable
Watch customization Wireless / USB cable
Connectivity (between devices) Bluetooth Smart
Data transfer Wireless / USB cable
Compatible with Suunto Movescount App
Phone notifications on the watch with Suunto Movescount App
Phone as secondary display of watch with Suunto Movescount App i
For availability information check www.suunto.com/software-updates
Compatible with online sports communities Strava, TrainingPeaks, MapMyFitness and others (available in Suunto Movescount.com)
Smartphone compatibility iPhone, Android
Compatible with Suunto Apps
Max. nr. of apps per sport mode 5
Logging of app specific metrics
Most recommended apps by activity
Chrono, GPS, HR, weather and altitude data yes, excluding weather
Running, cycling, swimming data yes, excluding cycling power/swimming
Rich math functions, if/then-logic, sound, backlight, etc.
Create own metrics with advanced formulas
Digital compass
Tilt compensation full
Direction scale degrees / mils
Needle north indicator
Compass accuracy
Compass resolution
Declination correction
Bearing lock with direction indicator
Recommended charging temperature 0° C to +35° C / +32° F to +95° F
Activity monitoring
Step counter
daily steps
TRAINING FUNCTIONS
Photos with watch data overlays with Suunto Movescount App
Suunto Movies with Suunto Movescount App
Distance based autolaps
Log recording rate 1, 10 s
Chrono
Laps > 1000
Autopause
GPS speed and distance Integrated
Foot POD support Bluetooth Smart
RR interval
Heart rate in beats per minute
Heart rate in % of max hr
Records heart rate in swimming yes, with Suunto Smart Sensor
Real-time average and max heart rate
Heart rate limits
Heart rate zones * i
* available In Movescount.com
EPOC & V02 max values * i
Heart rate graph in real time
Calories
Peak Training Effect
Recovery time
Real time EPOC yes** i
** available as Suunto Apps
Speed and heart rate-based guidance during exercise
Sleep recovery test (Firstbeat™) i
Quick recovery test (Firstbeat™)
Interval timers
Downloadable training plans from Suunto Movescount.com
Workout Planner i
For compatibility information check www.suunto.com/software-updates
Fitness test yes** i
Log summary on the watch with lap details
Training analysis in Suunto Movescount.com
Training logbook with story and image support in Suunto Movescount.com
OUTDOOR FUNCTIONS
Satellite systems GPS
GPS recording rate 1, 5, 60 s
Battery life (GPS active) 10, 15, 100 h i
For more information www.suunto.com/software-updates
Coordinate systems WGS84 Hd.d°
WGS84 Hd°m' s.s''
WGS84 Hd°m.m
UTM
MGRS
British (BNG)
Finnish (ETRS-TM35FIN)
Finnish (KKJ)
Irish (IG)
Swedish (RT90)
Swiss (CH1903)
UTM NAD27 - Alaska
UTM NAD27 - Conus
UTM NAD83
New Zealand (NZTM2000)
Waypoint and visual route navigation
Max. nr. of Points of Interest (POIs) 250
Track back
Route planning in Suunto Movescount.com
Route points per route / POIs in watch 1000 / 250
Track logging, viewing and sharing
GPS track analysis
Find back
Altitude graph
Vertical speed GPS based
Total ascent/descent
GPS based
i
only available with best GPS accuracy
Altitude difference yes** i
Resolution 1 m
Range -500 - 9999 m
GPS altitude
SPORT EXPERTISE
Customizable sport modes and displays 10 modes / 8 displays per mode
Running pace
Suunto FusedSpeed™
Average pace in real time
Running cadence watch or Foot POD
Foot POD calibration manual or GPS
Average stride length yes** i
Ghost Runner yes** i
Lap comparisons by kilometer/mile * i
Marathon End-time Estimator yes** i
Running Performance (Firstbeat™) i
Cycling speed based on GPS
Average speed in real time based on GPS
Openwater swim pace and distance
USER GUIDES
Use Adobe Reader for viewing.
Download PDF
HOW TO VIDEOS
Check out our videos.
DEALER AND SERVICE LOCATOR
Open the dealer locator
WRITE TO US
SIGN IN
REGISTER
What is MySuunto?
SUBMIT A QUESTION
CALL US
SUUNTO INTERNATIONAL LIMITED WARRANTY - Suunto Sports Watches, Dive Computers and Precision instruments
Warranty Period
For all Suunto Spartan watches purchased in 2016 the Warranty Period has been extended to three (3) years.
Exclusions and Limitations
Limitation of Liability
SUUNTO INTERNATIONAL LIMITED WARRANTY - Suunto Field Compasses
Suunto warrants that during the Warranty Period, as defined below, Suunto or Suunto Authorized Service Center will, at its sole discretion, remedy defects in materials or workmanship free of charge either by a) repairing, or b) replacing with similar product, or c) refunding, subject to the terms and conditions of this International Limited Warranty. This International Limited Warranty does not cover a) wear and tear, b) rough handling, c) modifications, d) exposure to chemicals, or e) misuse. Unless otherwise provided in applicable mandatory legislation, a) this International Limited Warranty is valid and enforceable regardless of the country of purchase, and b) to access the International Limited Warranty service, registration to www.suunto.com/mysuunto and proof of purchase is required. This International Limited Warranty does not affect your legal rights, granted under applicable mandatory legislation on the sale of consumer goods.
Warranty Period
International Limited Lifetime Warranty:
The International Warranty Period is limited until such reasonable time as the product is no longer reasonably usable due to wear and tear.
International Limited 2-year Warranty:
Applicable to Suunto AIM, Arrow, Orca-Pioneer and KB compasses.
The International Limited Warranty period is two (2) years from the date of original retail purchase.
TO THE MAXIMUM EXTENT PERMITTED BY APPLICABLE MANDATORY LAWS, THIS INTERNATIONAL LIMITED WARRANTY IS YOUR SOLE AND EXCLUSIVE REMEDY AND IS IN LIEU OF ALL OTHER WARRANTIES, EXPRESSED OR IMPLIED. SUUNTO SHALL NOT BE LIABLE FOR SPECIAL, INCIDENTAL, PUNITIVE OR CONSEQUENTIAL DAMAGES. SUUNTO SHALL NOT BE LIABLE FOR DELAY IN RENDERING WARRANTY SERVICE.
Warranty Period
IMPORTANT:
Australia
Austria
Belgium
Bulgaria
Croatia
Cyprus
Czech Republic
Denmark
Estonia
Finland
France
Germany
Greece
Hungary
Ireland
Italy
Latvia
Lithuania
Luxemburg
Malaysia
Malta
Netherlands
New Zealand
Norway
Poland
Portugal
Romania
Singapore
Slovakia
Slovenia
Spain
Sweden
Switzerland
United Kingdom
United States
