Share
REF SS010600610 / This product is no longer in production
Suunto Vector Yellow
Legendary outdoor sports watch with a solid track record of high-altitude performance
Availability: In stock
Free shipping over 50
Satisfied or your money back
THE ORIGINAL MOUNTAIN WATCH
After a decade of travels, adventures and courageous expeditions, the Suunto Vector is still the most legendary watch with altimeter, barometer and compass. With technology and durability that can take on the harshest of environments, the Suunto Vector is the choice of professionals.
PRODUCT HIGHLIGHTS
  • Altimeter, barometer, compass
  • Robust and light
  • Trusted by professionals
  • Weather trend indicator
  • Temperature
  • Altitude difference measurement
  • Altitude log
  • Vertical speed
  • Multiple watch
  • Date and time functions
  • User-replaceable battery
What's in the box?
Suunto Vector Yellow and Quick guide
Measurements 51.4  x  45.6  x  15.3  mm
Weight 54 g
Measurements 2.02  x  1.8 x  0.6 "
Weight 1.9 oz
Bezel material: Composite
Lens material: Acrylic
Case material: Composite
Strap material: Elastomer
Declination correction yes
Suunto Vector Yellow – Technical specifications
Weight 54 g
Water resistance 30 m (according to ISO 6425)
Battery life in time mode 12 months
Battery type CR2430
User replaceable battery
Time, date
Alarm clock up to 3 daily alarms
Countdown timer
Stopwatch timer
UI languages EN
Backlight electro-luminescent
Display type 7 segments
Metric and imperial units
Digital compass
Tilt compensation bubble level
Direction scale degrees
Needle north-south indicator
Compass accuracy
Compass resolution
OUTDOOR FUNCTIONS
Barometric altitude
Altitude difference
Log recording rate 20 s / 1, 10, 60 min
Resolution 5 m
Range -500 - 9000 m
Sea level pressure
Temperature
Temperature display range -20° C to +60° C / -4° F to +140° F
Pressure resolution 1hPa/0.05 inHg
Temperature resolution
Max weather recording length 4 days
TRAINING/SPORTS FUNCTIONS
MANUALS
Find out everything you need to know, from set up to troubleshooting. Download the manual now.
Use Adobe Reader for viewing.
HOW TO VIDEOS
Explore new features, get useful tips, see step-by-step instructions and find out how others are using Suunto devices.
Check out our videos.
DEALER LOCATOR
Open the dealer locator
WRITE TO US
SIGN IN
REGISTER
What is MySuunto?
SUBMIT A QUESTION
CALL US
SUUNTO LIMITED WARRANTY
Suunto warrants that during the Warranty Period Suunto or a Suunto Authorized Service Center (hereinafter Service Center) will, at its sole discretion, remedy defects in materials or workmanship free of charge either by a) repairing, or b) replacing, or c) refunding, subject to the terms and conditions of this Limited Warranty. This Limited Warranty is only valid and enforceable in the country of purchase, unless local law stipulates otherwise.
Warranty Period
The Limited Warranty Period starts at the date of original retail purchase.
The Warranty Period is two (2) years for Products unless otherwise specified.
The Warranty Period is one (1) year for accessories including but not limited to wireless sensors and transmitters, chargers, cables, rechargeable batteries, straps, bracelets and hoses.
Exclusions and Limitations
This Limited Warranty does not cover:
This Limited Warranty is not enforceable if the Product or accessory:
You must provide proof of purchase to access Suunto warranty service. For instructions how to obtain warranty service, visit www.suunto.com/warranty, contact your local authorized Suunto retailer, or call Suunto Contact Center.
Limitation of Liability
To the maximum extent permitted by applicable mandatory laws, this Limited Warranty is your sole and exclusive remedy and is in lieu of all other warranties, expressed or implied. Suunto shall not be liable for special, incidental, punitive or consequential damages, including but not limited to loss of anticipated benefits, loss of data, loss of use, cost of capital, cost of any substitute equipment or facilities, claims of third parties, damage to property resulting from the purchase or use of the item or arising from breach of the warranty, breach of contract, negligence, strict tort, or any legal or equitable theory, even if Suunto knew of the likelihood of such damages. Suunto shall not be liable for delay in rendering warranty service.
Warranty Period
Limited Lifetime Warranty:
Limited 2-year Warranty:
IMPORTANT:
Australia
Austria
Belgium
Bulgaria
Croatia
Cyprus
Czech Republic
Denmark
Estonia
Finland
France
Germany
Greece
Hungary
Ireland
Italy
Latvia
Lithuania
Luxemburg
Malaysia
Malta
Netherlands
New Zealand
Norway
Poland
Portugal
Romania
Singapore
Slovakia
Slovenia
Spain
Sweden
Switzerland
United Kingdom
United States
