Track back
With Track back, you can retrace your route at any point during an exercise. Suunto Ambit3 Run creates temporary waypoints to guide you back to your starting point.
To track back during exercise:
- While you are in a sport mode that uses GPS, keep pressed to access the options menu.
- Press Navigation. to select
- Scroll to Track back with and select with .
You can now start navigating your way back the same way as during route navigation. For more information about route navigation, see Navigating a route.
Track back can also be used from the logbook with exercises that include GPS data. Follow the same procedure as in Navigating a route. Scroll to Logbook instead of Routes, and select a log to start navigating.
