Calendar clock
Time and date settings are found under General / Device settings / Time & date.
Time and date formats are found under General / Device settings / Units and formats.
To change time and date
- Keep the middle button pressed to enter menu.
- Browse to General / Device settings / Time & date.
- Scroll to Set time or Set date with the upper or lower button.
- Press the middle button to enter the setting.
- Adjust the setting with the upper or lower button.
- Press the middle button to move to the next setting.
- Press again the middle button when last value is set to save and go back to Time & date menu.
- Keep middle button pressed to exit when done.
To change time and date formats
- Browse to General / Device settings / Units and formats.
- Scroll to Time format or Date format with the upper or lower button.
- Follow steps 5-8 as above to change and save formats.
