Find a dealer/service center
Suunto Traverse 使用手冊 - 2.0
路線
您可以使用 Suunto Movescount 內的路線規劃器制定一個路線,或將記錄的活動軌道匯出至規劃器。
若要新增路線時:
  1. 前往 Suunto Movescount 並登入。
  2. Plan & Create(規劃與建立)下,瀏覽至 Routes(路線)以搜尋和新增現有的路線,或瀏覽至Route Planner(路線規劃器)以建立您自己的路線。
  3. 儲存路線並選取「在我的…使用本路線」選項。
  4. 將您的 Suunto Traverse 和 Suunto Movescount 同步(使用 Suunto Movescount App(見 與行動app同步)或使用 Moveslink 與提供的 USB 傳輸線)。
也可透過 Suunto Movescount 刪除路線。
刪除路線:
  1. 前往 www.movescount.com 並登入。
  2. Plan & Create(規劃與建立)下,瀏覽至Route Planner(路線規劃器)
  3. MY ROUTES (我的路線) 下,按一下您要刪除的路線,然後按下DELETE (刪除)
Navigating a route
You can navigate a route you have transferred to your Suunto Traverse from Movescount (see 3.20 Routes) or from a log in your logbook with GPS data. You get a preview of the route based on the route list or logbook selection.
If you are using the compass for the first time, you need to calibrate it (see Calibrating compass). After activating the compass, the watch will begin searching for a GPS signal. After the watch acquires a GPS signal, you can begin to navigate a route.
To navigate a route:
  1. Press START to enter the start menu.
  2. Scroll to NAVIGATION with START and press NEXT.
  3. Scroll to Routes or NAVIGATION and press NEXT to enter .
  4. Scroll to the route you want to navigate with START or LIGHT and press NEXT.
  5. Press NEXT to select Navigate. All navigating is recorded. If you watch has more than one sport mode, you are prompted to select one.
  6. Select Forwards or Backwards to chose the direction you want to navigate (from the first waypoint or the last).
route select direction
  1. Start navigating. The watch informs you when you are approaching the beginning of the route.
route begin
  1. The watch informs you when you have arrived at your destination.
You can also start navigating while recording an activity (see Recording activities).
導航時
導航時,按下 VIEW,即可轉至下列視圖:
  • 顯示整條路線的完整軌跡視圖
  • 路線的放大視圖:於預設情況下,放大視圖是採用 100 公尺/0.1 英哩的比例,如果您遠離路線,也可以採用更大的比例。
軌跡視圖
完整軌跡視圖會向您顯示以下資訊:
  • (1) 箭頭,指出您的位置並指向您的前進方向。
  • (2) 路線的起點和終點
  • (3) 最靠近的景點顯示爲一個圖示。
  • (4) 軌跡視圖的比例
route track view
注释:
在完整軌跡視圖中,正北方向始終朝上。
地圖方位
您可以利用選項功能表的 NAVIGATIONNAVIGATION(導航)» SettingsSettings(設定) » MapMap(地圖)» OrientationOrientation(方位),以調整地圖的方位。
  • Heading upHeading up(前方朝上):以前方朝上的方式顯示放大地圖。
  • North upNorth up(北方朝上):以正北朝上的方式顯示放大地圖。
爬升過程檢視內容
在爬升過程檢視內容中,會顯示以下的資訊:
  1. 剩餘爬升量
  2. 即時的海拔變化過程圖
  3. 持續下降
ascent profile Traverse
如果您大幅偏離路徑軌道,即無法更新路徑圖。相反地,會在圖的下方顯示文字 Off routeOff route(偏離路徑)。您需要回到軌道上才能準確地加總計算。
