Share
REF SS020674000
Suunto Ambit3 Peak Black (HR)
The GPS watch for explorers with heart rate monitoring, weather functions and mobile connection
Watch the video of Suunto
Connected Family with Ambit3.
THE ADVENTURE EXPERIENCE
The journey to your summit is what it's all about – whether it's a mountain or a personal best. The Suunto Ambit3 Peak is your ultimate GPS watch for sports and adventure. It guides you every step of the way, providing all you need to progress and stay safe on your quest. Connect your watch wirelessly to your smartphone and use the free Suunto Movescount App to adjust the watch on the go and visually enrich, relive and share your adventure. There is no better companion out there to make every move count.
PRODUCT HIGHLIGHTS
  • The GPS watch with advanced outdoor and multisport functions
  • Smart mobile connection
  • Enrich, relive and share your Moves
Software upgrade
Suunto Ambit3 Peak software update, July 2016
The 2.2.16 software update brings added 3D distance option and several other smaller fixes and general performance improvements. Read more about this software update.
OUTDOOR AND MULTISPORT
  • 30h battery with 5 sec-GPS accuracy (1 min-accuracy: 200h)
  • Route navigation and track back
  • Compass
  • Altitude (FusedAltiTM)
  • Weather information
  • Heart rate in swimming**
  • Activity based recovery time
  • Speed, pace and distance
  • Bike power support (Bluetooth Smart)
  • Multiple sports in one log
  • Discover new routes with heatmaps on Suunto Movescount and Suunto Movescount App
  • Movescount training programs on the watch
  • Extended feature set through Suunto Apps
  • Languages: EN, CS, DA, DE, ES, FI, FR, IT, JA, KO, NL, NO, PL, PT, RU, SV, ZH
CONNECTIVITY
  • Upload and share your moves instantly*
  • Customize your watch on the go*
  • Time and GPS satellite data up to date on the go*
  • Use your phone as second watch display* (Add an extended battery pack for your smartphone to support even longer adventures.)
  • See calls, messages and push notifications on the watch*
ENRICH, RELIVE AND SHARE
  • Take photos during your Move showing your current speed, distance, and more*
  • Create a Suunto Movie of your Move with 3D map, key metrics and images*
  • Share your experience instantly to your social media networks*
*with the Suunto Movescount App
**with Suunto Smart Sensor
Note! The Ambit3 watches are Bluetooth Smart compatible, not compatible with ANT+™ (e.g. Suunto ANT PODs, Suunto Dual or Suunto ANT belt)
What's in the box?
Suunto Ambit3 Peak Black, Suunto Smart Sensor and black heart rate belt (size M), USB cable, quick guide, warranty leaflet
Measurements 50  x  50  x  18  mm
Weight 89 g
Measurements 1.97  x  1.97 x  0.71 "
Weight 3.14 oz
Bezel material: Steel
Glass material: Mineral crystal
Case material: Polyamide
Strap material: Elastomer
Suunto Ambit3 Peak Black (HR) – Technical specifications
Weight 89 g
Water resistance 100 m (according to ISO 6425)
Battery life in time mode 30 days
Battery type rechargeable lithium-ion
Firmware upgradable
Time, date
Alarm clock coming to Spartan
This feature is coming later for Suunto Spartan watches, follow the updates on www.suunto.com/spartangetsstronger.
1 daily alarm
Dual time
GPS timekeeping
Countdown timer
Stopwatch timer
Languages EN, CS, DA, DE, ES, FI, FR, IT, JA, KO, NL, NO, PL, PT, RU, SV, ZH i
For availability information check www.suunto.com/software-updates
Backlight LED
Configurable backlight brightness / mode
Button lock customizable
Invert display
Display type matrix
Display resolution 128 x 128
Battery indicator percentage / icon
Metric and imperial units
Autoscrolling of exercise displays
Memory left indicator
Compatible with Suunto Apps
Max. nr. of apps per sport mode 5
Logging of app specific metrics
Most recommended apps by activity
Create own metrics with advanced formulas
Chrono, GPS, HR, weather and altitude data
Running, cycling, swimming data
Rich math functions, if/then-logic, sound, backlight, etc.
Digital compass
Tilt compensation full
Direction scale degrees / mils
Needle north indicator
Compass accuracy
Compass resolution
Declination correction
Recommended charging temperature 0° C to +35° C / +32° F to +95° F
Watch customization Wireless / USB cable
Compatible with Suunto Movescount App
Data transfer Wireless / USB cable
Connectivity (between devices) Bluetooth Smart
Smartphone compatibility iPhone, Android
Phone notifications on the watch with Suunto Movescount App
Phone as secondary display of watch with Suunto Movescount App i
Compatible with online sports communities Strava, TrainingPeaks, MapMyFitness and others (available in Suunto Movescount.com)
Activity monitoring
OUTDOOR FUNCTIONS
Satellite systems GPS
GPS recording rate 1, 5, 60 s
Battery life (GPS active) 20, 30, 200 h i
For more information www.suunto.com/software-updates
Coordinate systems WGS84 Hd.d°
WGS84 Hd°m' s.s''
WGS84 Hd°m.m
UTM
MGRS
British (BNG)
Finnish (ETRS-TM35FIN)
Finnish (KKJ)
Irish (IG)
Swedish (RT90)
Swiss (CH1903)
UTM NAD27 - Alaska
UTM NAD27 - Conus
UTM NAD83
New Zealand (NZTM2000)
Waypoint and visual route navigation
Max. nr. of Points of Interest (POIs) 250
Find back
Track back
Track logging, viewing and sharing in Suunto Movescount.com
Route planning in Suunto Movescount.com
Route points per route / POIs in watch 1000 / 100
GPS track analysis
Barometric altitude
GPS altitude
Combined GPS and barometric altitude (FusedAlti™)
Altitude graph
Vertical speed air pressure based
Altitude difference yes** i
** available as Suunto Apps
Log recording rate 1, 10 s
Resolution 1 m
Range -500 - 9999 m
Sea level pressure
Sea level pressure graph
Weather trend indicator
Temperature
Temperature display range -20° C to +60° C / -4° F to +140° F
Sunrise/sunset times i
Automatic alti/baro profile coming to Spartan
Storm alarm
Tide information yes** i
Pressure resolution 1 hPa / 0.03 inHg
Temperature resolution
Max weather recording length past 26 hours
TRAINING INSIGHT
Distance based autolaps
Chrono
Laps > 1000
Autopause
GPS speed and distance Integrated
Foot POD support Bluetooth Smart
Bike POD support Bluetooth Smart
RR interval
Heart rate in beats per minute
Heart rate in % of max hr
Real-time average and max heart rate
Heart rate limits
Heart rate zones * i
* available In Movescount.com
EPOC & V02 max values * i
Heart rate graph in real time coming to Spartan
Calories
Peak Training Effect
Recovery time
Real time EPOC yes** i
Speed and heart rate-based guidance during exercise
Records heart rate in swimming yes, with Suunto Smart Sensor
Interval timers
Downloadable training plans from Suunto Movescount.com
Workout Planner i
For compatibility information check www.suunto.com/software-updates
Fitness test yes** i
Log summary on the watch with lap details
Training analysis in Suunto Movescount.com
Training logbook with story and image support in Suunto Movescount.com
Photos with watch data overlays with Suunto Movescount App
Suunto Movies with Suunto Movescount App
Sleep recovery test (Firstbeat™) i
Quick recovery test (Firstbeat™) i
For availability information www.suunto.com/software-updates
SPORT EXPERTISE
Customizable sport modes and displays coming to Spartan
10 modes / 8 displays per mode
Change sport mode during exercise
Preconfigured multisport modes
Multisport exercise summary
Post-analysis of multisport exercise by sport in Suunto Movescount.com
Running pace
Suunto FusedSpeed™
Average pace in real time
Running cadence watch or Foot POD
Average stride length yes** i
Ghost Runner yes** i
Marathon End-time Estimator yes** i
Lap comparisons by kilometer/mile * i
Running Performance (Firstbeat™) i
Running power with Stryd sensor
Foot POD calibration manual or GPS
Cycling speed
Average speed in real time
Multiple Bike POD support
Hill incline in real time yes, available as Suunto Apps
Bike Power (W), average and maximum (with power sensor) Bluetooth Smart
Bike Power 3s, 10s, 30s (with power sensor)
Bike Lap and Lap Maximum Power (with power sensor)
Power distribution and graphs
Peak Power Curve for peak power outputs
Normalized Power (Suunto Apps / TM by Training Peaks) yes** i
Aerodynamic drag in real time (with power sensor) yes** i
Cadence POD Support Bluetooth Smart
Pool swim pace and distance
Openwater swim pace and distance
Swimming time by pool length, lap, total
Swimming stroke rate, count and type
Swim styles detection with personal style teaching
Stroke efficiency (SWOLF)
Automatic intervals
Dynamic lap table with stroke, pace and duration * i
USER GUIDES
Use Adobe Reader for viewing.
HOW TO VIDEOS
Check out our videos.
DEALER AND SERVICE LOCATOR
Open the dealer locator
WRITE TO US
SIGN IN
REGISTER
What is MySuunto?
SUBMIT A QUESTION
CALL US
Warranty Period
Exclusions and Limitations
Limitation of Liability
SUUNTO LIMITED WARRANTY
Warranty Period
Limited Lifetime Warranty:
Limited 2-year Warranty:
IMPORTANT:
Australia
Austria
Belgium
Bulgaria
Croatia
Cyprus
Czech Republic
Denmark
Estonia
Finland
France
Germany
Greece
Hungary
Ireland
Italy
Latvia
Lithuania
Luxemburg
Malaysia
Malta
Netherlands
New Zealand
Norway
Poland
Portugal
Romania
Singapore
Slovakia
Slovenia
Spain
Sweden
Switzerland
United Kingdom
United States
