Share
REF SS016788000 / This product is no longer in production
Suunto Core Lava Red
Essential outdoor functions in a robust plastic case with an all black, light elastomer strap.
THE OUTDOOR WATCH
The award-winning Suunto Core comes in a range of stylish design options, packing easy to use outdoor functionalities in a robust construction. Combining altimeter, barometer and a compass with weather information, the Core provides the essential features for adventures in the great outdoors. Designed to bring out the explorer in you.
PRODUCT HIGHLIGHTS
  • Altimeter, barometer, compass
  • Weather functions
  • Mountain & everywhere use
  • Altimeter
  • Barometer
  • Compass
  • Temperature
  • Storm alarm
  • Sunrise / sunset
  • Depth meter for snorkeling
  • Multiple watch, date and time functions
  • User-replaceable battery
  • Multilingual menu (EN, FR, DE, ES)
What's in the box?
Suunto Core Lava Red and Quick Guide
Measurements 49.1  x  49.1  x  14.5  mm
Weight 63 g
Measurements 1.93  x  1.93 x  0.57 "
Weight 2.22 oz
Bezel material: Aluminum
Glass material: Mineral crystal
Case material: Composite
Strap material: Elastomer
Suunto Core Lava Red – Technical specifications
Weight 63 g
Water resistance 30 m (according to ISO 6425)
Battery life in time mode 12 months
Battery type CR2032
User replaceable battery
Time, date
Alarm clock 1 daily alarm
Dual time
Countdown timer
Stopwatch timer
Languages EN, DE, ES, FR
Backlight electro-luminescent
Configurable backlight activation: 1 button, all buttons
Button lock
Display type matrix
Metric and imperial units
Digital compass
Direction scale degrees
Needle north indicator
Compass accuracy
Compass resolution
DIVING FUNCTIONS
Depth meter for snorkeling 10 m
OUTDOOR FUNCTIONS
Barometric altitude
Altitude graph
Automatic alti/baro profile coming to Spartan in November
This feature is coming later for Suunto Spartan watches, follow the updates on www.suunto.com/spartangetsstronger.
Altitude difference
Log recording rate 1, 5, 10, 30, 60 s
Resolution 1 m
Range -500 - 9000 m
Sea level pressure
Sea level pressure graph
Weather trend indicator
Temperature
Temperature display range -20° C to +60° C / -4° F to +140° F
Sunrise/sunset times
Storm alarm
Pressure resolution 1 hPa / 0.03 inHg
Temperature resolution
Max weather recording length 7 days
USER GUIDES
Use Adobe Reader for viewing.
HOW TO VIDEOS
Check out our videos.
DEALER AND SERVICE LOCATOR
Open the dealer locator
WRITE TO US
SIGN IN
REGISTER
What is MySuunto?
SUBMIT A QUESTION
CALL US
Warranty Period
Exclusions and Limitations
Limitation of Liability
SUUNTO LIMITED WARRANTY
Warranty Period
Limited Lifetime Warranty:
Limited 2-year Warranty:
IMPORTANT:
Australia
Austria
Belgium
Bulgaria
Croatia
Cyprus
Czech Republic
Denmark
Estonia
Finland
France
Germany
Greece
Hungary
Ireland
Italy
Latvia
Lithuania
Luxemburg
Malaysia
Malta
Netherlands
New Zealand
Norway
Poland
Portugal
Romania
Singapore
Slovakia
Slovenia
Spain
Sweden
Switzerland
United Kingdom
United States
