Share
REF SS014529000 / This product is no longer in production
Suunto Elementum Aqua Black Rubber / light display
Premium sports watch for urban and underwater use
THE PREMIUM DIVING WATCH
Suunto Elementum Aqua is a superbly crafted timepiece exclusively manufactured in Finland.  It combines a heritage in craftsmanship with the functionality of a high-technology diving watch. While the Aqua is perfect for urban use, in water it transforms into a dive watch. The Aqua automatically detects when the user enters water and starts all the functions and measurements needed for an enjoyable dive. Designed with stainless steel casing and a sapphire crystal glass to withstand the elements.
PRODUCT HIGHLIGHTS
  • Finnish craftmanship
  • Stainless steel case with sapphire glass
  • Depth, dive and surface time, dive log
  • Auto dive mode with depth
  • Max depth
  • Dive time
  • Water temperature
  • Log: last 14 dives
Measurements 44.7  x  51.5  x  14.3  mm
Weight 105 g
Measurements 1.76  x  2.03 x  0.56 "
Weight 3.7 oz
Bezel material: Steel
Glass material: Sapphire crystal
Case material: Stainless steel
Strap material: Silicone
Suunto Elementum Aqua Black Rubber / light display – Technical specifications
Weight 105 g
Water resistance 200 m (ISO 6425, EN 13319)
Battery life in time mode 12 months
Battery type CR2032
Time, date
Alarm clock coming to Spartan
This feature is coming later for Suunto Spartan watches, follow the updates on www.suunto.com/spartangetsstronger.
1 daily alarm
Languages EN
Backlight electro-luminescent
Button lock
Display type matrix
Metric and imperial units
Operating temperature -10° C to +60° C / +14° F to +140° F
DIVING FUNCTIONS
Maximum operating depth (EN 13319) 80 m
Freedive
Dive time 0 to 99 h 59 min
Surface time 0 to 48 h
Logbook memory last 14 dives
OUTDOOR FUNCTIONS
Temperature display range 0° C to +40° C / +32° F to +104° F
Temperature resolution
Temperature
USER GUIDES
Use Adobe Reader for viewing.
HOW TO VIDEOS
Check out our videos.
DEALER AND SERVICE LOCATOR
Open the dealer locator
WRITE TO US
SIGN IN
REGISTER
What is MySuunto?
SUBMIT A QUESTION
CALL US
Warranty Period
Exclusions and Limitations
Limitation of Liability
SUUNTO LIMITED WARRANTY
Warranty Period
Limited Lifetime Warranty:
Limited 2-year Warranty:
IMPORTANT:
Australia
Austria
Belgium
Bulgaria
Croatia
Cyprus
Czech Republic
Denmark
Estonia
Finland
France
Germany
Greece
Hungary
Ireland
Italy
Latvia
Lithuania
Luxemburg
Malaysia
Malta
Netherlands
New Zealand
Norway
Poland
Portugal
Romania
Singapore
Slovakia
Slovenia
Spain
Sweden
Switzerland
United Kingdom
United States
