Share
REF SS018735000
Suunto Core Alu Pure White
The outdoor watch with altimeter, barometer & compass in an elegant aluminum case
SUUNTO CORE - THE OUTDOOR WATCH
Suunto Core Premium combines modern design with the essential outdoor functions. Choose rigid natural stainless steel with sapphire crystal glass for added durability, or the elegant aluminum cases for less weight on the wrist.
PRODUCT HIGHLIGHTS
  • Altimeter, barometer, compass
  • Weather functions
  • Mountain & everywhere use
  • Altimeter
  • Barometer
  • Compass
  • Temperature
  • Storm alarm
  • Sunrise / sunset
  • Depth meter for snorkeling
  • Multiple watch, date and time functions
  • User-replaceable battery
  • Multilingual menu (EN, FR, DE, ES)
What's in the box?
Suunto Core Alu Pure White and Quick Guide
Measurements 49.1  x  49.1  x  14.5  mm
Weight 79 g
Measurements 1.93  x  1.93 x  0.57 "
Weight 2.79 oz
Bezel material: Aluminum
Glass material: Mineral crystal
Case material: Aluminum
Strap material: Silicone
Suunto Core Alu Pure White – Technical specifications
Weight 79 g
Water resistance 30 m (according to ISO 6425)
Battery life in time mode 12 months
Battery type CR2032
User replaceable battery
Time, date
Alarm clock coming to Spartan
This feature is coming later for Suunto Spartan watches, follow the updates on www.suunto.com/spartangetsstronger.
1 daily alarm
Dual time
Countdown timer
Stopwatch timer
Languages EN, DE, ES, FR
Backlight electro-luminescent
Configurable backlight activation: 1 button, all buttons
Button lock
Display type matrix
Metric and imperial units
Digital compass
Direction scale degrees
Needle north indicator
Compass accuracy
Compass resolution
DIVING FUNCTIONS
Depth meter for snorkeling 10 m
OUTDOOR FUNCTIONS
Barometric altitude
Altitude graph
Automatic alti/baro profile
Altitude difference
Log recording rate 1, 5, 10, 30, 60 s
Resolution 1 m
Range -500 - 9000 m
Sea level pressure
Sea level pressure graph
Weather trend indicator
Temperature
Temperature display range -20° C to +60° C / -4° F to +140° F
Sunrise/sunset times i
Automatic alti/baro profile coming to Spartan
Storm alarm
Pressure resolution 1 hPa / 0.03 inHg
Temperature resolution
Max weather recording length 7 days
USER GUIDES
Use Adobe Reader for viewing.
HOW TO VIDEOS
Check out our videos.
DEALER AND SERVICE LOCATOR
Open the dealer locator
WRITE TO US
SIGN IN
REGISTER
What is MySuunto?
SUBMIT A QUESTION
CALL US
Warranty Period
Exclusions and Limitations
Limitation of Liability
SUUNTO LIMITED WARRANTY
Warranty Period
Limited Lifetime Warranty:
Limited 2-year Warranty:
IMPORTANT:
Australia
Austria
Belgium
Bulgaria
Croatia
Cyprus
Czech Republic
Denmark
Estonia
Finland
France
Germany
Greece
Hungary
Ireland
Italy
Latvia
Lithuania
Luxemburg
Malaysia
Malta
Netherlands
New Zealand
Norway
Poland
Portugal
Romania
Singapore
Slovakia
Slovenia
Spain
Sweden
Switzerland
United Kingdom
United States
