Share
REF SS019997000
Suunto Elementum Terra Black/Yellow Leather
Premium sports watch for urban and mountain life
THE PREMIUM OUTDOOR WATCH
Suunto Elementum Terra is a superbly crafted timepiece, exclusively manufactured in Finland. This urban inspired premium watch combines a heritage in craftsmanship with precision digital technology. While the Terra is perfect for urban use, it also measures altitude and weather trends and includes a unique 3D compass for adventures in the great outdoors. Designed with stainless steel casing and a sapphire crystal glass to withstand the elements.
PRODUCT HIGHLIGHTS
  • Finnish craftmanship
  • Stainless steel case with sapphire glass
  • Altimeter, barometer, compass
  • Altimeter
  • Barometric pressure & trend
  • 3D compass
  • Log: last 8 ascent / descent, max. altitude
What's in the box?
Suunto Elementum Terra Black/Yellow Leather, Quick Guide, Cleaning cloth
Measurements 44.7  x  51.5  x  14.3  mm
Weight 97 g
Measurements 1.76  x  2.03 x  0.56 "
Weight 3.42 oz
Bezel material: Steel
Glass material: Sapphire crystal
Case material: Stainless steel
Strap material: Leather
Suunto Elementum Terra Black/Yellow Leather – Technical specifications
Weight 97 g
Water resistance 100 m (according to ISO 6425)
Battery life in time mode 12 months
Battery type CR2032
Time, date
Alarm clock coming to Spartan
This feature is coming later for Suunto Spartan watches, follow the updates on www.suunto.com/spartangetsstronger.
1 daily alarm
Stopwatch timer
Languages EN
Backlight electro-luminescent display
Button lock
Display type matrix
Metric and imperial units
Digital compass
Tilt compensation up to 45°
Direction scale degrees
Needle north indicator
Compass accuracy
Compass resolution
Operating temperature -10° C to +60° C / +14° F to +140° F
OUTDOOR FUNCTIONS
Barometric altitude
Automatic alti/baro profile coming to Spartan in November
Log recording rate 1, 5, 10 s
Resolution 1 m
Range -500 - 9000 m
Sea level pressure
Weather trend indicator
Pressure resolution 1hPa/0.03 inHg
Max weather recording length last 6 hours
USER GUIDES
Use Adobe Reader for viewing.
HOW TO VIDEOS
Check out our videos.
DEALER AND SERVICE LOCATOR
Open the dealer locator
WRITE TO US
SIGN IN
REGISTER
What is MySuunto?
SUBMIT A QUESTION
CALL US
Warranty Period
Exclusions and Limitations
Limitation of Liability
SUUNTO LIMITED WARRANTY
Warranty Period
Limited Lifetime Warranty:
Limited 2-year Warranty:
IMPORTANT:
Australia
Austria
Belgium
Bulgaria
Croatia
Cyprus
Czech Republic
Denmark
Estonia
Finland
France
Germany
Greece
Hungary
Ireland
Italy
Latvia
Lithuania
Luxemburg
Malaysia
Malta
Netherlands
New Zealand
Norway
Poland
Portugal
Romania
Singapore
Slovakia
Slovenia
Spain
Sweden
Switzerland
United Kingdom
United States
