Share
REF SS012197310 / This product is no longer in production
Suunto X-Lander Black
Outdoor instrument with altimeter, barometer, compass and watch functions in a tough metal case
THE PREMIUM MOUNTAIN WATCH
Suunto X-Lander is the choice for outdoor people who are not willing to make compromises when it comes to the quality, materials and functionality of their equipment. The choice of professionals, Suunto X-Lander features an accurate altimeter, a complete barometer and a precise electronic compass in a light and robust casing.
PRODUCT HIGLIGHTS
  • Altimeter, barometer, compass
  • Aluminium case with mineral glass
  • Trusted by professionals
  • Cumulative altitude log
  • Altitude log
  • Vertical speed
  • Weather trend indicator
  • Temperature
  • Multiple watch, date and alarm functions
  • User-replaceable battery
What's in the box?
Suunto X-Lander Black and Quick Guide
Measurements 51.2  x  47.7  x  16.4  mm
Weight 65 g
Measurements 2.02  x  1.88 x  0.65 "
Weight 2.29 oz
Bezel material: Aluminum
Glass material: Acrylic
Case material: Aluminum
Strap material: Leather
Suunto X-Lander Black – Technical specifications
Weight 65 g
Water resistance 30 m (according to ISO 6425)
Battery life in time mode 12 months
Battery type CR2430
User replaceable battery
Time, date
Alarm clock coming to Spartan
This feature is coming later for Suunto Spartan watches, follow the updates on www.suunto.com/spartangetsstronger.
up to 3 daily alarms
Countdown timer
Stopwatch timer
Languages EN
Backlight electro-luminescent
Display type 7 segments
Metric and imperial units
Digital compass
Direction scale degrees
Needle north-south indicator
Compass accuracy
Compass resolution
OUTDOOR FUNCTIONS
Barometric altitude
Altitude difference
Log recording rate 20 s / 1, 10, 60 min
Resolution 5 m
Range -500 - 9000 m
Sea level pressure
Temperature
Temperature display range -20° C to +60° C / -4° F to +140° F
Pressure resolution 1hPa/0.05 inHg
Temperature resolution
Max weather recording length 4 days
TRAINING INSIGHT
Chrono
Laps 2
USER GUIDES
Use Adobe Reader for viewing.
HOW TO VIDEOS
Check out our videos.
DEALER AND SERVICE LOCATOR
Open the dealer locator
WRITE TO US
SIGN IN
REGISTER
What is MySuunto?
SUBMIT A QUESTION
CALL US
Warranty Period
Exclusions and Limitations
Limitation of Liability
SUUNTO LIMITED WARRANTY
Warranty Period
Limited Lifetime Warranty:
Limited 2-year Warranty:
IMPORTANT:
Australia
Austria
Belgium
Bulgaria
Croatia
Cyprus
Czech Republic
Denmark
Estonia
Finland
France
Germany
Greece
Hungary
Ireland
Italy
Latvia
Lithuania
Luxemburg
Malaysia
Malta
Netherlands
New Zealand
Norway
Poland
Portugal
Romania
Singapore
Slovakia
Slovenia
Spain
Sweden
Switzerland
United Kingdom
United States
