Share
REF SS014587000 / Este producto se ha dejado de fabricar
Suunto Cobra3
Advanced air-integrated dive computer with electronic 3D compass
Cargando precio e información sobre existencias
Suunto Cobra3 is an all-in-one console-mounted dive computer. It features air-integration, an electronic 3D compass, an easy-to-read matrix display, and simplified four-button operation.
Air integration
Suunto Cobra3 monitors and displays your tank pressure, tracks your rate of air consumption, and continuously calculates your remaining air time. It also provides visual and audible alarms for depth and pressure and warns you when you're running low on air.
Clear navigation
Suunto Cobra3 features a unique electronic 3D compass that can be tilted up to 45 degrees in any direction, making it easier to read the figures clearly and accurately under water.
Effortless operation
The easy-to-read dot matrix display and electro-luminescent backlight mean all your dive-critical information – including bearing, tank pressure, depth, and dive time – will all be shown clearly. And with the simplified four-button operation, the computer is easy to operate even when wearing gloves.
Multi-mode versatility
With its Nitrox, Air, and Gauge modes and gas-switching capabilities, Suunto Cobra3 delivers everything you need to maximize bottom time and make the most of every dive. When using enriched air, Suunto Cobra3 can be programmed for nitrox mixtures between 21% and 100% oxygen. You can also adjust oxygen partial pressure between 0.5 and 1.6 bar. In Gauge mode, it can also be used as a depth gauge and timer with profile memory.
Flexible decompression
Using the Suunto Deep Stop RGBM algorithm, Suunto Cobra3 enables continuous decompression for optimal ascent time. For deeper dives, the Deep Stop option adds further protection with a series of deep stops between your maximum depth and ceiling.
When in Nitrox mode, you can accelerate decompression by switching to a gas mix with a higher oxygen percentage. With Suunto Cobra3 it's quick and easy to switch between enabled gas mixes while diving.
Plan and review
You can test upcoming dives and view no-decompression and decompression time data for different depths before getting in the water with the built-in dive simulator. When the dive is over, get detailed graphical logs and dive data on your computer using Suunto DM4 software.
LO MÁS DESTACADO DEL PRODUCTO
  • Modos de aire, nítrox y manómetro
  • Brújula 3D
  • Suunto RGBM
  • Pantalla matricial de fácil lectura
  • Air integrated for tank pressure information
  • Tiltable electronic 3D compass to keep you on course
  • User-friendly design featuring easy-to-read matrix display and simplified four-button operation
  • Three dive modes and gas-switching capability for a range of dive situations
  • Continuous decompression with the Suunto RGBM algorithm
  • Built-in dive simulator for planning upcoming dives
  • Optional computer interface for detailed graphical logbooks and dive data analysis
Medidas 73  x  165  x  35  mm
Peso 210 g
Medidas 2,87  x  6,5 x  1,38 "
Peso 7,41 oz
Material del bisel: Compuesto
Material de la lente: Acrílico
Material de la carcasa: Compuesto
Material de la correa: Elastómero
Corrección de la declinación
Suunto Cobra3 – Especificaciones técnicas
Peso 210 g / 7,41 oz
Sumergibilidad 100 m (ISO 13319)
Duración de la pila en modo Time 3 años
Duración de la pila: 100 inmersiones/año 1,5 años
Tipo de pila CR 2450
Pila sustituible por el usuario
Hora, fecha
Despertador 1 alarma diaria
Idiomas EN
Luz de fondo electroluminiscente
Luz de fondo configurable duración: 5, 10, 20, 30, 60 s
Tipo de pantalla matricial
Resolución de pantalla 49 x 22
Indicador de batería indicador de batería baja
Unidades métricas e imperiales
Transferencia de datos Cable USB (opcional)
Compatible con DM5
Compatible con Suunto Movescount con DM5
Brújula digital
Compensación de inclinación hasta 45°
Escala de dirección grados
Aguja escala de la brújula
Equilibrado mundial
Fijación de rumbo con indicador de orientación
Exactitud de la brújula 10°
Resolución de brújula
Temperatura de funcionamiento De 0° C a +40° C/de +32° F a +104° F
Temperatura de almacenamiento De -20 ° C a +50 ° C/de -4° F a +122° F
FUNCIONES DE BUCÉO
Profundidad máxima de funcionamiento (EN 13319) 100 m
Nítrox (y aire)
Manómetro
Tiempo de inmersión De 0 a 999 min
Tiempo en superficie De 0 a 99 h 59 min
Tiempo sin vuelo
Parada de seguridad
Parada profunda
Pantalla de tiempo de ascenso 0-99 min (- - después de 99)
Cálculo de SNC/UTO (FLO)
Integración de aire de manguera
Modelo de descompresión SUUNTO RGBM
Ajustes personales 0-2
Ajuste de altitud 0-300 m/300-1500 m/1500-3000 m
Gases hasta 2 gases (oxígeno 21-99%)
Gas máx. pO2 1,2-1,6
Cambio de gases
Planificador sin descompresión
Memoria de diario ~42 h (frecuencia de muestreo 20 s)
Puntos de referencia en diario
Frecuencias de muestreo para diario 1, 10, 20, 30, 60 s
Historial de inmersiones toda la vida útil
Tiempo de inmersión
Profundidad máxima
Presión en la botella
pO2 alto (hiperóxico)
Ascenso demasiado rápido
Violación del techo de descompresión
SNC/UTO (FLO) 80%/100%
Cambio de gas (mejor gas disponible)
FUNCIONES PARA AIRE LIBRE
Intervalo de indicación de temperatura De -20° C a +50° C (+/- 2° C)/de -9° C a +122° F (+/- 3,6° F)
Resolución de temperatura 1° C/1,5° F
Temperatura
GUÍAS DEL USUARIO
Las guías del usuario proporcionan un resumen completo de las funciones del producto, cómo utilizarlas y las normas generales de uso y especificaciones técnicas.
Usa Adobe Reader para verlas.
Descargar PDF
VÍDEOS A MODO DE GUÍA
Te dan consejos útiles e instrucciones detalladas y te permiten descubrir nuevas funciones y cómo utilizan otras personas los productos Suunto.
Mira nuestros vídeos.
LOCALIZADOR DE DISTRIBUIDORES Y SERVICIOS TÉCNICOS
Busca un servicio técnico autorizado o un distribuidor Suunto en tu zona.
Abrir el localizador de distribuidores
Cambio de la batería del ordenador de buceo y del dispositivo
Suunto recomienda acudir a un centro de servicio autorizado para cambiar la batería del ordenador de buceo y del dispositivo. Puedes encontrar tu centro de servicio más cercano utilizando el buscador de distribuidores Suunto. Simplemente, selecciona el centro de servicio y la categoría del producto. También puedes solicitar la reparación de tu producto Suunto con nuestra solicitud de servicio en línea. Los países en los que está disponible aparecen relacionados en la página de solicitud de servicio en línea.
Algunas de las ventajas de recurrir a un centro de servicio autorizado Suunto son:
  • Además de la batería, también se sustituyen las juntas y otras piezas mecánicas gastadas o dañadas.
  • Las baterías de recambio son nuevas (máxima capacidad) y las piezas cumplen las especificaciones de Suunto para garantizar una duración de la batería según las especificaciones y mantener intacta la integridad del producto.
  • El ordenador de buceo no sufrirá daños por una descarga electroestática repentina, ya que el cambio de batería se lleva a cabo en un entorno seguro.
  • Después de las tareas de servicio, se comprueba el correcto funcionamiento del producto y su sumergibilidad.
  • Las tareas de servicio son realizadas por personal formado por Suunto, con las herramientas adecuadas y recambios originales Suunto, lo que garantiza una atención óptima de tu ordenador.
  • Lo productos Suunto reparados por un proveedor de servicio autorizado cuentan con tres (3) meses de garantía de servicio a partir de la fecha de reparación.
Suunto DM5 para la planificación y el seguimiento de tus inmersiones – para PC y MAC
Suunto DM5 te permite descargar tus registros de inmersión para realizar un análisis avanzado y cargar planes de inmersión detallados a tu ordenador de buceo. El programa se puede descargar de forma gratuita. Suunto DM5 está disponible en inglés, holandés, francés, finlandés, alemán, japonés, coreano, español y chino. Los requisitos mínimos del sistema operativo son: Mac 10.7 o Windows XP. Más información sobre DM5.
Algunas de las ventajas de utilizar Suunto DM5 son:
  • Con el planificador gráfico de inmersiones Suunto DM5 podrás crear fácilmente perfiles de inmersión y gestionar gases y planes de respaldo. Cuando hayas terminado, puedes transferir los gases planificados y demás información crítica de inmersión a tu ordenador de buceo (solo en modelos seleccionados*). También puedes imprimir las instrucciones para mezclar los gases desde DM5.
  • Tras la inmersión puedes transferir tus registros de inmersión a DM5. Tus inmersiones se guardan en el diario, donde puedes revisarlas, analizarlas y organizarlas por fecha, modo y equipo. La función de etiquetado te facilita la tarea de marcar tus inmersiones y organizarlas según tus preferencias personales. Además, puedes seleccionar varias inmersiones para compararlas entre sí.
  • También puedes guardar tus inmersiones en Suunto Movescount y compartirlas con tus amigos.
Descarga Suunto DM5 gratuitamente aquí:
PARA WINDOWS
PARA MAC
ESCRÍBENOS
Puedes obtener asistencia en chino, inglés, finlandés, francés, alemán, italiano, japonés, ruso, español o sueco.
1. Contacta a través de MySuunto.
INICIAR SESIÓN
REGISTRARME
¿Qué es MySuunto?
2. O bien puedes dejar tu mensaje a continuación (no es preciso registrarse)
HAZ UNA CONSULTA
Trataremos de responder en los próximos días. Sin embargo, si necesitas ayuda urgente, ponte en contacto por teléfono.
LLÁMANOS
Asistencia disponible en inglés 24/7.
Asistencia disponible de las 9:00 a las 17:00 en el horario local en días laborales:
Si tu país no aparece en la lista, las llamadas tendrán el coste establecido por tu compañía telefónica para llamadas internacionales. Tu llamada puede ser controlada o grabada con fines de control de calidad o formación.
GARANTÍA LIMITADA INTERNACIONAL SUUNTO - Relojes deportivos, ordenadores de buceo e instrumentos de precisión
Suunto garantiza que, durante el periodo de vigencia de la garantía, Suunto o un Centro de servicio técnico autorizado Suunto (en adelante, "Centro de servicio") subsanarán, de la forma que consideren oportuna y sin cargo alguno, cualquier desperfectos de materiales o fabricación ya sea mediante a) la reparación, b) la sustitución, o c) el reembolso, con sujeción a los términos y condiciones de la presente Garantía limitada internacional. La presente Garantía limitada internacional será válida y exigible independientemente del país de compra. La Garantía limitada internacional no afecta a sus derechos legales, garantizados por la legislación nacional vigente aplicable a la venta de bienes de consumo.
Periodo de garantía
El periodo de garantía limitada internacional se computará a partir de la fecha de compra original.
El periodo de garantía es de dos (2) años para productos y transmisores de buceo, salvo que se estipule lo contrario.
El periodo de garantía es de un (1) año para accesorios, incluidos, entre otros, los sensores inalámbricos, cargadores, cables, baterías recargables, correas, brazaletes y latiguillos.
Se extiende a tres (3) años el periodo de garantía para todos los relojes Suunto Spartan comprados en 2016.
Exclusiones y limitaciones
Esta Garantía limitada internacional no cubre:
  1. a) el desgaste normal, como arañazos, abrasiones o alteraciones en el color y/o en el material de las correas no metálicas, b) los defectos causados por un manejo poco cuidadoso, y c) los defectos o daños causados por un uso inadecuado o contrario al recomendado o previsto, o por accidentes, como caídas o golpes fuertes;
  2. los materiales impresos y el embalaje;
  3. los daños o supuestos menoscabos ocasionados como consecuencia de la utilización de productos, accesorios, software y/o servicio técnico no realizado o proporcionado por Suunto;
  4. las baterías no recargables.
Suunto no garantiza un funcionamiento del Producto o los accesorios sin interrupciones o errores repentinos, ni tampoco que el Producto o los accesorios funcionen con cualquier otro elemento de hardware o software proporcionado por un tercero.
La presente Garantía limitada internacional no será de aplicación en caso de que:
  1. el Producto o el accesorio haya sido abierto más allá del uso para el que fue concebido;
  2. el Producto o el accesorio haya sido reparado utilizando recambios no autorizados; o bien, modificado o reparado por un centro de servicio no autorizado;
  3. a criterio de Suunto, el número de serie del Producto o el accesorio haya sido eliminado o alterado de cualquier otra forma, haya devenido ilegible o
  4. haya sido expuesto a productos químicos, incluidos (entre otros) los protectores solares o los repelentes de mosquitos.
Acceso al servicio de garantía de Suunto
Para acceder al servicio de garantía de Suunto, es necesario presentar la prueba de compra. Asimismo, usted deberá registrar su producto en línea en www.suunto.com/mysuunto para recibir servicios de garantía internacional en cualquier país. Para obtener instrucciones acerca de cómo acceder al servicio de garantía, visite www.suunto.com/warranty, póngase en contacto con su distribuidor autorizado Suunto o llame al Centro de contacto de Suunto.
Limitación de responsabilidad
La presente Garantía limitada internacional constituye su única garantía, en sustitución de cualquier otra garantía, expresa o implícita, y en todo caso dentro de los límites de la legislación aplicable. Suunto no se hace responsable de los daños especiales, accidentales, punitorios o consecuentes, incluidos, a título meramente enunciativo pero no limitativo, pérdidas de beneficios esperados, pérdidas de datos, pérdidas de uso, costes de capital, costes de sustitución de equipamientos o instalaciones, reclamaciones de terceros, daños causados en una propiedad como consecuencia de la compra o utilización del artículo, o derivados del incumplimiento de las condiciones de la garantía, incumplimiento contractual, negligencia, agravio civil o cualquier otro supuesto legal análogo o equivalente, aun cuando Suunto tuviera conocimiento de la posibilidad de que tales daños pudieran producirse. Suunto no se hace responsable del retraso ocasionado en la prestación de los servicios cubiertos por la garantía.
GARANTÍA INTERNACIONAL LIMITADA SUUNTO - Brújulas de campo
Suunto garantiza que, durante el periodo de vigencia de la garantía, según se define a continuación, Suunto o un Centro de servicio autorizado Suunto subsanarán, de la forma que consideren oportuna y sin cargo alguno, cualquier defecto en materiales o fabricación, ya sea mediante a) reparación, b) sustitución por un producto similar, o c) reembolso, con sujeción a los términos y condiciones de la presente Garantía Internacional Limitada. La presente Garantía Internacional Limitada no cubre a) desgaste natural, b) manipulación descuidada, c) modificaciones, d) exposición a productos químicos, ni e) uso indebido. Salvo disposición en otro sentido en la legislación vigente, a) la presente Garantía Internacional Limitada Internacional es válida y aplicable independientemente del país de compra, y b) para acceder al servicio de Garantía Internacional Limitada es preciso estar registrado en www.suunto.com/mysuunto y presentar comprobante de compra. La Garantía Internacional Limitada no afecta a sus derechos legales estipulados en la legislación nacional vigente sobre la venta de bienes de consumo.
Periodo de garantía
Garantía Internacional Limitada de por vida:
Aplicable a la brújulas A, M, MC, MB y Clipper de Suunto.
El periodo de la Garantía Internacional está limitado hasta que, según criterios razonables, el producto ya no esté utilizable debido al desgaste.
Garantía Internacional Limitada de 2 años:
Aplicable a las brújulas AIM, Arrow, Orca-Pioneer y KB de Suunto.
El período de la Garantía Internacional Limitada es de dos (2) años a partir de la fecha de compra original.
LA PRESENTE GARANTÍA INTERNACIONAL LIMITADA CONSTITUYE SU ÚNICA GARANTÍA, EN SUSTITUCIÓN DE CUALQUIER OTRA GARANTÍA EXPRESA O IMPLÍCITA Y, EN TODO CASO, DENTRO DE LOS LÍMITES DE LA LEGISLACIÓN NACIONAL APLICABLE. SUUNTO NO SE HACE RESPONSABLE DE DAÑOS ESPECIALES, INCIDENTALES, PUNITIVOS NI INDIRECTOS. SUUNTO NO SE HACE RESPONSABLE DE RETRASOS EN LA PRESTACIÓN DE LOS SERVICIOS CUBIERTOS POR LA GARANTÍA.
GARANTÍA LIMITADA INTERNACIONAL DE SUUNTO
Suunto garantiza que, durante el Período de Garantía, según se define a continuación, Suunto o un Centro de Servicio Autorizado de Suunto, a su sola discreción, corregirá los defectos en materiales o mano de obra de forma gratuita, ya sea mediante a) reparación, o b) sustitución por un producto similar, o c) reembolso, con sujeción a los términos y condiciones de esta Garantía Limitada. La presente Garantía Limitada Internacional no cubre a) desgaste natural, b) manipulación descuidada, c) modificaciones, d) exposición a productos químicos, ni e) uso indebido. Salvo disposición en otro sentido en la legislación vigente, a) la presente Garantía Limitada Internacional es válida y aplicable independientemente del país de compra, y b) para acceder al servicio de Garantía Limitada Internacional es preciso estar registrado en www.suunto.com/mysuunto y presentar comprobante de compra. La Garantía Limitada Internacional no afecta a sus derechos legales estipulados en la legislación nacional vigente sobre la venta de bienes de consumo.
Período de Garantía
Garantía Limitada Internacional de por vida:
Aplicable a las brújulas Suunto A, M, MC, MB y Clipper.
El Período de Garantía Internacional se entiende limitado hasta el momento en el que el producto pierda su capacidad para el uso normal debido al desgaste natural.
Garantía Limitada Internacional de 2 años:
Aplicable a las brújulas Suunto AIM, Arrow, Orca-Pioneer y KB.
El Período de Garantía Internacional es de dos (2) años a partir de la fecha de compra original.
LA PRESENTE GARANTÍA CONSTITUYE SU ÚNICA GARANTÍA, EN SUSTITUCIÓN DE CUALESQUIERA OTRAS EXPRESAS O IMPLÍCITAS Y, EN TODO CASO, DENTRO DE LOS LÍMITES DE LA LEGISLACIÓN NACIONAL APLICABLE. SUUNTO NO SE HACE RESPONSABLE DE DAÑOS ESPECIALES, INCIDENTALES, PUNITIVOS NI INDIRECTOS. SUUNTO NO SE HACE RESPONSABLE DE RETRASOS EN LA PRESTACIÓN DE LOS SERVICIOS CUBIERTOS POR LA GARANTÍA.
Solicita la reparación de tu producto Suunto mediante nuestra solicitud de reparación en línea. Amplía la pestaña de solicitud de reparación en línea más abajo para comprobar la disponibilidad del servicio en tu país.
Si no aparece tu país, o si tienes una brújula o instrumento de precisión, puedes encontrar tu centro de asistencia más cercano utilizando el buscador de distribuidores Suunto. Simplemente, selecciona el centro de asistencia y la categoría de productos.
Nuestra solicitud de asistencia online está disponible en los países enumerados a continuación. Si no aparece tu país, o si tienes una brújula o instrumento de precisión, puedes encontrar tu centro de asistencia más cercano utilizando el buscador de distribuidores Suunto. Simplemente, selecciona el centro de asistencia y la categoría de productos.
IMPORTANTE:
La reparación se realiza en aproximadamente siete días laborables. Si el producto no está en garantía, te enviaremos un presupuesto antes de comenzar la reparación. Si no aceptas este presupuesto, te devolveremos el producto y te cobraremos un importe fijo en concepto de análisis y transporte, que puede cambiar entre países.
Instrucciones para completar la solicitud de asistencia online:
  • 1. Necesitas una dirección válida de correo electrónico, el n.º de serie de tu producto y acceso a una impresora.
  • 2. Selecciona tu país en la lista.
  • 3. Rellena la información obligatoria. Los documentos para el envío se crean automáticamente para que los imprimas. Guárdalos con el producto que nos vas a enviar.
  • 4. Cuando recibas la confirmación, llama a la empresa de mensajería con el número de teléfono que te indicamos para que recojan tu producto.
  • 5. No envíes con el producto las guías de usuario, manuales de instrucciones ni paquetes de venta. No podremos devolvértelos.
  • 6. Si la solución no queda cubierta por la garantía, te remitiremos los detalles del pago por correo electrónico. Puedes hacer el pago de forma segura mediante PayPal.
  • 7. En cuanto el producto esté reparado, te lo remitiremos a la dirección que indicaste al rellenar la solicitud de asistencia.
Australia
Austria
Bélgica
Bulgaria
Croacia
Chipre
República Checa
Dinamarca
Estonia
Finlandia
Francia
Alemania
Grecia
Hungría
Irlanda
Italia
Letonia
Lituania
Luxemburgo
Malasia
Malta
Países Bajos
Nueva Zelanda
Noruega
Polonia
Portugal
Rumanía
Singapur
Eslovaquia
Eslovenia
España
Suecia
Suiza
Reino Unido
Estados Unidos
Suunto tiene una amplia red de centros de servicio autorizados en distintos países para ayudarle con todas sus necesidades de reparación y mantenimiento. Puede encontrar su centro de servicio más cercano utilizando el buscador de distribuidores Suunto. Simplemente seleccione el centro de servicio y la categoría de productos.
Además, puede contactar con Asistencia al cliente de Suunto para encontrar la mejor forma de reparar su producto.
