Share
REF SS016421000 / Este producto se ha dejado de fabricar
Suunto Core Extreme Edition Everest
A limited edition of the award winning Suunto Core family
Cargando precio e información sobre existencias
Thrilling Moves with Apa Sherpa
In honor of the legendary mountaineer and Suunto Ambassador Apa Sherpa, Suunto launches a limited edition outdoor sports instrument, the Suunto Core Extreme Edition Everest. Celebrating Apa Sherpa’s world-record 20th summit of Mount Everest, the Core Extreme Edition Everest reflects the determination and strength of one of the world’s greatest living mountaineers.
Suunto will donate a portion of all proceeds of this product to the Apa Sherpa Foundation to help support the education of the children living in the remote village near the base camp of Mount Everest.
As a limited edition, Suunto is producing only 8,848 pieces of the Extreme Edition Everest to match the elevation of Mount Everest’s peak at 8,848 meters.
Add your own moves at www.movescount.com and join the Thrilling Moves competition!
Altimeter
The altimeter features a range up to 9000m (29 500 ft). It is ideally suited for all activities where knowing your altitude and ascent and descent rates is essential. The Core altimeter sports an altitude difference measurement that allows you to track your progress in terms of altitude climbed. The log recorder stores all your movements in altitude between the start and stop times, so you can re-live your trip at home - view graphs of changes in altitude during your treks, find out how much you climbed, the duration of ascents and descents, average ascent and descent speed and more.
Barometer
Suunto Core displays the current sea level pressure as a detailed graph, showing recording of the last 24 hours with a recording interval of 30 minutes. The weather trend indicator is a useful feature providing quick reference to check upcoming weather conditions. The storm alarm notifies you of a sudden drop in air pressure, which may be related to worsening weather conditions.
Automatic Alti/Baro switch
Suunto Core sports an Automatic Alti/Baro switch, a smart feature that senses your movement or lack thereof, switching between altimeter and barometer accordingly. When you’re climbing, it records changes in elevation. And when you stop to rest, it records changes in barometric pressure. A drop in air pressure while you’re sleeping under the stars will be recorded for what it really is: a change in barometric pressure, not altitude.
Compass
The digital compass displays the cardinal or half-cardinal point and the North. The declination adjustment function allows you to correct the difference between the true North and magnetic North. You can also set it to track a certain bearing, which helps you follow a chosen direction in the terrain. The compass features a one-touch function that allows you to sight lock and follow a bearing.
Depth meter
Intended for snorkeling, the Suunto Core depth meter provides information on current depth and the maximum depth reached during your snorkeling dive. The maximum depth of the device is 10m (32,8 ft).
Watch
Watch functions include time, dual time, date, alarm, sports chronograph, countdown timer and predicted times for sunrise and sunset for over 400 locations worldwide.
LO MÁS DESTACADO DEL PRODUCTO
  • Altímetro, barómetro, brújula
  • Funciones de clima
  • Uso en la montaña y cualquier lugar
  • A numbered, limited edition of 8848 pieces inspired by Mount Everest’s height of 8848 meters
  • Altimeter with altitude log memory and altitude difference measurement
  • Barometer with storm alarm and weather trend indicator
  • Automatic Alti / Baro switch
  • Compass with semi automatic calibration and a digital bearing
  • Depth meter
  • Multiple watch, date and alarm functions with dual time and countdown timer
  • Sunrise/Sunset times for over 400 locations worldwide
  • Digital thermometer
  • Menu based user interface in English, German, French and Spanish
  • User-replaceable battery
Medidas 49,1  x  49,1  x  14,5  mm
Peso 65 g
Medidas 1,93  x  1,93 x  0,57 "
Peso 2,29 oz
Material del bisel: Aluminio
Material de la lente: Cristal mineral
Material de la carcasa: Compuesto
Material de la correa: Silicona
Suunto Core Extreme Edition Everest – Especificaciones técnicas
Peso 65 g / 2,29 oz
Sumergibilidad 30 m (según ISO 6425)
Duración de la pila en modo Time 12 meses
Tipo de pila CR2032
Pila sustituible por el usuario
Hora, fecha
Despertador 1 alarma diaria
Hora dual
Temporizador de cuenta atrás
Cronómetro
Idiomas EN, DE, ES, FR
Luz de fondo electroluminiscente
Luz de fondo configurable activación: 1 botón, todos los botones
Bloqueo de botones
Tipo de pantalla matricial
Indicador de batería indicador de batería baja
Unidades métricas e imperiales
Brújula digital
Escala de dirección grados
Aguja indicador de norte
Fijación de rumbo con indicador de orientación
Exactitud de la brújula
Resolución de brújula
Temperatura de funcionamiento De -20° C a +60° C/de -5° F a +140° F
Temperatura de almacenamiento De -30° C a +60° C/de -22° F a +140° F
FUNCIONES DE BUCÉO
Profundímetro para inmersión con snorkel 10 m
FUNCIONES PARA AIRE LIBRE
Altitud barométrica
Gráfica de altitud
Ascenso/descenso total basado en presión atmosférica
Perfil automático alti/baro
Diferencia de altitud
Frecuencia de grabación de registros 1, 5, 10, 30, 60 s
Resolución 1 m
Intervalo -500 - 9000 m
Presión a nivel del mar
Gráfica de presión a nivel del mar
Indicador de tendencia del clima
Temperatura
Intervalo de indicación de temperatura De -20° C a +60° C/de -4° F a +140° F
Hora de amanecer/puesta de sol
Alarma de tormenta
Resolución de presión 1 hPa/0,03 inHg
Resolución de temperatura
Máx. duración de registro de clima 7 días
GUÍAS DEL USUARIO
Las guías del usuario proporcionan un resumen completo de las funciones del producto, cómo utilizarlas y las normas generales de uso y especificaciones técnicas.
Usa Adobe Reader para verlas.
VÍDEOS A MODO DE GUÍA
Te dan consejos útiles e instrucciones detalladas y te permiten descubrir nuevas funciones y cómo utilizan otras personas los productos Suunto.
Mira nuestros vídeos.
LOCALIZADOR DE DISTRIBUIDORES Y SERVICIOS TÉCNICOS
Busca un servicio técnico autorizado o un distribuidor Suunto en tu zona.
Abrir el localizador de distribuidores
ESCRÍBENOS
Puedes obtener asistencia en chino, inglés, finlandés, francés, alemán, italiano, japonés, ruso, español o sueco.
1. Contacta a través de MySuunto.
INICIAR SESIÓN
REGISTRARME
¿Qué es MySuunto?
2. O bien puedes dejar tu mensaje a continuación (no es preciso registrarse)
HAZ UNA CONSULTA
Trataremos de responder en los próximos días. Sin embargo, si necesitas ayuda urgente, ponte en contacto por teléfono.
LLÁMANOS
Asistencia disponible en inglés 24/7.
Asistencia disponible de las 9:00 a las 17:00 en el horario local en días laborales:
Si tu país no aparece en la lista, las llamadas tendrán el coste establecido por tu compañía telefónica para llamadas internacionales. Tu llamada puede ser controlada o grabada con fines de control de calidad o formación.
GARANTÍA LIMITADA INTERNACIONAL SUUNTO
Suunto garantiza que, durante el periodo de vigencia de la garantía, Suunto o un Centro de servicio técnico autorizado Suunto (en adelante, "Centro de servicio") subsanarán, de la forma que consideren oportuna y sin cargo alguno, cualquier desperfectos de materiales o fabricación ya sea mediante a) la reparación, b) la sustitución, o c) el reembolso, con sujeción a los términos y condiciones de la presente Garantía limitada internacional. La presente Garantía limitada internacional será válida y exigible independientemente del país de compra. La Garantía limitada internacional no afecta a sus derechos legales, garantizados por la legislación nacional vigente aplicable a la venta de bienes de consumo.
Periodo de garantía
El periodo de garantía limitada internacional se computará a partir de la fecha de compra original.
El periodo de garantía es de dos (2) años para productos y transmisores de buceo, salvo que se estipule lo contrario.
El periodo de garantía es de un (1) año para accesorios, incluidos, entre otros, los sensores inalámbricos, cargadores, cables, baterías recargables, correas, brazaletes y latiguillos.
Se extiende a tres (3) años el periodo de garantía para todos los relojes Suunto Spartan comprados en 2016.
Exclusiones y limitaciones
Esta Garantía limitada internacional no cubre:
  1. a) el desgaste normal, como arañazos, abrasiones o alteraciones en el color y/o en el material de las correas no metálicas, b) los defectos causados por un manejo poco cuidadoso, y c) los defectos o daños causados por un uso inadecuado o contrario al recomendado o previsto, o por accidentes, como caídas o golpes fuertes;
  2. los materiales impresos y el embalaje;
  3. los daños o supuestos menoscabos ocasionados como consecuencia de la utilización de productos, accesorios, software y/o servicio técnico no realizado o proporcionado por Suunto;
  4. las baterías no recargables.
Suunto no garantiza un funcionamiento del Producto o los accesorios sin interrupciones o errores repentinos, ni tampoco que el Producto o los accesorios funcionen con cualquier otro elemento de hardware o software proporcionado por un tercero.
La presente Garantía limitada internacional no será de aplicación en caso de que:
  1. el Producto o el accesorio haya sido abierto más allá del uso para el que fue concebido;
  2. el Producto o el accesorio haya sido reparado utilizando recambios no autorizados; o bien, modificado o reparado por un centro de servicio no autorizado;
  3. a criterio de Suunto, el número de serie del Producto o el accesorio haya sido eliminado o alterado de cualquier otra forma, haya devenido ilegible o
  4. haya sido expuesto a productos químicos, incluidos (entre otros) los protectores solares o los repelentes de mosquitos.
Acceso al servicio de garantía de Suunto
Para acceder al servicio de garantía de Suunto, es necesario presentar la prueba de compra. Asimismo, usted deberá registrar su producto en línea en www.suunto.com/mysuunto para recibir servicios de garantía internacional en cualquier país. Para obtener instrucciones acerca de cómo acceder al servicio de garantía, visite www.suunto.com/warranty, póngase en contacto con su distribuidor autorizado Suunto o llame al Centro de contacto de Suunto.
Limitación de responsabilidad
La presente Garantía limitada internacional constituye su única garantía, en sustitución de cualquier otra garantía, expresa o implícita, y en todo caso dentro de los límites de la legislación aplicable. Suunto no se hace responsable de los daños especiales, accidentales, punitorios o consecuentes, incluidos, a título meramente enunciativo pero no limitativo, pérdidas de beneficios esperados, pérdidas de datos, pérdidas de uso, costes de capital, costes de sustitución de equipamientos o instalaciones, reclamaciones de terceros, daños causados en una propiedad como consecuencia de la compra o utilización del artículo, o derivados del incumplimiento de las condiciones de la garantía, incumplimiento contractual, negligencia, agravio civil o cualquier otro supuesto legal análogo o equivalente, aun cuando Suunto tuviera conocimiento de la posibilidad de que tales daños pudieran producirse. Suunto no se hace responsable del retraso ocasionado en la prestación de los servicios cubiertos por la garantía.
GARANTÍA LIMITADA INTERNACIONAL DE SUUNTO
Suunto garantiza que, durante el Período de Garantía, según se define a continuación, Suunto o un Centro de Servicio Autorizado de Suunto, a su sola discreción, corregirá los defectos en materiales o mano de obra de forma gratuita, ya sea mediante a) reparación, o b) sustitución por un producto similar, o c) reembolso, con sujeción a los términos y condiciones de esta Garantía Limitada. La presente Garantía Limitada Internacional no cubre a) desgaste natural, b) manipulación descuidada, c) modificaciones, d) exposición a productos químicos, ni e) uso indebido. Salvo disposición en otro sentido en la legislación vigente, a) la presente Garantía Limitada Internacional es válida y aplicable independientemente del país de compra, y b) para acceder al servicio de Garantía Limitada Internacional es preciso estar registrado en www.suunto.com/mysuunto y presentar comprobante de compra. La Garantía Limitada Internacional no afecta a sus derechos legales estipulados en la legislación nacional vigente sobre la venta de bienes de consumo.
Período de Garantía
Garantía Limitada Internacional de por vida:
Aplicable a las brújulas Suunto A, M, MC, MB y Clipper.
El Período de Garantía Internacional se entiende limitado hasta el momento en el que el producto pierda su capacidad para el uso normal debido al desgaste natural.
Garantía Limitada Internacional de 2 años:
Aplicable a las brújulas Suunto AIM, Arrow, Orca-Pioneer y KB.
El Período de Garantía Internacional es de dos (2) años a partir de la fecha de compra original.
LA PRESENTE GARANTÍA CONSTITUYE SU ÚNICA GARANTÍA, EN SUSTITUCIÓN DE CUALESQUIERA OTRAS EXPRESAS O IMPLÍCITAS Y, EN TODO CASO, DENTRO DE LOS LÍMITES DE LA LEGISLACIÓN NACIONAL APLICABLE. SUUNTO NO SE HACE RESPONSABLE DE DAÑOS ESPECIALES, INCIDENTALES, PUNITIVOS NI INDIRECTOS. SUUNTO NO SE HACE RESPONSABLE DE RETRASOS EN LA PRESTACIÓN DE LOS SERVICIOS CUBIERTOS POR LA GARANTÍA.
Solicita la reparación de tu producto Suunto mediante nuestra solicitud de reparación en línea. Amplía la pestaña de solicitud de reparación en línea más abajo para comprobar la disponibilidad del servicio en tu país.
Si no aparece tu país, o si tienes una brújula o instrumento de precisión, puedes encontrar tu centro de asistencia más cercano utilizando el buscador de distribuidores Suunto. Simplemente, selecciona el centro de asistencia y la categoría de productos.
Nuestra solicitud de asistencia online está disponible en los países enumerados a continuación. Si no aparece tu país, o si tienes una brújula o instrumento de precisión, puedes encontrar tu centro de asistencia más cercano utilizando el buscador de distribuidores Suunto. Simplemente, selecciona el centro de asistencia y la categoría de productos.
IMPORTANTE:
La reparación se realiza en aproximadamente siete días laborables. Si el producto no está en garantía, te enviaremos un presupuesto antes de comenzar la reparación. Si no aceptas este presupuesto, te devolveremos el producto y te cobraremos un importe fijo en concepto de análisis y transporte, que puede cambiar entre países.
Instrucciones para completar la solicitud de asistencia online:
  • 1. Necesitas una dirección válida de correo electrónico, el n.º de serie de tu producto y acceso a una impresora.
  • 2. Selecciona tu país en la lista.
  • 3. Rellena la información obligatoria. Los documentos para el envío se crean automáticamente para que los imprimas. Guárdalos con el producto que nos vas a enviar.
  • 4. Cuando recibas la confirmación, llama a la empresa de mensajería con el número de teléfono que te indicamos para que recojan tu producto.
  • 5. No envíes con el producto las guías de usuario, manuales de instrucciones ni paquetes de venta. No podremos devolvértelos.
  • 6. Si la solución no queda cubierta por la garantía, te remitiremos los detalles del pago por correo electrónico. Puedes hacer el pago de forma segura mediante PayPal.
  • 7. En cuanto el producto esté reparado, te lo remitiremos a la dirección que indicaste al rellenar la solicitud de asistencia.
Australia
Austria
Bélgica
Bulgaria
Croacia
Chipre
República Checa
Dinamarca
Estonia
Finlandia
Francia
Alemania
Grecia
Hungría
Irlanda
Italia
Letonia
Lituania
Luxemburgo
Malasia
Malta
Países Bajos
Nueva Zelanda
Noruega
Polonia
Portugal
Rumanía
Singapur
Eslovaquia
Eslovenia
España
Suecia
Suiza
Reino Unido
Estados Unidos
Suunto tiene una amplia red de centros de servicio autorizados en distintos países para ayudarle con todas sus necesidades de reparación y mantenimiento. Puede encontrar su centro de servicio más cercano utilizando el buscador de distribuidores Suunto. Simplemente seleccione el centro de servicio y la categoría de productos.
Además, puede contactar con Asistencia al cliente de Suunto para encontrar la mejor forma de reparar su producto.
