Share
REF SS014443010 / Este producto se ha dejado de fabricar
Suunto Core Alu Alu
Essential outdoor functions in an aluminium case, aluminium strap
Cargando precio e información sobre existencias
Every great adventure starts from within. From a drive to seek out new places and discover new experiences. Your passion is our inspiration. Suunto Core is the essential outdoor watch with a pioneering spirit designed to bring out the explorer in you.
The award-winning Suunto Core gathers a range of data to help you navigate your way through the wilder parts of the world.
Altimeter
The altimeter features a range up to 9000 m (29 500 ft). It is ideally suited for all activities where knowing your altitude and ascent and descent rates is essential. The Core altimeter sports an altitude difference measurement that allows you to track your progress in terms of altitude climbed. The log recorder stores all your movements in altitude between the start and stop times, so you can re-live your trip at home - view graphs of changes in altitude during your treks, find out how much you climbed, the duration of ascents and descents, average ascent and descent speed and more.
Barometer
Suunto Core displays the current sea level pressure as a detailed graph, showing recording of the last 24 hours with a recording interval of 30 minutes. The weather trend indicator is a useful feature providing quick reference to check upcoming weather conditions. The storm alarm notifies you of a sudden drop in air pressure, which may be related to worsening weather conditions.
Automatic Alti/Baro switch
Suunto Core sports an Automatic Alti/Baro switch, a smart feature that senses your movement or lack thereof, switching between altimeter and barometer accordingly. When you’re climbing, it records changes in elevation. And when you stop to rest, it records changes in barometric pressure. A drop in air pressure while you’re sleeping under the stars will be recorded for what it really is: a change in barometric pressure, not altitude
Compass
The digital compass displays the cardinal or half-cardinal point and the North. The declination adjustment function allows you to correct the difference between the true North and magnetic North. You can also set it to track a certain bearing, which helps you follow a chosen direction in the terrain. The compass features a rotating bezel for traditional use (most variants), or a one-touch function that allows you to sight lock and follow a bearing.
Depth meter
Intended for snorkeling, the Suunto Core depth meter provides information on current depth and the maximum depth reached during your snorkeling dive. The maximum depth of the device is 10 m (32,8 ft).
Watch
Watch functions include time, dual time, date, alarm, sports chronograph, countdown timer and predicted times for sunrise and sunset for over 400 locations worldwide.
Suunto Core is available in a range of styles and materials.
LO MÁS DESTACADO DEL PRODUCTO
  • Altímetro, barómetro, brújula
  • Funciones de clima
  • Uso en la montaña y cualquier lugar
  • Altimeter with altitude log memory and altitude difference measurement
  • Barometer with storm alarm and weather trend indicator
  • Automatic Alti / Baro switch
  • Compass with semi automatic calibration and a digital bearing
  • Depth meter
  • Multiple watch, date and alarm functions with dual time and countdown timer
  • Sunrise/Sunset times for over 400 locations worldwide
  • Digital thermometer
  • Menu based user interface in English, German, French and Spanish
  • Available in a range of styles
  • Accessory straps
  • User-replaceable battery
Medidas 49,1  x  49,1  x  14,5  mm
Peso 102 g
Medidas 1,93  x  1,93 x  0,57 "
Peso 3,6 oz
Material del bisel: Aluminio
Material de la lente: Cristal mineral
Material de la carcasa: Compuesto
Material de la correa: Silicona
Suunto Core Alu Alu – Especificaciones técnicas
Peso 102 g
Sumergibilidad 30 m (según ISO 6425)
Duración de la pila en modo Time 12 meses
Tipo de pila CR2032
Pila sustituible por el usuario
Hora, fecha
Despertador próximamente en Spartan
Esta característica se introducirá más adelante en los relojes Suunto Spartan; sigue las actualizaciones en www.suunto.com/spartangetsstronger.
1 alarma diaria
Hora dual
Temporizador de cuenta atrás
Cronómetro
Idiomas EN, DE, ES, FR
Luz de fondo electroluminiscente
Luz de fondo configurable activación: 1 botón, todos los botones
Bloqueo de botones
Tipo de pantalla matricial
Indicador de batería indicador de batería baja
Unidades métricas e imperiales
Brújula digital
Escala de dirección grados
Aguja indicador de norte
Fijación de rumbo con indicador de orientación
Exactitud de la brújula
Resolución de brújula
Temperatura de funcionamiento De -20° C a +60° C/de -5° F a +140° F
Temperatura de almacenamiento De -30° C a +60° C/de -22° F a +140° F
FUNCIONES DE BUCÉO
Profundímetro para inmersión con snorkel 10 m
FUNCIONES PARA AIRE LIBRE
Altitud barométrica
Gráfica de altitud
Ascenso/descenso total basado en presión atmosférica
Perfil automático alti/baro
Diferencia de altitud
Frecuencia de grabación de registros 1, 5, 10, 30, 60 s
Resolución 1 m
Intervalo -500 - 9000 m
Presión a nivel del mar
Gráfica de presión a nivel del mar
Indicador de tendencia del clima
Temperatura
Intervalo de indicación de temperatura De -20° C a +60° C/de -4° F a +140° F
Hora de amanecer/puesta de sol i
Perfil automático alti/baro próximamente en Spartan
Alarma de tormenta
Resolución de presión 1 hPa/0,03 inHg
Resolución de temperatura
Máx. duración de registro de clima 7 días
GUÍAS DEL USUARIO
Las guías del usuario proporcionan un resumen completo de las funciones del producto, cómo utilizarlas y las normas generales de uso y especificaciones técnicas.
Usa Adobe Reader para verlas.
VÍDEOS A MODO DE GUÍA
Te dan consejos útiles e instrucciones detalladas y te permiten descubrir nuevas funciones y cómo utilizan otras personas los productos Suunto.
Mira nuestros vídeos.
LOCALIZADOR DE DISTRIBUIDORES Y SERVICIOS TÉCNICOS
Busca un servicio técnico autorizado o un distribuidor Suunto en tu zona.
Abrir el localizador de distribuidores
ESCRÍBENOS
Puedes obtener asistencia en chino, inglés, finlandés, francés, alemán, italiano, japonés, ruso, español o sueco.
1. Contacta a través de MySuunto.
INICIAR SESIÓN
REGISTRARME
¿Qué es MySuunto?
2. O bien puedes dejar tu mensaje a continuación (no es preciso registrarse)
HAZ UNA CONSULTA
Trataremos de responder en los próximos días. Sin embargo, si necesitas ayuda urgente, ponte en contacto por teléfono.
LLÁMANOS
Asistencia disponible en inglés 24/7.
Asistencia disponible de las 9:00 a las 17:00 en el horario local en días laborales:
Si tu país no aparece en la lista, las llamadas tendrán el coste establecido por tu compañía telefónica para llamadas internacionales. Tu llamada puede ser controlada o grabada con fines de control de calidad o formación.
GARANTÍA INTERNACIONAL LIMITADA SUUNTO
Suunto garantiza que, durante el periodo de vigencia de la garantía, Suunto o un Centro de servicio autorizado Suunto (en adelante, "Centro de servicio") subsanarán, de la forma que consideren oportuna y sin cargo alguno, cualesquiera desperfectos de materiales o fabricación ya sea mediante a) la reparación, b) la sustitución, o c) el reembolso, con sujeción a los términos y condiciones de la presente Garantía limitada internacional. La presente Garantía limitada internacional será válida y exigible independientemente del país de compra. La Garantía limitada internacional no afecta a sus derechos legales, otorgados por la legislación nacional vigente aplicable a la venta de bienes de consumo.
Periodo de garantía
El periodo de garantía limitada internacional se computará a partir de la fecha de compra original.
El periodo de garantía es de dos (2) años para productos y transmisores de buceo, salvo que se estipule lo contrario.
El periodo de garantía es de un (1) año para accesorios, incluidos, entre otros, los sensores inalámbricos, cargadores, cables, baterías recargables, correas, brazaletes y latiguillos.
Exclusiones y limitaciones
Esta Garantía limitada internacional no cubre:
  1. a) el desgaste normal como arañazos, abrasiones o alteraciones en el color y/o en el material de las correas no metálicas, b) los defectos causados por un manejo poco cuidadoso, ni c) los defectos o daños causados por un uso inadecuado o contrario al recomendado o para el que fue concebido, o por accidentes como caídas o golpes fuertes;
  2. los materiales impresos ni el embalaje;
  3. los daños o supuestos menoscabos ocasionados como consecuencia de la utilización de productos, accesorios, software y/o mantenimiento no realizado o proporcionado por Suunto;
  4. las baterías no recargables.
Suunto no garantiza el funcionamiento del Producto o los accesorios sin interrupciones o errores repentinos en los mismos, ni tampoco que el Producto o los accesorios funcionen con cualquier otro elemento de hardware o software proporcionado por un tercero.
La presente Garantía limitada internacional no será de aplicación en caso de que el Producto o el accesorio:
  1. haya sido abierto más allá del uso para el que fue concebido;
  2. haya sido reparado utilizando recambios no autorizados; o bien, modificado o reparado por un centro de servicio no autorizado;
  3. cuando, a criterio de Suunto, el número de serie haya sido eliminado, alterado de cualquier otra forma, o hubiere devenido ilegible, o bien
  4. hubiere sido expuesto a productos químicos, incluidos (entre otros) los protectores solares o los repelentes de mosquitos.
Acceso al servicio de garantía de Suunto
Para acceder al servicio de garantía de Suunto, es necesario presentar la prueba de compra. Asimismo, usted deberá registrar su producto en línea en www.suunto.com/mysuunto para recibir servicios de garantía internacional en cualquier país. Para obtener instrucciones acerca de cómo acceder al servicio de garantía, visite www.suunto.com/warranty, póngase en contacto con su distribuidor autorizado Suunto, o llame al Centro de contacto de Suunto.
Limitación de responsabilidades
La presente Garantía limitada internacional constituye su única garantía, en sustitución de cualesquiera otras garantías, expresas o implícitas, y en todo caso dentro de los límites de la legislación aplicable. Suunto no se hace responsable de los daños especiales, accidentales, punitorios o consecuentes, incluidos, a título meramente enunciativo pero no limitativo, las pérdidas de beneficios esperados, pérdidas de datos, pérdidas de uso, costes de capital, costes de sustitución de equipamientos o instalaciones, reclamaciones de terceros, cualquier daño causado en una propiedad como consecuencia de la compra o utilización del artículo, o derivado del incumplimiento de las condiciones de la garantía, incumplimiento contractual, negligencia, ilícito civil o cualquier otra figura jurídica análoga o equivalente, aún cuando Suunto tuviera conocimiento de la posibilidad de que tales daños pudieran producirse. Suunto no se hace responsable del retraso ocasionado en la prestación de los servicios cubiertos por la garantía.
GARANTÍA LIMITADA DE SUUNTO
Suunto garantiza que, durante el período de garantía de Suunto y a su sola discreción, pondrá remedio a los defectos en materiales o mano de obra de forma gratuita, ya sea mediante a) reparación, o b) sustitución por un producto similar, o c) reembolso, sujeto a los términos y condiciones de esta Garantía Limitada. Esta Garantía Limitada no cubre a) el desgaste, b) la manipulación descuidada, c) modificaciones, d) la exposición a productos químicos, o e) el uso indebido. A menos que la ley vigente local disponga otra cosa, a) esta Garantía Limitada solo es válida en el país de compra y b) se deberá presentar la prueba de compra al solicitar los servicios de garantía.
Período de Garantía
Garantía limitada de por vida:
Aplicable a la brújulas A, M, MC, MB y Clipper de Suunto.
El periodo de garantía se limita hasta el momento en que el producto ya no está razonablemente utilizable debido al desgaste.
Garantía limitada de 2 años:
Aplicable a las brújulas Arrow, Orca-Pioneer y KB de Suunto.
El período de garantía limitada es de dos (2) años a partir de la fecha de compra original.
EN LA MEDIDA MÁXIMA PERMITIDA POR LA LEGISLACIÓN NACIONAL APLICABLE, ESTA GARANTÍA LIMITADA ES ÚNICA Y EXCLUSIVA, Y PREVALECE SOBRE CUALQUIER OTRA GARANTÍA, EXPRESA O IMPLÍCITA. SUUNTO NO SE HACE RESPONSABLE DE DAÑOS ESPECIALES, INCIDENTALES, PUNITIVOS NI INDIRECTOS. SUUNTO NO SE HACE RESPONSABLE DE RETRASOS EN LA PRESTACIÓN DEL SERVICIO DE GARANTÍA.
© Suunto Oy 12/2013. Todos los derechos reservados.
Suunto es una marca comercial registrada de Suunto Oy
Solicita la reparación de tu producto Suunto mediante nuestra solicitud de reparación en línea. Amplía la pestaña de solicitud de reparación en línea más abajo para comprobar la disponibilidad del servicio en tu país.
Si no aparece tu país, o si tienes una brújula o instrumento de precisión, puedes encontrar tu centro de asistencia más cercano utilizando el buscador de distribuidores Suunto. Simplemente, selecciona el centro de asistencia y la categoría de productos.
Nuestra solicitud de asistencia online está disponible en los países enumerados a continuación. Si no aparece tu país, o si tienes una brújula o instrumento de precisión, puedes encontrar tu centro de asistencia más cercano utilizando el buscador de distribuidores Suunto. Simplemente, selecciona el centro de asistencia y la categoría de productos.
IMPORTANTE:
La reparación se realiza en aproximadamente siete días laborables. Si el producto no está en garantía, te enviaremos un presupuesto antes de comenzar la reparación. Si no aceptas este presupuesto, te devolveremos el producto y te cobraremos un importe fijo en concepto de análisis y transporte, que puede cambiar entre países.
Instrucciones para completar la solicitud de asistencia online:
  • 1. Necesitas una dirección válida de correo electrónico, el n.º de serie de tu producto y acceso a una impresora.
  • 2. Selecciona tu país en la lista.
  • 3. Rellena la información obligatoria. Los documentos para el envío se crean automáticamente para que los imprimas. Guárdalos con el producto que nos vas a enviar.
  • 4. Cuando recibas la confirmación, llama a la empresa de mensajería con el número de teléfono que te indicamos para que recojan tu producto.
  • 5. No envíes con el producto las guías de usuario, manuales de instrucciones ni paquetes de venta. No podremos devolvértelos.
  • 6. Si la solución no queda cubierta por la garantía, te remitiremos los detalles del pago por correo electrónico. Puedes hacer el pago de forma segura mediante PayPal.
  • 7. En cuanto el producto esté reparado, te lo remitiremos a la dirección que indicaste al rellenar la solicitud de asistencia.
Australia
Austria
Bélgica
Bulgaria
Croacia
Chipre
República Checa
Dinamarca
Estonia
Finlandia
Francia
Alemania
Grecia
Hungría
Irlanda
Italia
Letonia
Lituania
Luxemburgo
Malasia
Malta
Países Bajos
Nueva Zelanda
Noruega
Polonia
Portugal
Rumanía
Singapur
Eslovaquia
Eslovenia
España
Suecia
Suiza
Reino Unido
Estados Unidos
Suunto tiene una amplia red de centros de servicio autorizados en distintos países para ayudarle con todas sus necesidades de reparación y mantenimiento. Puede encontrar su centro de servicio más cercano utilizando el buscador de distribuidores Suunto. Simplemente seleccione el centro de servicio y la categoría de productos.
Además, puede contactar con Asistencia al cliente de Suunto para encontrar la mejor forma de reparar su producto.
