Share
REF SS014587000 / Ce produit n'est plus fabriqué
Suunto Cobra3
Advanced air-integrated dive computer with electronic 3D compass
Chargement des informations sur les prix et stocks
Suunto Cobra3 is an all-in-one console-mounted dive computer. It features air-integration, an electronic 3D compass, an easy-to-read matrix display, and simplified four-button operation.
Air integration
Suunto Cobra3 monitors and displays your tank pressure, tracks your rate of air consumption, and continuously calculates your remaining air time. It also provides visual and audible alarms for depth and pressure and warns you when you're running low on air.
Clear navigation
Suunto Cobra3 features a unique electronic 3D compass that can be tilted up to 45 degrees in any direction, making it easier to read the figures clearly and accurately under water.
Effortless operation
The easy-to-read dot matrix display and electro-luminescent backlight mean all your dive-critical information – including bearing, tank pressure, depth, and dive time – will all be shown clearly. And with the simplified four-button operation, the computer is easy to operate even when wearing gloves.
Multi-mode versatility
With its Nitrox, Air, and Gauge modes and gas-switching capabilities, Suunto Cobra3 delivers everything you need to maximize bottom time and make the most of every dive. When using enriched air, Suunto Cobra3 can be programmed for nitrox mixtures between 21% and 100% oxygen. You can also adjust oxygen partial pressure between 0.5 and 1.6 bar. In Gauge mode, it can also be used as a depth gauge and timer with profile memory.
Flexible decompression
Using the Suunto Deep Stop RGBM algorithm, Suunto Cobra3 enables continuous decompression for optimal ascent time. For deeper dives, the Deep Stop option adds further protection with a series of deep stops between your maximum depth and ceiling.
When in Nitrox mode, you can accelerate decompression by switching to a gas mix with a higher oxygen percentage. With Suunto Cobra3 it's quick and easy to switch between enabled gas mixes while diving.
Plan and review
You can test upcoming dives and view no-decompression and decompression time data for different depths before getting in the water with the built-in dive simulator. When the dive is over, get detailed graphical logs and dive data on your computer using Suunto DM4 software.
L'ESSENTIEL
  • Modes air, nitrox et profondimètre
  • Boussole 3D
  • Suunto RGBM
  • Écran matriciel facile à lire
  • Air integrated for tank pressure information
  • Tiltable electronic 3D compass to keep you on course
  • User-friendly design featuring easy-to-read matrix display and simplified four-button operation
  • Three dive modes and gas-switching capability for a range of dive situations
  • Continuous decompression with the Suunto RGBM algorithm
  • Built-in dive simulator for planning upcoming dives
  • Optional computer interface for detailed graphical logbooks and dive data analysis
Dimensions 73  x  165  x  35  mm
Poids 210 g
Dimensions 2,87  x  6,5 x  1,38 "
Poids 7,41 oz
Matériau de la lunette : Composite
Matériau du verre : Acrylique
Matériau du boîtier : Composite
Matériau du bracelet : Élastomère
Correction de la déclinaison oui
Suunto Cobra3 – Caractéristiques techniques
Poids 210 g / 7,41 oz
Étanchéité 100 m (ISO 13319)
Durée de vie de la pile/batterie en mode heure 3 ans
Durée de vie de la pile/batterie 100 plongées/an 1,5 an
Type de batterie/pile CR 2450
Pile remplaçable par l'utilisateur
Heure, date
Réveil 1 alarme quotidienne
Langues EN
Rétroéclairage électroluminescent
Rétroéclairage configurable durée : 5, 10, 20, 30, 60 s
Type d'affichage matrice
Résolution d'affichage 49 x 22
Indicateur de batterie/pile témoin de batterie faible
Unités métriques et impériales
Transfert de données Câble USB (en option)
Compatible avec DM5
Compatible avec Suunto Movescount avec le logiciel DM5
Boussole numérique
Compensation de l'inclinaison jusqu'à 45°
Échelle de direction degrés
Aiguille rose des vents
Utilisable sous toutes les latitudes
Verrouillage de relèvement avec indicateur d'orientation
Précision de la boussole 10°
Résolution de la boussole
Température de fonctionnement 0 à +40 °C / +32 à +104 °F
Température de stockage -20 à +50 °C / -4 à +122 °F
FONCTIONS DE PLONGÉE
Profondeur d'utilisation maximum (EN 13319) 100 m
Nitrox (et air)
Jauge
Temps de plongée 0 à 999 min
Temps en surface 0 à 99 h 59 min
Temps d'attente avant un vol
Palier de sécurité
Palier profond
Affichage du temps de remontée 0 à 99 min (- - après 99)
Calcul CNS/OTU (OLF)
Gestion de l'air par flexible
Modèle de décompression SUUNTO RGBM
Réglage personnel 0 à 2
Réglage de l'altitude 0 à 300 m / 300 à 1500 m / 1500 à 3000 m
Gaz jusqu'à 2 gaz (oxygène 21 à 99 %)
pO2 maxi. gaz 1.2 - 1.6
Changement de gaz
Planificateurs de temps sans décompression
Mémoire du journal ~42 h (intervalle d'échantillonnage de 20 s)
Signets du journal
Intervalles d'échantillonnage du journal 1, 20, 10, 30, 60 s
Historique de plongée durée de vie
Temps de plongée
Profondeur maximum
Pression des bouteilles
pO2 élevée (hyperoxique)
Remontée trop rapide
Violation de plafond de décompression
CNS/OTU (OLF) 80 % / 100 %
Changer de gaz (un meilleur gaz est disponible)
FONCTIONS DÉDIÉES AU PLEIN AIR
Plage d'affichage de température -20 à +50 °C (+/- 2 °C) / -9 à +122 °F (+/- 3,6 °F)
Résolution de température 1 °C / 1,5 °F
Température
GUIDES D'UTILISATION
Les guides d'utilisation procurent une vue d'ensemble complète des fonctionnalités et des caractéristiques techniques des produits, expliquent comment les utiliser et donnent des conseils de manipulation.
Utilisez Adobe Reader pour afficher les documents.
VIDÉOS EXPLICATIVES
Explorez les nouvelles fonctions, recevez des astuces pratiques, consultez les instructions pas-à-pas et découvrez comment les autres utilisent leurs produits Suunto.
Consultez nos vidéos.
OUTIL DE LOCALISATION DE REVENDEURS ET RÉPARATEURS
Trouvez un centre de réparation ou un revendeur Suunto agréé près de chez vous.
Ouvrir l'outil de localisation de revendeurs
Changement de la pile de l'ordinateur de plongée et de l'appareil
Suunto recommande de faire remplacer les piles des ordinateurs de plongée et d'autres appareils par un centre de réparation agréé. Vous pouvez trouver le centre de réparation le plus proche en utilisant l'outil de localisation des revendeurs Suunto - il vous suffit simplement de sélectionner un centre de réparation et la catégorie du produit. Vous pouvez également faire réparer votre produit Suunto en utilisant notre formulaire de demande de réparation en ligne. Les pays disponibles sont répertoriés dans la page de demande de réparation en ligne.
Consulter un centre de réparation agréé Suunto DM5 a les avantages suivants :
  • En plus de la pile, les joints et autres composants mécaniques déformés ou endommagés sont également remplacés.
  • Les piles de remplacement sont neuves (pleine capacité) et les pièces conformes aux spécifications de Suunto, ce qui permet de garantir que la batterie offrira l'autonomie spécifiée et que l'intégrité du produit restera intacte.
  • L'ordinateur de plongée ne peut être endommagé par une DES soudaine (décharge électrostatique), car le changement de la pile est effectué dans un environnement offrant une protection totale contre les DES.
  • Une fois l'entretien terminé, les produits sont testés afin de garantir leur bon fonctionnement et leur étanchéité totale.
  • La réparation est effectuée par du personnel formé par Suunto, à l'aide des outils adéquats et des pièces détachées Suunto d'origine garantissent le meilleur soin de votre ordinateur de plongée.
  • Les produits Suunto réparés par un centre de service agréé sont couverts par une garantie de (3) mois à partir de la date de réparation.
Planifiez et suivez vos plongées avec le logiciel Suunto DM5 – sur PC et sur MAC
Suunto DM5 vous permet de télécharger vos journaux de plongée en vue de les analyser et de transférer des plans de plongée détaillés vers votre ordinateur de plongée. Ce logiciel peut être téléchargé gratuitement. Suunto DM5 est désormais disponible en anglais, néerlandais, français, finlandais, allemand, japonais, coréen, espagnol et chinois. La configuration système minimale est la suivante : Mac 10.7 ou Windows XP. En savoir plus sur le DM5.
L'utilisation de Suunto DM5 offre les avantages suivants :
  • Grâce au planificateur graphique de plongée Suunto DM5, vous pouvez très facilement créer des profils de plongée, gérer des mélanges gazeux et des plans de secours. Lorsque vous le désirez, transférez vos mélanges gazeux et autres informations essentielles planifiées vers votre ordinateur de plongée (certains modèles uniquement). Vous pouvez également imprimer les instructions liées aux mélanges gazeux depuis le logiciel DM5.
  • Une fois la plongée terminée, vous pouvez transférer vos journaux de plongée vers le logiciel DM5. Vos plongées sont stockées sur le journal où il est possible de les consulter, les analyser et les organiser par date, mode et équipement. La fonction de tag permet de facilement marquer vos plongées et de les organiser selon vos préférences. De plus, il est possible de sélectionner plusieurs plongées afin de les comparer.
  • Vous pouvez également enregistrer vos plongées dans Suunto Movescount et les partager avec vos amis.
Téléchargez gratuitement le logiciel Suunto DM5 à ces adresses :
POUR WINDOWS
POUR MAC
ÉCRIVEZ-NOUS
Obtenez de l'aide en chinois, anglais, finnois, français, allemand, italien, japonais, russe, espagnol ou suédois.
1. Contactez-nous via MySuunto
SE CONNECTER
ENREGISTRER
Qu'est-ce que MySuunto ?
2. Ou laissez-nous votre message ci-dessous (pas d'inscription nécessaire)
ENVOYER UNE QUESTION
Nous ferons de notre mieux pour vous répondre dans les prochains jours. Toutefois, si vous avez besoin d'aide en urgence, téléphonez-nous.
TÉLÉPHONEZ-NOUS
Assistance en anglais disponible 24 h sur 24, 7 jours sur 7.
Assistance disponible de 9h00 à 17h00 heure locale les jours ouvrés :
Si votre pays n'apparaît pas dans la liste, les appels vous seront facturés au tarif international en vigueur chez votre opérateur. Votre appel pourra être enregistré ou écouté à des fins de contrôle qualité et de formation.
GARANTIE LIMITÉE INTERNATIONALE SUUNTO
Pendant la période de garantie, Suunto ou un centre de service après-vente agréé Suunto (appelé ci-après centre de service) s'engage à sa seule discrétion à remédier sans frais aux défauts de matériau ou de fabrication, soit a) en réparant, soit b) en remplaçant ou encore c) en remboursant le produit, conformément aux conditions générales de la présente garantie limitée internationale. La présente garantie limitée internationale est valable et exécutoire quel que soit le pays d'achat. La garantie limitée internationale n'a pas d'incidence sur les droits qui vous sont conférés par la législation nationale applicable à la vente de biens de consommation.
Période de garantie
La période de garantie limitée internationale prend effet à la date de l'achat initial au détail.
La période de garantie est de deux (2) ans pour les produits et transmetteurs de plongée, sauf indication contraire.
La période de garantie est d'un (1) an pour les accessoires, notamment et de manière non limitative pour les capteurs sans fil, chargeurs, câbles, batteries rechargeables, sangles, bracelets et flexibles.
Pour toutes les montres Suunto Spartan achetées en 2016, la période de garantie a été étendue à trois (3) ans.
Exclusions et limitations
La présente garantie limitée internationale ne couvre pas :
  1. a) l'usure normale telle que les rayures, l'abrasion, la décoloration ou la déformation du matériau des bracelets non métalliques, b) les défauts résultant d'une manipulation brutale ou c) les défauts ou dommages résultant d'une utilisation contraire à celle prévue ou recommandée, un entretien inapproprié, une négligence et les accidents comme les chutes ou l'écrasement ;
  2. les documents imprimés et l'emballage ;
  3. les défauts ou prétendus défauts consécutifs à l'utilisation avec tout autre produit, accessoire, logiciel ou service non fabriqué ou fourni par Suunto ;
  4. les piles non rechargeables.
Suunto ne garantit pas que le fonctionnement du produit ou de l'accessoire sera exempt d'erreurs ou d'interruptions, ni que le produit ou l'accessoire fonctionnera avec des logiciels ou des matériels fournis par un tiers.
La présente garantie limitée internationale n'est pas exécutoire si le produit ou l'accessoire :
  1. a été ouvert hors de l'utilisation prévue ;
  2. a été réparé avec des pièces de rechange non autorisées ; modifié ou réparé par un centre de service non autorisé ;
  3. a vu son numéro de série supprimé, altéré ou rendu illisible de quelque manière que ce soit, ceci étant laissé à la seule appréciation de Suunto ;
  4. a été exposé à des produits chimiques, y compris et de manière non limitative par des crèmes solaires et anti-moustiques.
Accès au service de garantie Suunto
Vous devez fournir la preuve d'achat du produit pour accéder au service de garantie Suunto. Vous devez également enregistrer votre produit en ligne sur www.suunto.com/mysuunto pour pouvoir bénéficier des services de la garantie internationale dans le monde entier. Pour savoir comment bénéficier du service de garantie, rendez-vous sur www.suunto.com/warranty, adressez-vous à votre détaillant local agréé Suunto ou appelez le Centre de contact Suunto.
Limitation de responsabilité
Dans les limites autorisées par la législation applicable, la présente garantie limitée internationale constitue votre seul et exclusif recours et remplace toute autre garantie, formelle ou implicite. Suunto ne saurait être tenue responsable des dommages spéciaux, indirects, exemplaires ou accessoires, y compris et de manière non limitative la perte de bénéfices anticipés, la perte de données, la perte d'utilisation, le coût du capital, le coût de tout équipement ou moyen de substitution, les plaintes déposées par des tiers, les dommages matériels résultant de l'achat ou de l'utilisation du produit ou découlant du non-respect de la garantie, du non-respect du contrat, d'une négligence, d'un tort strict ou de toute théorie légale ou équitable, même si Suunto avait connaissance de l'éventualité de tels dommages. Suunto ne saurait être tenue responsable des retards liés à l'exécution du service de garantie.
La société Suunto s'engage à sa seule et entière discrétion à remédier sans frais, pendant la période de garantie, aux vices de matériau ou de fabrication du produit, par ses propres moyens ou par l'intermédiaire d'un centre de service agréé Suunto, soit a) en le réparant, soit b) en le remplaçant par un produit similaire, soit encore c) en le remboursant, sous réserve des conditions générales de la présente garantie limitée internationale. La présente garantie limitée internationale ne couvre pas a) l'usure normale, b) les manipulations brutales, c) les modifications, d) l'exposition à des produits chimiques ou e) une mauvaise utilisation. Sauf dispositions contraires stipulées dans la législation en vigueur, a) la présente garantie limitée internationale est valable et exécutoire quel que soit le pays d'achat et b) pour bénéficier des prestations de la garantie limitée internationale, l'inscription sur le site www.suunto.com/mysuunto et une preuve d'achat sont exigées. La présente garantie limitée internationale n'a pas d'incidence sur les droits qui vous sont conférés par la législation en vigueur en matière de vente de biens de consommation.
Période de garantie
Garantie internationale limitée à vie :
Applicable aux boussoles Suunto A, M, MC, MB et Clipper.
La période de garantie internationale est limitée à la durée raisonnable à l'issue de laquelle le produit n'est plus raisonnablement utilisable en raison de son usure normale.
Garantie limitée internationale de 2 ans :
Applicable aux boussoles Suunto AIM, Arrow, Orca-Pioneer et KB.
La période de garantie limitée internationale est de deux (2) ans à compter de la date de l'achat initial au détail.
DANS LES LIMITES AUTORISÉES PAR LES LOIS EN VIGUEUR, LA PRÉSENTE GARANTIE LIMITÉE INTERNATIONALE CONSTITUE VOTRE SEUL ET EXCLUSIF RECOURS ET REMPLACE TOUTE AUTRE GARANTIE, EXPRESSE OU IMPLICITE. SUUNTO NE SAURAIT ÊTRE TENUE RESPONSABLE DES DOMMAGES SPÉCIAUX, INDIRECTS, EXEMPLAIRES OU ACCESSOIRES. SUUNTO NE SAURAIT ÊTRE TENUE RESPONSABLE DES RETARDS LIÉS À L'EXÉCUTION DES PRESTATIONS DE GARANTIE.
Faites réparer votre produit Suunto avec notre demande de réparation en ligne. Ouvrez l'onglet de la demande de réparation en ligne ci-dessous pour vérifier la disponibilité du service dans votre pays.
Si votre pays ne figure pas dans la liste, ou si votre demande de réparation concerne une boussole ou un instrument de précision, vous trouverez le centre de réparation le plus proche de chez vous en utilisant l' Outil de localisation des revendeurs Suunto  – il vous suffit de sélectionner Centre de réparation et la catégorie de votre produit.
Notre demande de réparation en ligne est disponible pour les pays répertoriés ci-dessous. Si votre pays ne figure pas dans la liste, ou si votre demande de réparation concerne une boussole ou un instrument de précision, vous trouverez le centre de réparation le plus proche de chez vous en utilisant l'Outil de localisation des revendeurs Suunto – il vous suffit de sélectionner Centre de réparation et la catégorie de votre produit.
IMPORTANT :
La réparation sera effectuée en sept jours ouvrés environ. Si le produit n'est pas sous garantie, nous vous enverrons un devis avant d'entreprendre la réparation. Si vous refusez notre devis, nous vous renverrons le produit et nous vous facturerons un montant fixe pour l'analyse et les frais de port. Ce montant est susceptible de varier en fonction du pays dans lequel vous résidez.
Instructions à suivre pour remplir la demande de réparation en ligne :
  • 1. Vous devez disposer d'une adresse électronique valide, du numéro de série de votre produit et d'un accès à une imprimante.
  • 2. Choisissez votre pays dans la liste.
  • 3. Saisissez les renseignements demandés. Les documents d'expédition sont automatiquement créés ; vous n'avez plus qu'à les imprimer. Joignez-les au produit que vous nous envoyez.
  • 4. Lorsque vous recevrez la confirmation, appelez la société de messagerie au numéro indiqué afin de convenir d'un rendez-vous pour l'enlèvement du produit.
  • 5. N'envoyez pas les guides d'utilisation, notices ou autres articles vendus en coffret avec votre produit. Nous ne pourrions pas vous les rendre.
  • 6. Si la résolution du problème n'est pas couverte par la garantie, nous nous enverrons par e-mail les modalités de paiement. Les paiements s'effectuent de manière sécurisée par PayPal.
  • 7. Dès que le produit sera réparé, il sera réexpédié à l'adresse que vous aurez indiquée dans votre demande de réparation.
Australie
Autriche
Belgique
Bulgarie
Croatie
Chypre
République tchèque
Danemark
Estonie
Finlande
France
Allemagne
Grèce
Hongrie
Irlande
Italie
Lettonie
Lituanie
Luxembourg
Malaisie
Malte
Pays-Bas
Nouvelle-Zélande
Norvège
Pologne
Portugal
Roumanie
Singapour
Slovaquie
Slovénie
Espagne
Suède
Suisse
Royaume-Uni
États-Unis
Suunto dispose d'un large réseau de centres de service agréés dans plusieurs pays afin de répondre à vos besoins en matière de réparation ou de maintenance. Découvrez le centre de service le plus proche en utilisant l'outil de localisation des revendeurs Suunto – sélectionnez simplement l'option centre de service et la catégorie du produit.
Vous pouvez également contacter l'Assistance client Suunto pour connaître la meilleure façon de dépanner votre produit.
