Share
REF SS014443010 / Ce produit n'est plus fabriqué
Suunto Core Alu Alu
Essential outdoor functions in an aluminium case, aluminium strap
Chargement des informations sur les prix et stocks
Every great adventure starts from within. From a drive to seek out new places and discover new experiences. Your passion is our inspiration. Suunto Core is the essential outdoor watch with a pioneering spirit designed to bring out the explorer in you.
The award-winning Suunto Core gathers a range of data to help you navigate your way through the wilder parts of the world.
Altimeter
The altimeter features a range up to 9000 m (29 500 ft). It is ideally suited for all activities where knowing your altitude and ascent and descent rates is essential. The Core altimeter sports an altitude difference measurement that allows you to track your progress in terms of altitude climbed. The log recorder stores all your movements in altitude between the start and stop times, so you can re-live your trip at home - view graphs of changes in altitude during your treks, find out how much you climbed, the duration of ascents and descents, average ascent and descent speed and more.
Barometer
Suunto Core displays the current sea level pressure as a detailed graph, showing recording of the last 24 hours with a recording interval of 30 minutes. The weather trend indicator is a useful feature providing quick reference to check upcoming weather conditions. The storm alarm notifies you of a sudden drop in air pressure, which may be related to worsening weather conditions.
Automatic Alti/Baro switch
Suunto Core sports an Automatic Alti/Baro switch, a smart feature that senses your movement or lack thereof, switching between altimeter and barometer accordingly. When you’re climbing, it records changes in elevation. And when you stop to rest, it records changes in barometric pressure. A drop in air pressure while you’re sleeping under the stars will be recorded for what it really is: a change in barometric pressure, not altitude
Compass
The digital compass displays the cardinal or half-cardinal point and the North. The declination adjustment function allows you to correct the difference between the true North and magnetic North. You can also set it to track a certain bearing, which helps you follow a chosen direction in the terrain. The compass features a rotating bezel for traditional use (most variants), or a one-touch function that allows you to sight lock and follow a bearing.
Depth meter
Intended for snorkeling, the Suunto Core depth meter provides information on current depth and the maximum depth reached during your snorkeling dive. The maximum depth of the device is 10 m (32,8 ft).
Watch
Watch functions include time, dual time, date, alarm, sports chronograph, countdown timer and predicted times for sunrise and sunset for over 400 locations worldwide.
Suunto Core is available in a range of styles and materials.
L'ESSENTIEL
  • Altimètre, baromètre, boussole
  • Fonctions météo
  • Utilisation en montagne et dans tous les environnements
  • Altimeter with altitude log memory and altitude difference measurement
  • Barometer with storm alarm and weather trend indicator
  • Automatic Alti / Baro switch
  • Compass with semi automatic calibration and a digital bearing
  • Depth meter
  • Multiple watch, date and alarm functions with dual time and countdown timer
  • Sunrise/Sunset times for over 400 locations worldwide
  • Digital thermometer
  • Menu based user interface in English, German, French and Spanish
  • Available in a range of styles
  • Accessory straps
  • User-replaceable battery
Dimensions 49,1  x  49,1  x  14,5  mm
Poids 102 g
Dimensions 1,93  x  1,93 x  0,57 "
Poids 3,6 oz
Matériau de la lunette : Aluminium
Matériau du verre : Cristal minéral
Matériau du boîtier : Composite
Matériau du bracelet : Silicone
Suunto Core Alu Alu – Caractéristiques techniques
Poids 102 g / 3,6 oz
Étanchéité 30 m (conformément à ISO 6425)
Durée de vie de la pile/batterie en mode heure 12 mois
Type de batterie/pile CR2032
Pile remplaçable par l'utilisateur
Heure, date
Réveil 1 alarme quotidienne
Deuxième heure
Compte à rebours
Chronomètre
Langues EN, DE, ES, FR
Rétroéclairage électroluminescent
Rétroéclairage configurable activation : 1 bouton, tous les boutons
Verrouillage des boutons
Type d'affichage matrice
Indicateur de batterie/pile témoin de batterie faible
Unités métriques et impériales
Boussole numérique
Échelle de direction degrés
Aiguille indicateur du nord
Verrouillage de relèvement avec indicateur d'orientation
Précision de la boussole
Résolution de la boussole
Température de fonctionnement -20 à +60 °C / -5 à +140 °F
Température de stockage -30 à +60 °C / -22 à +140 °F
FONCTIONS DE PLONGÉE
Profondimètre pour la plongée avec tuba 10 m
FONCTIONS DÉDIÉES AU PLEIN AIR
Altitude barométrique
Graphique d'altitude
Totaux des ascensions/descentes via la pression atmosphérique
Profil altimètre/baromètre automatique à venir pour Spartan
Cette fonctionnalité sera prochainement disponible pour les montres Suunto Spartan ; suivez les mises à jour sur www.suunto.com/spartangetsstronger.
Différence d'altitude
Fréquence d'enregistrement du journal 1, 5, 10, 30, 60 s
Résolution 1 m
Portée -500 à 9000 m
Pression au niveau de la mer
Graphique de pression au niveau de la mer
Indicateur de tendance météo
Température
Plage d'affichage de température -20 à +60 °C / -4 à +140 °F
Heures de lever/coucher du soleil
Alarme d'orage
Résolution de pression 1 hPa / 0,03 inHg
Résolution de température
Longueur d'enregistrement météo maxi. 7 jours
GUIDES D'UTILISATION
Les guides d'utilisation procurent une vue d'ensemble complète des fonctionnalités et des caractéristiques techniques des produits, expliquent comment les utiliser et donnent des conseils de manipulation.
Utilisez Adobe Reader pour afficher les documents.
VIDÉOS EXPLICATIVES
Explorez les nouvelles fonctions, recevez des astuces pratiques, consultez les instructions pas-à-pas et découvrez comment les autres utilisent leurs produits Suunto.
Consultez nos vidéos.
OUTIL DE LOCALISATION DE REVENDEURS ET RÉPARATEURS
Trouvez un centre de réparation ou un revendeur Suunto agréé près de chez vous.
Ouvrir l'outil de localisation de revendeurs
ÉCRIVEZ-NOUS
Obtenez de l'aide en chinois, anglais, finnois, français, allemand, italien, japonais, russe, espagnol ou suédois.
1. Contactez-nous via MySuunto
SE CONNECTER
ENREGISTRER
Qu'est-ce que MySuunto ?
2. Ou laissez-nous votre message ci-dessous (pas d'inscription nécessaire)
ENVOYER UNE QUESTION
Nous ferons de notre mieux pour vous répondre dans les prochains jours. Toutefois, si vous avez besoin d'aide en urgence, téléphonez-nous.
TÉLÉPHONEZ-NOUS
Assistance en anglais disponible 24 h sur 24, 7 jours sur 7.
Assistance disponible de 9h00 à 17h00 heure locale les jours ouvrés :
Si votre pays n'apparaît pas dans la liste, les appels vous seront facturés au tarif international en vigueur chez votre opérateur. Votre appel pourra être enregistré ou écouté à des fins de contrôle qualité et de formation.
GARANTIE LIMITÉE INTERNATIONALE SUUNTO
Pendant la période de garantie, Suunto ou un centre de service après-vente agréé Suunto (appelé ci-après centre de service) s'engage à sa seule discrétion à remédier sans frais aux défauts de matériau ou de fabrication, soit a) en réparant, soit b) en remplaçant ou encore c) en remboursant le produit, conformément aux conditions générales de la présente garantie limitée internationale. La présente garantie limitée internationale est valable et exécutoire quel que soit le pays d'achat. La garantie limitée internationale n'a pas d'incidence sur les droits qui vous sont conférés par la législation nationale applicable à la vente de biens de consommation.
Période de garantie
La période de garantie limitée internationale prend effet à la date de l'achat initial au détail.
La période de garantie est de deux (2) ans pour les produits et transmetteurs de plongée, sauf indication contraire.
La période de garantie est d'un (1) an pour les accessoires, notamment et de manière non limitative pour les capteurs sans fil, chargeurs, câbles, batteries rechargeables, sangles, bracelets et flexibles.
Pour toutes les montres Suunto Spartan achetées en 2016, la période de garantie a été étendue à trois (3) ans.
Exclusions et limitations
La présente garantie limitée internationale ne couvre pas :
  1. a) l'usure normale telle que les rayures, l'abrasion, la décoloration ou la déformation du matériau des bracelets non métalliques, b) les défauts résultant d'une manipulation brutale ou c) les défauts ou dommages résultant d'une utilisation contraire à celle prévue ou recommandée, un entretien inapproprié, une négligence et les accidents comme les chutes ou l'écrasement ;
  2. les documents imprimés et l'emballage ;
  3. les défauts ou prétendus défauts consécutifs à l'utilisation avec tout autre produit, accessoire, logiciel ou service non fabriqué ou fourni par Suunto ;
  4. les piles non rechargeables.
Suunto ne garantit pas que le fonctionnement du produit ou de l'accessoire sera exempt d'erreurs ou d'interruptions, ni que le produit ou l'accessoire fonctionnera avec des logiciels ou des matériels fournis par un tiers.
La présente garantie limitée internationale n'est pas exécutoire si le produit ou l'accessoire :
  1. a été ouvert hors de l'utilisation prévue ;
  2. a été réparé avec des pièces de rechange non autorisées ; modifié ou réparé par un centre de service non autorisé ;
  3. a vu son numéro de série supprimé, altéré ou rendu illisible de quelque manière que ce soit, ceci étant laissé à la seule appréciation de Suunto ;
  4. a été exposé à des produits chimiques, y compris et de manière non limitative par des crèmes solaires et anti-moustiques.
Accès au service de garantie Suunto
Vous devez fournir la preuve d'achat du produit pour accéder au service de garantie Suunto. Vous devez également enregistrer votre produit en ligne sur www.suunto.com/mysuunto pour pouvoir bénéficier des services de la garantie internationale dans le monde entier. Pour savoir comment bénéficier du service de garantie, rendez-vous sur www.suunto.com/warranty, adressez-vous à votre détaillant local agréé Suunto ou appelez le Centre de contact Suunto.
Limitation de responsabilité
Dans les limites autorisées par la législation applicable, la présente garantie limitée internationale constitue votre seul et exclusif recours et remplace toute autre garantie, formelle ou implicite. Suunto ne saurait être tenue responsable des dommages spéciaux, indirects, exemplaires ou accessoires, y compris et de manière non limitative la perte de bénéfices anticipés, la perte de données, la perte d'utilisation, le coût du capital, le coût de tout équipement ou moyen de substitution, les plaintes déposées par des tiers, les dommages matériels résultant de l'achat ou de l'utilisation du produit ou découlant du non-respect de la garantie, du non-respect du contrat, d'une négligence, d'un tort strict ou de toute théorie légale ou équitable, même si Suunto avait connaissance de l'éventualité de tels dommages. Suunto ne saurait être tenue responsable des retards liés à l'exécution du service de garantie.
La société Suunto s'engage à sa seule et entière discrétion à remédier sans frais, pendant la période de garantie, aux vices de matériau ou de fabrication du produit, par ses propres moyens ou par l'intermédiaire d'un centre de service agréé Suunto, soit a) en le réparant, soit b) en le remplaçant par un produit similaire, soit encore c) en le remboursant, sous réserve des conditions générales de la présente garantie limitée internationale. La présente garantie limitée internationale ne couvre pas a) l'usure normale, b) les manipulations brutales, c) les modifications, d) l'exposition à des produits chimiques ou e) une mauvaise utilisation. Sauf dispositions contraires stipulées dans la législation en vigueur, a) la présente garantie limitée internationale est valable et exécutoire quel que soit le pays d'achat et b) pour bénéficier des prestations de la garantie limitée internationale, l'inscription sur le site www.suunto.com/mysuunto et une preuve d'achat sont exigées. La présente garantie limitée internationale n'a pas d'incidence sur les droits qui vous sont conférés par la législation en vigueur en matière de vente de biens de consommation.
Période de garantie
Garantie internationale limitée à vie :
Applicable aux boussoles Suunto A, M, MC, MB et Clipper.
La période de garantie internationale est limitée à la durée raisonnable à l'issue de laquelle le produit n'est plus raisonnablement utilisable en raison de son usure normale.
Garantie limitée internationale de 2 ans :
Applicable aux boussoles Suunto AIM, Arrow, Orca-Pioneer et KB.
La période de garantie limitée internationale est de deux (2) ans à compter de la date de l'achat initial au détail.
DANS LES LIMITES AUTORISÉES PAR LES LOIS EN VIGUEUR, LA PRÉSENTE GARANTIE LIMITÉE INTERNATIONALE CONSTITUE VOTRE SEUL ET EXCLUSIF RECOURS ET REMPLACE TOUTE AUTRE GARANTIE, EXPRESSE OU IMPLICITE. SUUNTO NE SAURAIT ÊTRE TENUE RESPONSABLE DES DOMMAGES SPÉCIAUX, INDIRECTS, EXEMPLAIRES OU ACCESSOIRES. SUUNTO NE SAURAIT ÊTRE TENUE RESPONSABLE DES RETARDS LIÉS À L'EXÉCUTION DES PRESTATIONS DE GARANTIE.
Faites réparer votre produit Suunto avec notre demande de réparation en ligne. Ouvrez l'onglet de la demande de réparation en ligne ci-dessous pour vérifier la disponibilité du service dans votre pays.
Si votre pays ne figure pas dans la liste, ou si votre demande de réparation concerne une boussole ou un instrument de précision, vous trouverez le centre de réparation le plus proche de chez vous en utilisant l' Outil de localisation des revendeurs Suunto  – il vous suffit de sélectionner Centre de réparation et la catégorie de votre produit.
Notre demande de réparation en ligne est disponible pour les pays répertoriés ci-dessous. Si votre pays ne figure pas dans la liste, ou si votre demande de réparation concerne une boussole ou un instrument de précision, vous trouverez le centre de réparation le plus proche de chez vous en utilisant l'Outil de localisation des revendeurs Suunto – il vous suffit de sélectionner Centre de réparation et la catégorie de votre produit.
IMPORTANT :
La réparation sera effectuée en sept jours ouvrés environ. Si le produit n'est pas sous garantie, nous vous enverrons un devis avant d'entreprendre la réparation. Si vous refusez notre devis, nous vous renverrons le produit et nous vous facturerons un montant fixe pour l'analyse et les frais de port. Ce montant est susceptible de varier en fonction du pays dans lequel vous résidez.
Instructions à suivre pour remplir la demande de réparation en ligne :
  • 1. Vous devez disposer d'une adresse électronique valide, du numéro de série de votre produit et d'un accès à une imprimante.
  • 2. Choisissez votre pays dans la liste.
  • 3. Saisissez les renseignements demandés. Les documents d'expédition sont automatiquement créés ; vous n'avez plus qu'à les imprimer. Joignez-les au produit que vous nous envoyez.
  • 4. Lorsque vous recevrez la confirmation, appelez la société de messagerie au numéro indiqué afin de convenir d'un rendez-vous pour l'enlèvement du produit.
  • 5. N'envoyez pas les guides d'utilisation, notices ou autres articles vendus en coffret avec votre produit. Nous ne pourrions pas vous les rendre.
  • 6. Si la résolution du problème n'est pas couverte par la garantie, nous nous enverrons par e-mail les modalités de paiement. Les paiements s'effectuent de manière sécurisée par PayPal.
  • 7. Dès que le produit sera réparé, il sera réexpédié à l'adresse que vous aurez indiquée dans votre demande de réparation.
Australie
Autriche
Belgique
Bulgarie
Croatie
Chypre
République tchèque
Danemark
Estonie
Finlande
France
Allemagne
Grèce
Hongrie
Irlande
Italie
Lettonie
Lituanie
Luxembourg
Malaisie
Malte
Pays-Bas
Nouvelle-Zélande
Norvège
Pologne
Portugal
Roumanie
Singapour
Slovaquie
Slovénie
Espagne
Suède
Suisse
Royaume-Uni
États-Unis
Suunto dispose d'un large réseau de centres de service agréés dans plusieurs pays afin de répondre à vos besoins en matière de réparation ou de maintenance. Découvrez le centre de service le plus proche en utilisant l'outil de localisation des revendeurs Suunto – sélectionnez simplement l'option centre de service et la catégorie du produit.
Vous pouvez également contacter l'Assistance client Suunto pour connaître la meilleure façon de dépanner votre produit.
