Share
REF SS014587000 / この製品は生産を終了しております。
Suunto Cobra3
Advanced air-integrated dive computer with electronic 3D compass
価格と在庫情報を読み込み中です
Suunto Cobra3 is an all-in-one console-mounted dive computer. It features air-integration, an electronic 3D compass, an easy-to-read matrix display, and simplified four-button operation.
Air integration
Suunto Cobra3 monitors and displays your tank pressure, tracks your rate of air consumption, and continuously calculates your remaining air time. It also provides visual and audible alarms for depth and pressure and warns you when you're running low on air.
Clear navigation
Suunto Cobra3 features a unique electronic 3D compass that can be tilted up to 45 degrees in any direction, making it easier to read the figures clearly and accurately under water.
Effortless operation
The easy-to-read dot matrix display and electro-luminescent backlight mean all your dive-critical information – including bearing, tank pressure, depth, and dive time – will all be shown clearly. And with the simplified four-button operation, the computer is easy to operate even when wearing gloves.
Multi-mode versatility
With its Nitrox, Air, and Gauge modes and gas-switching capabilities, Suunto Cobra3 delivers everything you need to maximize bottom time and make the most of every dive. When using enriched air, Suunto Cobra3 can be programmed for nitrox mixtures between 21% and 100% oxygen. You can also adjust oxygen partial pressure between 0.5 and 1.6 bar. In Gauge mode, it can also be used as a depth gauge and timer with profile memory.
Flexible decompression
Using the Suunto Deep Stop RGBM algorithm, Suunto Cobra3 enables continuous decompression for optimal ascent time. For deeper dives, the Deep Stop option adds further protection with a series of deep stops between your maximum depth and ceiling.
When in Nitrox mode, you can accelerate decompression by switching to a gas mix with a higher oxygen percentage. With Suunto Cobra3 it's quick and easy to switch between enabled gas mixes while diving.
Plan and review
You can test upcoming dives and view no-decompression and decompression time data for different depths before getting in the water with the built-in dive simulator. When the dive is over, get detailed graphical logs and dive data on your computer using Suunto DM4 software.
  • エアー、ナイトロックス、ゲージモード
  • 3D デジタルコンパス
  • スント RGBM
  • 視認性に優れたマトリクスディスプレイ
  • Air integrated for tank pressure information
  • Tiltable electronic 3D compass to keep you on course
  • User-friendly design featuring easy-to-read matrix display and simplified four-button operation
  • Three dive modes and gas-switching capability for a range of dive situations
  • Continuous decompression with the Suunto RGBM algorithm
  • Built-in dive simulator for planning upcoming dives
  • Optional computer interface for detailed graphical logbooks and dive data analysis
サイズ 73  x  165  x  35  mm
重量 210 g
サイズ 2.87  x  6.5 x  1.38 "
重量 7.41 oz
ベゼルの素材: コンポジット
レンズの素材: アクリル
ケースの素材: コンポジット
ストラップの素材: エラストマー
偏角の補正 あり
Suunto Cobra3 – 技術仕様
ベゼルの素材: コンポジット
レンズの素材: アクリル
ケースの素材: コンポジット
ストラップの素材: エラストマー
重量 210 g / 7.41 oz
耐水設計 100 m (ISO 13319)
タイムモードでのバッテリー寿命 3 年間
バッテリー寿命:100 デバイス/年 1.5 年間
バッテリータイプ CR 2450
交換可能なバッテリー
時間、日付
アラームクロック 1 デイリーアラーム
言語 英語
バックライト EL ライト
調整式バックライト 時間間隔: 5、10、20、30、60 秒
表示タイプ マトリクス
表示解像度 49 x 22
バッテリーインジケータ 低バッテリーインジケータ
メートル法とヤードポンド法
データ転送 USB ケーブル (オプション)
DM5 と互換
Suunto Movescountに対応 DM5対応
デジタル コンパス
傾斜調整 最大 45°
方位目盛
ニードル コンパス
グローバル バランス
方位インジケータの軸受ロック
コンパスの精度 10°
コンパスの分解能
動作温度 0℃~+40℃/+32°F~+104°F
保管温度 -20℃~+50℃/-4°F~+122°F
ダイビング機能
最大動作深さ (EN 13319) 100 m
ナイトロックス (およびエアモード)
ゲージ
ダイブ時間 0~999 分
水面時間 0~99 時間 59 分
飛行禁止時間
安全停止
ディープストップ
浮上タイムディスプレイ 0~99 分 (- - 99 後)
CNS/OTU (OLF) 計算
ホースエアーインテグレーション
減圧モデル SUUNTO RGBM
個人調整 0 - 2
高度調整 0~300 m / 300~1500 m / 1500~3000 m
ガス 最大 2 種類のガス (酸素:21~99%)
ガス最大 pO2 1.2 - 1.6
ガス切換
無減圧プランナー
ログブック メモリ 最大 42 時間 (20 秒サンプリングレート)
ログブック ブックマーク
ログブック サンプリングレート 1、10、20、30、60 秒
ダイブ履歴 寿命
ダイブ時間
最大深度
タンク圧力
高 pO2 (高酸素)
過大浮上速度
減圧水面違反
CNS/OTU (OLF) 80% / 100%
ガス切り替え (より良いガスを利用可能)
アウトドア機能
温度表示範囲 -20℃~+50℃(±2℃) / -9°F~+122°F(±3.6°F)
温度分解能 1℃/1.5°F
温度
ユーザーガイド
ユーザーガイドには製品機能全般の概要と使用方法、取扱注意事項および技術仕様が記載されています。
PDFファイルの閲覧にはAdobe Readerが必要です。
How Toムービー
新しい機能に関する詳しい説明や役に立つヒントを紹介したり、ステップバイステップ形式で手順をわかりやすく解説しているほか、Suunto製品のその他の活用方法も紹介しています。
Suuntoのビデオをご覧ください。
販売店およびサービスセンター検索
お近くの認定サービスセンターまたはSuunto製品販売店を検索できます。
販売店検索を開く
ダイブコンピュータおよびデバイスのバッテリー交換
ダイブコンピュータおよびデバイスのバッテリー交換は、Suunto認定サービスセンターにご依頼ください。Suunto取扱店検索を使って最寄りのサービスセンターを見つけることができます。サービスセンターと製品カテゴリを指定するだけで簡単に検索できます。お使いのSuunto製品の修理が必要な場合には、オンラインサービスリクエストをご利用ください。ご利用可能な国の一覧は、オンラインサービスリクエストページに掲載されています。
Suunto認定サービスセンターにて提供される主な修理内容:
  • バッテリーの交換、Oリングやガスケットの交換、磨耗または損傷した部品の交換など。
  • バッテリーの交換にはすべて新品(フル充電)のバッテリーを使用し、Suuntoの製品仕様に沿ったバッテリー寿命を確保します。部品の修理および交換は、製品の整合性を維持するためにSuuntoの製品仕様を忠実に守って行います。
  • バッテリーの交換作業は静電気放電(ESD)から保護された安全な環境で行います。ダイブコンピュータが急激なESDにより損傷を受けるようなことはありません。
  • 修理が完了した製品は、動作確認テストおよび防水テストを行って入念に検査されます。
  • お客様のダイブコンピュータに最高のケアを提供するために、すべての修理およびサービスはトレーニングを受けたSuunto認定技術者がSuunto純正部品と適切な工具を使って行います。
  • 認定サービスセンターにて修理を行ったSuunto製品は、修理完了日から3か月間の修理サービス保証が適用されます。
Suunto DM5でダイビングの計画とログの管理 – PCとMACに対応
Suunto DM5では、高度な分析を行うためにダイブログをダウンロードすることも、詳細なダイブプランをダイブコンピュータにアップロードすることもできます。このプログラムは無料でダウンロードできます。Suunto DM5は英語、オランダ語、フランス語、フィンランド語、ドイツ語、日本語、韓国語、スペイン語、中国語でご利用いただけます。最低動作環境(対応OS):Mac 10.7またはWindows XPDM5について詳しくお読みください
Suunto DM5の主な機能:
  • グラフィカルな表示でわかりやすいSuunto DM5ダイブプランナーでは、ダイブプロファイルの作成やガスの管理を簡単に行えるだけでなく、バックアップ計画を簡単に立てることもできます。作成したガス計画やダイビングに必要不可欠な情報は、ダイブコンピュータにエクスポートすることができます(対応モデルのみ)。また、DM5から混合ガスの情報を印刷することができます。
  • ダイビング後にはダイブログをDM5に転送することができます。ダイビングのデータはログブックに記録されるので、ダイビングをログブックで日別、モード別、ギア別にレビュー、分析することができます。タグ付け機能を使えば、ダイブログにタグ付けするだけでお好みに合わせて整理することができます。また、複数のダイブログを選択して比較することもできます。
  • さらに、Suunto Movescountにダイビングを保存して、友人と共有することができます。
Suunto DM5の無料ダウンロードはこちら:
WINDOWS版
MAC版
お問い合わせください(MESSAGE US)
日本語、英語、フィンランド語、フランス語、ドイツ語、中国語、 イタリア語、ロシア語、スペイン語、スェーデン語でサポートを提供しております。
1. MySuunto から連絡してください。
サインイン
登録
MySuunto とは何ですか?
 2. または、以下よりメッセージをお送りください
 お問い合わせを送信
刻も早くご回答できるようにベストを尽くしますが、より早いサポートをお望みの場合はお電話にてお知らせください。
【製品や機能のお問い合わせ】
製品に関するお問い合わせや機能についてのご質問は、ヘルプデスクが承ります。スントのヘルプデスクは本国フィンランドが運営する専門のスタッフが対応いたします。日本のお客様のお問い合わせには、日本人スタッフおよび日本語が堪能なスタッフがお応えします。ヘルプデスクも国内通話料金のみでご利用いただけます。
TEL:03-4520-9417
10:00〜18:00(土日祝・振替休日を除く平日)
※本国フィンランドにて運用を行っている関係上、フィンランドの祝日に合わせてヘルプデスクがお休みとなる場合がございますので予めご了承ください。
Suunto製品に関する国際保証
保証期間内において、スントまたはスント認定サービスセンター(以後「サービスセンター」)の独自の判断により、素材や不具合の改善・修理の無償提供を保証しています。その内容は本国際保証の条件に従い、a) 製品または部品の修理、b) 製品または部品の交換、またはc) 返金のいずれかになります。本国際保証は、現地法がそれ以外を規定する場合を除き、購入した国に関わらず法的強制力を持ちますが、消費財の販売を統制する適用国内法に基づいて、消費者が保有する法的権利に影響を与えることはありません。
保証期間
本国際保証の保証期間は、小売店からご購入いただいた日が保証の開始日となります。
製品およびダイブトランスミッターの保証期間は、別段の定めがある場合を除き通常、ご購入日から2年間となります。
ワイヤレスセンサー、充電器、ケーブル、充電式バッテリー、ストラップ、ブレスレット、ホースなどアクセサリーの保証期間は、ご購入日から1年間となります。
2016年に購入されたSuunto Spartanウォッチ(全モデル対象)の保証期間は、ご購入日から3年間となります。
適用除外・制限条項
以下の場合、本保証の対象となりません:
  1. a) 傷、摩耗、または非金属ストラップの変色および/または材質の変化などの通常の使用損耗、 b) 乱暴な取り」扱いによる欠陥・不具合、または c) 本来の使用目的または推奨されている使用方法に反した使用、不適切なケア、過失、および落下または衝突などの事故に起因する欠陥または損傷;
  2. 印刷物およびパッケージ;
  3. Suuntoによって製造または提供されていないすべての製品、付属品・アクセサリー、ソフトウェア、サービスに起因する欠陥または欠陥の疑い;
  4. 非充電式バッテリー
Suuntoでは、製品または付属品・アクセサリーの動作の中断、またはエラーがないこと、さらには第三者のハードウェアまたはソフトウェアを使用した場合に製品または付属品・アクセサリーが動作することを保証するものではありません。
国際保証は製品またはアクセサリーが以下に該当する場合、対象外となります:
  1. 使用目的を超えて開梱された場合;
  2. 不正な補修部品を使用して修理された場合; 非公認のサービスセンターによって改良または修理された場合;
  3. シリアルナンバーが除去、変更、または判読不能であるとSuuntoが判断した場合; または
  4. 日焼け止め剤や防虫剤など化学薬品が付着した場合
Suunto保証サービスの利用
Suunto保証サービスを利用するには、ご購入日が特定できる保証書やレシートなどの購入証明書を提出しなければなりません。本国際保証サービスを受けるためには、www.suunto.com/mysuuntoで製品をオンライン登録していることが条件となります。保証サービスを受ける方法については、www.suunto.com/warrantyをご覧になるか、最寄りのSuunto正規販売店へ連絡、またはSuuntoサービスセンターへお電話にてお問い合わせください。
責任制限
適用法令で許される最大限の範囲内において、本国際保証はお客様の唯一かつ排他的な救済手段であり、明示または黙示を問わず、すべての保証に代わるものです。Suuntoは、Suuntoがかかる損傷の可能性を予期できていた場合であっても、予期される利益の損失、データの損失、使用不能、資本コスト、代替機器もしくは施設の費用、第三者の要求、機器の購入もしくは使用の結果となる、もしくは保証の違反、契約違反、過失、不法行為もしくは法律もしくは衡平法の理論から発生する資産への損失を含むがこれに限定されない特殊損害、偶発的損害、懲罰的損害または間接的損害については、その責任を負わないものとします。
Suuntoは保証サービス提供の遅延において責任を負わないものとします。
SUUNTO国際限定保証
Suuntoは、本国際限定保証の条件に従い、以下に定める保証期間内において、SuuntoまたはSuunto認定サービスセンターによる独自の判断で、a) 修理、b) 同様の製品との交換、c) 返金のいずれかの方法で、部品または作業行程における不具合の修正を無料で行うことを保証します。本国際限定保証では、a) 通常使用による磨耗や損傷、b) 乱暴な取り扱い、c) 改造、d) 化学薬品との接触、e) 誤用によって生じた故障や不具合は保証の適用外となります。本国際限定保証は、適用される強行法規に別段の定めがない限り、a) 購入国に関わらず法的強制力を持ち、b) サービス利用には、www.suunto.com/mysuuntoへの登録および購入の証明が必要となります。本国際限定保証は、消費財の販売に関連して適用される強行法規に基づき、消費者が保有する法的権利に何ら影響を与えるものではありません。
保証期間
国際限定保証:
Suunto A、M、MC、MBおよびClipperコンパスに適用。
国際限定保証の期間は、摩耗や損傷が原因で製品の通常使用が不可能になるまでの期間に限定されます。
2年間国際限定保証:
Suunto AIM、Arrow、Orca-PioneerおよびKBコンパスに適用。
本国際限定保証期間は、小売店での最初の購入日から2年間とします。
本国際限定保証は、免責
適用される強行法規により許容される最大限の範囲内において、お客様の唯一かつ排他的な救済手段であり、明示的または黙示的であるかを問わず、すべての他の保証に代わるものです。Suuntoは、特別、偶発的、懲罰的または間接的な損害に対して、一切責任を負わないものとします。Suuntoは、保証サービス提供の遅延に対して、一切責任を負わないものとします。
マリンコンパス保証情報
製品のお買い上げ日から5年(60ヶ月)以内に材質及び/または仕上げ等に不具合が生じた場合には、当該製品を再生部品または新品を使用して無償修理を行います。
その後の製品の再販売およびスントが認定した製品の修理または交換による影響がない限り、保証期間は延長または更新されません。しかし、保証期間中の部品の修理または交換は、元の保証期間の残りの期間、または修理または交換の日付から3カ月の期間のいずれか長い方の期間で保証されます。
マリンコンパスの保証期間
保証期間は、最初のエンドユーザーの購入者が小売店で購入した日より開始します。マリンコンパスの保証期間は5年間です。
お客様の国の法律が許可する範囲において、その後の再販売、スントが認定した製品の修理または交換による影響がない限り保証期間は延長または更新されません。 しかし、保証期間中の部品の修理または交換は、元の保証期間の残りの期間、または修理または交換の日付から3カ月の期間のいずれか長い方の期間で保証されます。
限定または排除
本限定保証には以下は含まれません:
1. a) 通常の消耗や傷み、 b) 乱暴な取り扱いによって生じた欠陥、または c) 使用目的から外れるまたは推奨する使用方法に反する間違った使い方によって生じた欠陥や損傷;
2.ユーザーマニュアルまたは第三者の物品;
3.スント以外が製造または供給した、製品、アクセサリー、ソフトウェア、サービスの使用によって生じた欠陥または疑われる欠陥;
4. 交換可能バッテリー。
部材が、以下の場合は、本限定保証の効力はありません:
1.使用目的から外れて、開かれた場合;
2.認定されていないスペア部品を使用して修理された場合;認定されていないサービスセンターによって変更または修理された場合
3.シリアルナンバーが取り外された、変更された、またはなんらかの不正な方法で作成され、それがスントの独自の裁量権で認められた場合;
4.化学薬品(蚊よけ製品を含むがこれに限定されるものではない)に暴露された場合。
スントは、製品の動作が途中で停止しないまたはエラーがないこと、または製品が第三者によって提供されたハードウェアまたはソフトウェアとともに動作することを保証しません。
スント保証サービスへのアクセス
スント保証サービスにアクセスするには購入の証明を持っていなければなりません。保証サービスを得るための手順は、「修理サービス(Repair Services)」のセクションを見るか、カスタマサポートまでご連絡ください。
責任限定
適用される強制的法律が許可する可能な最大限の範囲において、本限定保証は、明示的または暗示的に関わらず、お客様の唯一かつ排他的な救済 で、他の保証すべてに代わるものです。スントはいかなる場合も 特別な、偶発的な、苛酷な、または誘発的な損害(期待された利益の損失、データの損失、使用の損失、予算のコスト、代替の装備または設備のコスト、第三者からの請求、購入の結果によって、もしくは物品の使用によって、もしくは保証の不履行によって生じた財産への損害、契約の不履行、過失、厳格な不法行為、または法的もしくは衡平法上の理論を含むがこれに限定されるものではない)について、スントがそのような損害の可能性を知っていたとしても、一切責任を負いません。スントはいかなる場合も、保証サービスの遅れについて一切責任を負いません。
スポーツ・コンピューター保証情報
製品のお買い上げ日から2年(24ヶ月)以内に材質及び/または仕上げ等に不具合が生じた場合には、当該製品を再生部品または新品を使用して無償修理を行います。
この無償保証は正規の購入者に対してのみ有効であり、保証期間内に通常使用中に生じた材質及び/または仕上げ等の不具合にのみ適用されます。
バッテリーは保証対象外であり、保有者によるバッテリー交換にともなう不具合、事故、誤使用、お手入れを怠った場合、不適切な取り扱い、改造、不当な修理が行われた場合に起因する損傷や故障、また、本製品の性能を超えた使用をされた場合に起因する全ての故障、取扱説明書に記載されている以外に起因する不具合などが生じた場合は保証の限りではありません。
上記以外の事項に関しては保証いたしません。
また、保証条件以外の製品修理については有償で行うものし、保証権限を元の製品所有者より移譲することはできないものとします。
スント社及びアメアスポーツジャパン株式会社は、製品を使用した、または使用できなかったことに起因する不意または結果として起こったいかなる破損に対しても責任を負わないものとします。
スント社、アメアスポーツジャパン株式会社及びその子会社は、本製品の使用から生じた第三者の損害や申し立てに対し、いかなる責任も負わないものとします。
スント社の品質保証システムは、Det Norske Vertas によりISO 9001 適合の認可を受けています (品質認証番号:96-HEL-AQ-220)。
製品の修理・メンテナンスについて
この度は、SUUNTOダイブコンピューター製品をお買い上げいただきありがとうございます。
製品の製造、出荷につきましては、最大限の注意を払いお客様のお手元に届くよう万全の管理体制を組み対応しておりますが、万一、製品の不具合や故障が生じた場合は、下記の注意事項をお読みの上、修理・メンテナンスのご依頼をお願いいたします。
株式会社エフエル・コーポレーションは、1988年8月8日より、スント社(フィンランド国)のスクーバダイビング器材などの総輸入元及び、卸業として取扱いを行っております。
■ 修理のご依頼方法:
製品をお買い求めいただいた、または最寄りのダイビングショップに直接ご依頼ください。
ダイビングショップにお持込みができない場合は、下記をご用意いただいた上で、株式会社エフエル・コーポレーション内メンテナンス係に直接ご郵送ください。
■ ご用意いただくもの:
  • 当該製品
  • アクセサリー(ワイヤレス・トランスミッターをご使用の場合のみ)
  • 保証書
  • 電池交換・修理依頼シート
※印直接郵送する場合、下記の修理依頼シートに必要事項をご記入ください。
修理依頼シートのダウンロード(PDF)
※保証期間の有無を問わず、保証書のご提示をお願いしております。
保証書をお持ちでない、または紛失された場合でも修理の受付は可能となりますが、
修理金額が異なる場合がございます。予めご理解をお願いいたします。
■ 修理品の送付先:
住所:〒182-0026 東京都調布市小島町2-25-40
TEL:(042)489-7341
■ 直接修理品を発送いただく際の注意点:
  1. 送運賃はお客様のご負担となります。
  2. お持込みでの受付は対応しておりません。
  3. 発送方法はお客様控えが残る宅配便(佐川、ヤマト、宅急便、ゆうパックなど)にてお願いします。
  4. 修理後のお戻しは、製品に不具合がない場合に限り、約10日~2週間程度を想定しております。また、お戻し納期に関しては、修理の状況により変動しますので予めご了承ください。
  5. 修理代金は代引きでの発送となります。(電池交換の場合、正規品7,665円税込/海外購入品・並行輸入品13,125円税込、代引き手数料含)
■ 製品に関するよくあるご質問:
電池交換以外の修理、またはそれ以外の製品に関するご質問は下記でもご覧いただけます。
http://www.flcorp.co.jp/faq.html#01
製品別 修理・メンテナンスお問い合わせ先
スント ダイブコンピューターに関するお問合せ先:
株式会社 エフエルコーポレーション〈日本正規代理店〉
TEL:0424-89-7341
スント 精密コンパスに関するお問合せ先:
株式会社 テックインターナショナル〈日本正規代理店〉
http://www.tec-inter.co.jp/
TEL:03-3235-3838
※スント スポーツウォッチ(アウトドアモデル、心拍計、GPSウォッチ)に関するお問合せは、下記をご参照ください。
保証修理につきまして
日本国内のスント正規販売店にてお買い上げいただきました製品が保証期間内で、取扱説明書に沿った正しい方法でご使用いただいていた場合の故障につきましては、部品交換による修理もしくは新品への交換を無償で行います。なお、本体交換やモジュール交換を実施した場合は、シリアル番号や外装が変更になることがございますので、予めご了承ください。
※GPS搭載モデル(AMBIT, TRAVERSE, KAILASH, SPARTANシリーズなど)の修理につきまして
GPS搭載モデル(AMBIT, TRAVERSE, KAILASH, SPARTANシリーズなど)は、その修理内容に関わらず、ユニット内部点検を行うとともに本体データを最新版にアップデートする作業を行います。そのため、本体に記録された全てのデータが初期化されますので、必要なデータは修理をご依頼頂く前にお客様ご自身でバックアップ頂けますようお願いいたします。
保証対象部分
製品内部の故障、機能の不具合が保証対象となります。
保証対象外の故障・損傷
保証期間内でも次の場合は有償での修理となります。
  1.  お買い上げの後の輸送、移動時のお取扱が不適切なため生じた故障・損傷
  2.  誤用、乱用及び取り扱い不注意による故障・損傷
  3.  不当な修理または改造による故障・損傷
  4. 使用中に生じたキズ、破損などの外観上の変化
  5.  消耗品 ( バッテリー、ストラップなど) の交換
  6. 火災、地震、水害その他の天災事変及び異常電圧による故障・損傷
国内保証書について
日本国内のスント正規販売店にてご購入頂きましたスント製品には、必ずアメアスポーツジャパン(株)発行の国内保証書が添付されています。
上記無償保証対象外による修理でも、割引価格にてお受けしております。また、保証期間を過ぎても故障内容によっては無償保証の対象となる場合がございますので、国内保証書は大切に保管いただきますようお願いいたします。
■ 国内保証書サンプル
リストップ・コンピュータ
◀ リストップ・コンピュータ
POD
◀ POD
ELEMENTUM
◀ ELEMENTUM
周辺機器
◀ 周辺機器
*国内保証書の再発行は行っておりません。
修理のご依頼方法
■ 国内スント正規販売店にてスント製品をご購入頂きましたお客様
下記をご用意いただき、製品をお買い求め頂いた販売店に直接ご依頼ください。
  • 当該製品
  • 保証書 :保証期間の有無を問わず、保証書のご提示をお願いしております。保証書をお持ちでない、紛失された場合でも修理の受付は可能となりますが、修理金額が変わる場合がございます。
  • アクセサリ:トランスミッターベルト、PODなどをご使用の場合のみ
■ 国内スント正規販売店以外でご購入頂きましたお客様
下記をご用意いただき、直接ご郵送ください。
  • 当該製品
〒230-0076
神奈川県横浜市鶴見区馬場3-2-32 3F
TEL:03-6831-2715(内線2番)
FAX:045-581-3882
スント修理センター宛
*お持込みでの受付はしておりません。
ご注意:
以下をご確認のうえ、当該製品を修理センターまでお送りください。
・お送り頂く際は、下記情報をご記入頂いたメモを添付ください。
  1. お客様のお名前
  2. ご住所
  3. ご連絡先(電話、ファックス、メールアドレスなど)
  4. 当該製品の修理ご依頼箇所、不具合内容、症状などの詳細
  5. ソフトウエアアップデートに関するご承認(GPS搭載モデルの場合。詳しくは上記「※GPS搭載モデルの修理につきまして」をご参照下さい)
・当該製品が海外並行品である場合、修理センターにお送り頂いた時点で(修理のご依頼の有無に関わらず)2,000円(税抜)のお見積作成料金が発生致します。
・ご発送の際は時計に衝撃が加わらないように緩衝材などで十分に保護して下さい。
・送料はお客様のご負担となります。
・修理金額が発生した場合のお支払いについては、商品代引きでのお支払いとなります。
・代引き手数料が別途お客様ご負担となりますので、予めご了承頂けますようお願い致します。
修理価格について
修理センターでは、修理品をお預かり後、正式なお見積書を発行しております。修理のご依頼は、お客様にお見積額をご確認いただいてから行いますのでご了承ください。修理品の受取日より7営業日前後でお見積書をご案内いたします。
■ 修理価格例(モデルにより異なります)
バッテリー交換:5,500〜
アッパーケース交換:12,000〜
基盤交換:20,000〜
修理期間について
修理内容や部品の在庫状況により異なりますため、具体的な修理期間につきましては、修理センターにて当該製品の故障状況を確認させていただいた後にご連絡を差し上げます。
