REF SS015077000
Suunto Vector Orange
Legendary outdoor sports watch with a solid track record of high-altitude performance
THE ORIGINAL MOUNTAIN WATCH
After a decade of travels, adventures and courageous expeditions, the Suunto Vector is still the most legendary watch with altimeter, barometer and compass. With technology and durability that can take on the harshest of environments, the Suunto Vector is the choice of professionals.
PRODUCT HIGHLIGHTS
  • Altimeter, barometer, compass
  • Robust and light
  • Trusted by professionals
  • Weather trend indicator
  • Temperature
  • Altitude difference measurement
  • Altitude log
  • Vertical speed
  • Multiple watch
  • Date and time functions
  • User-replaceable battery
What's in the box?
Suunto Vector Orange, Quick guide
Measurements 51,4  x  45,6  x  15,3  mm
Weight 54 g
Measurements 2,02  x  1,8 x  0,6 "
Weight 1,9 oz
Suunto Vector Orange – Technical specifications
Altimeter
Altitude alarm
Vertical speed
Temperature compensation
Automatic 24-hour memory
Altitude range -500m - 9000m/-1600ft - 29500ft
Difference measurement
History memory
Logbook function
Total ascent/descent
Resolution 5 m
Recording intervals 20s, 60s, 10min, 60min
Chronograph
Countdown timer
Stopwatch
Max number of split times in memory 2
Compass
Heading in degrees
Declination setting
Cardinal directions
Bearing tracking
Compass with bubble level
North-South indicator North-South indicator
Other
User replaceable straps
Selectable metric/imperial units
Weight 54 g / 1.9 oz
Operating temperature -20°C - +60°C /-5°F - +140°F
Water resistance 30 m / 100 ft
Storage temperature -30°C - + 60°C / -22°F - +140°F
Backlight type Electro-luminescent display
Power
Low battery warning
User replaceable battery
Special
Rotating bezel
Watch
12/24h
Calendar clock
Daily alarms 3
Weather
Absolute barometric pressure
Trend indicator
Temperature
Sea level pressure
Barometer resolution 0,05 inHg/1 mbar
Barometer range 8,9 -32,4 inHg/300-1100 mbar
Temperature resolution 1°C / 1°F
Weather memory 4 days
Temperature range -20°C - +60°C /-5°F - +140°F
MANUALS
Find out everything you need to know, from set up to troubleshooting. Download the manual now.
Use Adobe Reader for viewing.
HOW TO VIDEOS
Explore new features, get useful tips, see step-by-step instructions and find out how others are using Suunto devices.
Check out our videos.
DEALER LOCATOR
Open the dealer locator
MESSAGE US
Get in touch through MySuunto.
SIGN IN
REGISTER
What is MySuunto?
EMAIL US
Email us at support@suunto.com.
Get support in English, Finnish, French, German, Italian, Japanese, Russian, Spanish or Swedish.
State the product name, serial number and a detailed description of the issue. We will respond within 72 hours, unless the solution requires a more in-depth analysis.
CALL US
Support in English available 24/7:
Australia +61 1800 240 498 (toll free)
New Zealand +64 988 75 223
United Kingdom +44 20 360 805 34
USA +1 855 258 0900 (toll free)
Support available from 9 am to 5 pm local time:
Austria +43 72 088 3104
Canada +1 800 267 7506 (toll free) - press 3 and then 1 for technical support (in English and French)
Finland +358 94 245 0127
France +33 48 168 0926
Germany +49 893 803 8778
Italy +39 029 475 1965
Japan +81 34 520 9417
Netherlands +31 10 713 7269 (in English)
Russia +7 499 918 7148
Spain +34 911 143 175
Sweden +46 85 250 0730
Switzerland +41 44 580 9988
Sports Watches, Dive Computers and Precision instruments
Warranty information for Suunto products
Suunto warrants that during the Warranty Period Suunto or a Suunto Authorized Service Center (hereinafter Service Center) will, at its sole discretion, remedy defects in materials or workmanship free of charge either by a) repairing, or b) replacing, or c) refunding, subject to the terms and conditions of this Limited Warranty. This Limited Warranty is only valid and enforceable in the country of purchase, unless local law stipulates otherwise.
Warranty Period for Sports Watches, Dive Computers and Precision Instruments
The Limited Warranty Period starts at the date of original retail purchase. The Warranty Period is two (2) years. The Warranty Period is one (1) year for accessories including but not limited to PODs and heart rate transmitters, chargeable batteries, chargers, docking stations, straps, cables and hoses as well as for all consumable parts.
Exclusions and Limitations
This Limited Warranty does not cover:
1. a) normal wear and tear, b) defects caused by rough handling, or c) defects or damage caused by misuse contrary to intended or recommended use;
2. User manuals or any third-party items;
3. Defects or alleged defects caused by the use with any product, accessory, software and/or service not manufactured or supplied by Suunto;
4. replaceable batteries.
This Limited Warranty is not enforceable if item:
1. Has been opened beyond intended use;
2. Has been repaired using unauthorized spare parts; modified or repaired by unauthorized Service Center
3. Serial number has been removed, altered or made illegible in any way, as determined at the sole discretion of Suunto;
4. Has been exposed to chemicals including but not limited to mosquito repellents.
Suunto does not warrant that the operation of the Product will be uninterrupted or error free, or that the Product will work with any hardware or software provided by a third party.
You must have proof of purchase to access Suunto warranty service. For instructions how to obtain warranty service see the section ‘Repair Services’ or contact our Customer Support.
Limitation of Liability
To the maximum extent permitted by applicable mandatory laws, this Limited Warranty is your sole and exclusive remedy and is in lieu of all other warranties, expressed or implied. Suunto shall not be liable for special, incidental, punitive or consequential damages, including but not limited to loss of anticipated benefits, loss of data, loss of use, cost of capital, cost of any substitute equipment or facilities, claims of third parties, damage to property resulting from the purchase or use of the item or arising from breach of the warranty, breach of contract, negligence, strict tort, or any legal or equitable theory, even if Suunto knew of the likelihood of such damages. Suunto shall not be liable for delay in rendering warranty service.
Field Compasses
SUUNTO LIMITED WARRANTY
Warranty Period
Limited Lifetime Warranty:
Limited 2-year Warranty:
Marine Compasses
Warranty Information for Suunto Products
Warranty Period for Marine Compasses
The Warranty Period starts at the date of retail purchase by the original end user purchaser. The Warranty Period is five (5) years for marine compasses.
To the extent your national laws permit, the Warranty Period will not be extended or renewed or otherwise affected due to subsequent resale, Suunto authorized repair or replacement of the Product. However, part(s) repaired or replaced during the Warranty Period will be warranted for the remainder of the original Warranty Period or for three (3) months from the date of repair or replacement, whichever is longer.
Get your Suunto product repaired with our online service request, available in the United States and in 30 European countries.
Online service request
IMPORTANT:
Repair is completed within approximately seven business days. If the product is not under warranty, we’ll send you a cost estimate before starting repair – if you choose not to have the product repaired, we’ll send it back to you but you’ll still be charged for the diagnosis and freight.
  • 6. If the solution is not covered by the warranty, we’ll send you payment details by email. Payments are made securely via PayPal. In Norway and Switzerland the costs are handled directly through a credit card company.
Andorra
Austria
Belgium
Bulgaria
Cyprus
Czech Republic
Denmark
Estonia
Finland
France
Germany
Greece
Hungary
Ireland
Italy
Latvia
Lithuania
Luxemburg
Malta
Netherlands
Norway
Poland
Portugal
Romania
Slovakia
Slovenia
Spain
Sweden
Switzerland
United Kingdom
United States
Service centers
Product accessories
