Share
REF SS014587000 / Выпуск этого продукта прекращен
Suunto Cobra3
Advanced air-integrated dive computer with electronic 3D compass
Suunto Cobra3 is an all-in-one console-mounted dive computer. It features air-integration, an electronic 3D compass, an easy-to-read matrix display, and simplified four-button operation.
Air integration
Suunto Cobra3 monitors and displays your tank pressure, tracks your rate of air consumption, and continuously calculates your remaining air time. It also provides visual and audible alarms for depth and pressure and warns you when you're running low on air.
Clear navigation
Suunto Cobra3 features a unique electronic 3D compass that can be tilted up to 45 degrees in any direction, making it easier to read the figures clearly and accurately under water.
Effortless operation
The easy-to-read dot matrix display and electro-luminescent backlight mean all your dive-critical information – including bearing, tank pressure, depth, and dive time – will all be shown clearly. And with the simplified four-button operation, the computer is easy to operate even when wearing gloves.
Multi-mode versatility
With its Nitrox, Air, and Gauge modes and gas-switching capabilities, Suunto Cobra3 delivers everything you need to maximize bottom time and make the most of every dive. When using enriched air, Suunto Cobra3 can be programmed for nitrox mixtures between 21% and 100% oxygen. You can also adjust oxygen partial pressure between 0.5 and 1.6 bar. In Gauge mode, it can also be used as a depth gauge and timer with profile memory.
Flexible decompression
Using the Suunto Deep Stop RGBM algorithm, Suunto Cobra3 enables continuous decompression for optimal ascent time. For deeper dives, the Deep Stop option adds further protection with a series of deep stops between your maximum depth and ceiling.
When in Nitrox mode, you can accelerate decompression by switching to a gas mix with a higher oxygen percentage. With Suunto Cobra3 it's quick and easy to switch between enabled gas mixes while diving.
Plan and review
You can test upcoming dives and view no-decompression and decompression time data for different depths before getting in the water with the built-in dive simulator. When the dive is over, get detailed graphical logs and dive data on your computer using Suunto DM4 software.
ОСОБЕННОСТИ МОДЕЛИ
  • Режимы воздуха, кислородно-азотной смеси и датчика
  • 3D-компас
  • Suunto RGBM
  • Хорошо читаемый матричный дисплей
  • Air integrated for tank pressure information
  • Tiltable electronic 3D compass to keep you on course
  • User-friendly design featuring easy-to-read matrix display and simplified four-button operation
  • Three dive modes and gas-switching capability for a range of dive situations
  • Continuous decompression with the Suunto RGBM algorithm
  • Built-in dive simulator for planning upcoming dives
  • Optional computer interface for detailed graphical logbooks and dive data analysis
Размеры 73  x  165  x  35  мм
Вес 210 г
Размеры 2,87  x  6,5 x  1,38 "
Вес 7,41 у
Материал безеля: Композит
Материал стекла: Акрил
Материал корпуса: Композит
Материал ремешка: Эластомер
Коррекция отклонения Да
Suunto Cobra3 – Технические характеристики
Вес 210 г / 7,41 у
Водостойкий 100 м (ISO 13319)
Время работы батареи в режиме времени 3 года
Срок службы батареи: 100 погружений в год 1,5 года
Тип батареи CR 2450
Сменная батарея
Время, дата
Будильник 1 ежедневная подача сигнала
Языки EN
Подсветка электролюминесцентная
Настраиваемая подсветка продолжительность 5, 10, 20, 30, 60 с
Тип дисплея матричный
Разрешение дисплея 49 x 22
Индикатор заряда батареи индикатор низкого заряда батареи
Метрическая и британская системы измерения
Передача данных USB кабель (доп.)
Совместимость с DM5
Поддержка Suunto Movescount с помощью DM5
Цифровой компас
Компенсация склонения до 45°
Шкала направления градусы
Стрелка картушка компаса
Глобальная балансировка
Фиксация курса с индикатором ориентирования
Точность компаса 10°
Дискретность компаса
Рабочая температура от 0 °C до +40 °C
Температура хранения от -20 °C до +50 °C
ФУНКЦИИ ДЛЯ ПОГРУЖЕНИЯ
Максимальная глубина погружения (EN 13319) 100 м
Кислородно-азотная смесь (и воздух)
Gauge (Датчик)
Время погружения От 0 до 999 мин
Время на поверхности от 0 до 99 ч 59 мин
Время запрета полетов
Остановка безопасности
Декомпрессионная остановка
Отображение времени всплытия 0–99 мин (– – после 99)
Вычисление ЦНС (%) + ед. токсичности кислорода (коэффициент предельного насыщения)
Подключение к системе подачи воздуха
Модель декомпрессии SUUNTO RGBM
Персональная настройка 0 - 2
Поправка по высоте 0–300 м / 300–1 500 м / 1 500–3 000 м
Газовые смеси До 2 газовых смесей (кислород 21–99%)
Максимальное парциальное давление кислорода (pO2) в дыхательной смеси 1.2 - 1.6
Переключение дыхательных смесей
Планировщик бездекомпрессионного предела
Память для журнала измерений ~42 ч (интервал регистрации данных – 20 с)
Создание ярлыков журнала
Изменение интервалов регистрации данных в журнале 1, 10, 20, 30, 60 с
Журнал погружений время работы от аккумулятора
Время погружения
Давление в баллоне
Высокое парциальное давление pO2 (гипероксия)
Слишком быстрое всплытие
Выход за верхний декомпрессионный предел
Вычисление ЦНС (%) + ед. токсичности кислорода (коэффициент предельного насыщения) 80% / 100%
Переключение газовой смеси (на более подходящую, если имеется)
ФУНКЦИИ ДЛЯ АКТИВНОГО ОТДЫХА
Диапазон отображения температуры от -20 °C до +50 °C (+/- 2 °C)
Дискретность температуры 1 °C
Термометр
РУКОВОДСТВА ПОЛЬЗОВАТЕЛЯ
Руководства пользователя содержат комплексный обзор возможностей продуктов, инструкции по использованию, рекомендации по эксплуатации и хранению, а также технические характеристики.
Для просмотра руководства используйте Adobe Reader.
Загрузить PDF
Выберите язык
ОБУЧАЮЩИЕ ВИДЕОРОЛИКИ
Исследуйте новые функции, получите полезные советы, просмотрите пошаговые инструкции и узнайте, как другие пользуются устройствами Suunto.
Посмотрите наши видеоролики.
СРЕДСТВО ПОИСКА ДИЛЕРОВ И СЕРВИС-ЦЕНТРОВ
Найдите ближайший к вам авторизованный сервисный или дилерский центр Suunto.
Открыть средство поиска дилеров.
Замена аккумуляторов на компьютерах для погружений и устройствах
Компания Suunto рекомендует проводить замену аккумуляторов компьютеров для погружений и устройств в авторизованном сервисном центре. Чтобы найти ближайший сервисный центр, используйте Инструмент поиска дилерского центра Suunto, просто выбрав сервисный центр и категорию продукции. Чтобы узнать, где можно отремонтировать изделия Suunto, воспользуйтесь интерактивной службой запроса обслуживания, по ссылке . Страны, в которых доступно обслуживание, перечислены на странице онлайн-запроса обслуживания.
Преимущества обращения в авторизованные сервисные центры Suunto:
  • Замена изношенных или поврежденных частей в дополнение к замене аккумуляторов, уплотнительных колец, прокладок и других механических частей.
  • Замена аккумуляторов новыми (с полным зарядом) и использование для замены частей, соответсвующих техническим требованиям компании Suunto, что обеспечивает указанный срок службы аккумуляторов и сохранение стабильной работы изделий.
  • Предотвращение повреждения компьютера для погружений случайным электростатическим разрядом, так как замена аккумуляторов выполняется в защищенных от электростатических разрядов условиях.
  • Проверка изделий после обслуживания, чтобы убедиться в правильности работы и водонепроницаемости.
  • Проведение обслуживания силами персонала, обученного компаний Suunto, с использованием надлежащих инструментов и оригинальных запасных частей Suunto, что обеспечивает наилучшее обслуживание компьютера.
  • Трехмесячная гарантия с даты ремонта в случае выполнения ремонта авторизованной обслуживающей организацией.
Suunto DM5 — программное обеспечение для планирования и отслеживания погружений на ПК и Мас
Приложение Suunto DM5 позволяет загружать журналы погружений для детального анализа, создавать планы погружений и переносить их на компьютер для погружений. Эту программу можно загрузить бесплатно. Suunto DM5 предлагается с интерфейсом на английском, нидерландском, французском, финском, немецком, японском, корейском, испанском и китайском языках. Минимальные требования к ОС: Mac 10.7 или Windows XP. Узнайте больше о DM5.
Преимущества использования Suunto DM5:
  • В графическом средстве планирования погружений Suunto DM5 легко составить план погружения, выбрать газовую смесь, подготовить резервные планы. Затем можно перенести запланированные газовые смеси и другую необходимую для погружения информацию на компьютер для погружений (только в некоторых моделях). С помощью DM5 также можно распечатать инструкции по подготовке газовых смесей.
  • После погружения можно перенести журналы погружений в DM5. Все погружения хранятся в журнале, где можно просматривать, анализировать и упорядочивать их по дате, типу и снаряжению. Погружениям можно присвоить особые метки, чтобы сортировать в соответствии с личными предпочтениями. Кроме того, можно выбрать несколько погружений и сравнить их друг с другом.
  • Также можно сохранить данные погружений на веб-сайте Suunto Movescount и поделиться ими с друзьями.
Загрузите Suunto DM5 бесплатно здесь:
ДЛЯ WINDOWS
ДЛЯ MAC
НАПИШИТЕ НАМ
Мы оказываем поддержку на следующих языках: китайский, английский, испанский, итальянский, немецкий, русский, финский, французский, шведский и японский.
1. Связаться через MySuunto.
ВХОД
РЕГИСТРАЦИЯ
Что такое MySuunto?
2. Оставить сообщение ниже (регистрация не требуется)
ЗАДАТЬ ВОПРОС
Мы приложим все усилия, чтобы ответить вам в ближайшие дни. Однако, если вам требуется срочная помощь, позвоните нам.
ПОЗВОНИТЬ
Круглосуточная поддержка на английском языке:
Служба поддержки работает с 9:00 до 17:00 по местному времени (только рабочие дни):
Если ваша страна здесь не представлена, телефонные звонки подлежат оплате по международному тарифу вашего оператора связи. Ваш телефонный звонок может быть записан или прослушан в целях контроля качества обслуживания или обучения сотрудников.
МЕЖДУНАРОДНАЯ ОГРАНИЧЕННАЯ ГАРАНТИЯ SUUNTO - Спортивные часы, компьютеры для погружений и высокоточные приборы
Компания Suunto гарантирует, что в течение гарантийного срока компания Suunto или авторизованный сервисный центр Suunto (в дальнейшем называемый Сервисным центром) будет бесплатно устранять дефекты в материалах или сборке одним из следующих способов, выбранных по своему усмотрению: а) ремонт, б) замена, в) возмещение стоимости устройства при условии соблюдения положений данной ограниченной гарантии. Данная международная ограниченная гарантия действует и применяется независимо от страны приобретения. Международная ограниченная гарантия не влияет на ваши права, определенные обязательным к применению национальным законодательством о продаже потребительских товаров.
Срок действия гарантии
Отсчет срока международной ограниченной гарантии начинается с даты первоначальной розничной покупки.
Продолжительность гарантийного срока для Устройств и Передатчиков для погружений составляет два (2) года, если не указано иное.
Продолжительность гарантийного срока составляет один (1) год для принадлежностей, включая без ограничений беспроводные датчики, зарядные устройства, кабели, перезаряжаемые аккумуляторные батареи, ремешки, браслеты и шланги.
Для всех часов Suunto Spartan, приобретенных в 2016 году, гарантийный период продлен до трех (3) лет.
Исключения и ограничения
Настоящая международная ограниченная гарантия не охватывает:
  1. a) обычный износ, например, царапины, потертости и изменения цвета и (или) материала неметаллических ремешков, б) дефекты, вызванные неосторожным обращением, и в) дефекты и повреждения, вызванные неправильной или противоречащей инструкциям эксплуатацией устройства, ненадлежащим уходом, небрежным обращением и авариями, такими как падение или раздавливание устройства;
  2. печатные материалы и упаковку;
  3. дефекты и предполагаемые дефекты, вызванные совместным использованием с любым продуктом, принадлежностью, программным обеспечением и/или услугой, которые не были произведены / не поставлялись компанией Suunto;
  4. батареи, не поддерживающие перезарядку.
Suunto не гарантирует, что эксплуатация Устройства или принадлежности будет происходить без сбоев или ошибок, или что Устройство или принадлежность будут совместимы с каким-либо оборудованием или программным обеспечением сторонних производителей.
Настоящая международная ограниченная гарантия на устройство или принадлежность перестает действовать в следующих случаях:
  1. вскрытия устройства с нарушением правил использования;
  2. ремонта устройства с использованием неутвержденных запасных частей; модификации или ремонта в сервисных центрах, не являющихся авторизованными Сервисными центрами;
  3. удаления, изменения, порчи серийного номера устройства или иных действий, делающих его нечитаемым; решение по этому вопросу принимается по усмотрению компании Suunto; либо
  4. воздействие на устройство химических веществ, включая, без ограничений, солнцезащитный крем и репеллент от насекомых.
Обращение за гарантийным обслуживанием Suunto
Чтобы воспользоваться гарантийным обслуживанием Suunto, необходимо предоставить документы, подтверждающие приобретение устройства. Следует также зарегистрировать продукт онлайн на сайте www.suunto.com/mysuunto, чтобы получать услуги международной гарантии по всему миру. Дополнительные сведения о получении гарантийных услуг можно узнать на странице www.suunto.com/warranty, у местного официального розничного продавца Suunto или позвонив в контактный центр Suunto.
Ограничение ответственности
В максимальной степени, допускаемой применимым законодательством, настоящая международная ограниченная гарантия является единственным и исключительным средством судебной защиты и заменяет собой все остальные явно выраженные или подразумеваемые гарантии. Компания Suunto не несет ответственности за специфические, случайные, штрафные или косвенные убытки, включая, помимо прочего, потерю предполагаемой прибыли, потерю данных, утрату возможности эксплуатации, стоимость капитала, стоимость любого заместительного оборудования или заместительных средств, претензии третьих лиц, ущерб собственности, нанесенный в результате приобретения или использования данного изделия или в результате нарушения условий гарантии, договора, небрежности, строгого правонарушения или любого другого юридического или объективного обоснования, даже если компании Suunto было известно о вероятности возникновения такого ущерба. Компания Suunto не несет ответственности за задержки в предоставлении гарантийного обслуживания.
МЕЖДУНАРОДНАЯ ОГРАНИЧЕННАЯ ГАРАНТИЯ SUUNTO - Полевые компасы
Suunto гарантирует, что в течение гарантийного срока компания Suunto или авторизованный сервисный центр Suunto будут бесплатно устранять дефекты материалов и ошибки сборки одним из следующих способов, выбранных по своему усмотрению: а) ремонт б) замена в) возмещение стоимости устройства при условии соблюдения положений настоящей международной ограниченной гарантии. Настоящая международная ограниченная гарантия не охватывает а) естественный износ б) небрежное обращение в) внесение технических изменений г) воздействие химических веществ д) ненадлежащее использование. Если действующим законодательством не установлено иное, а) настоящая международная ограниченная гарантия действует и имеет законную силу независимо от страны приобретения изделия б) чтобы воспользоваться гарантийным обслуживанием согласно настоящей международной ограниченной гарантии, необходимо зарегистрироваться на сайте www.suunto.com/mysuunto и предоставить доказательство покупки. Настоящая международная ограниченная гарантия не затрагивает ваши законные права, определенные действующим законодательством о реализации потребительских товаров.
Международная ограниченная пожизненная гарантия
Распространяется на компасы Suunto серий A, M, MC, MB и Clipper.
Период действия международной гарантии ограничен разумным периодом времени, по истечении которого продукт становится объективно непригодным для использования по причине естественного износа.
Международная ограниченная двухлетняя гарантия
Распространяется на компасы Suunto серий AIM, Arrow, Orca-Pioneer и KB.
Период действия международной ограниченной гарантии составляет два года, начиная с даты розничной покупки товара.
В МАКСИМАЛЬНОЙ СТЕПЕНИ, РАЗРЕШЕННОЙ ДЕЙСТВУЮЩИМ ЗАКОНОДАТЕЛЬСТВОМ, НАСТОЯЩАЯ МЕЖДУНАРОДНАЯ ОГРАНИЧЕННАЯ ГАРАНТИЯ ЯВЛЯЕТСЯ ВАШИМ ЕДИНСТВЕННЫМ И ИСКЛЮЧИТЕЛЬНЫМ СРЕДСТВОМ ПРАВОВОЙ ЗАЩИТЫ И ЗАМЕНЯЕТ СОБОЙ ЛЮБЫЕ ДРУГИЕ ГАРАНТИИ, ЯВНЫЕ ИЛИ ПОДРАЗУМЕВАЕМЫЕ. КОМПАНИЯ SUUNTO НЕ НЕСЕТ ОТВЕТСТВЕННОСТИ ЗА ЛЮБЫЕ ОСОБЫЕ, СЛУЧАЙНЫЕ, ШТРАФНЫЕ ИЛИ СОПУТСТВУЮЩИЕ УБЫТКИ. КОМПАНИЯ SUUNTO НЕ НЕСЕТ ОТВЕТСТВЕННОСТИ ЗА ЗАДЕРЖКИ В ПРОЦЕССЕ ПРЕДОСТАВЛЕНИЯ ГАРАНТИЙНОГО ОБСЛУЖИВАНИЯ.
ОГРАНИЧЕННАЯ МЕЖДУНАРОДНАЯ ГАРАНТИЯ SUUNTO
Suunto гарантирует, что в течение определенного ниже Гарантийного срока компания Suunto или Авторизованный сервисный центр Suunto будут бесплатно устранять дефекты, вызванные низким качеством материалов или изготовления, одним из следующих способов, выбранных по своему усмотрению: а) ремонт, б) замена на аналогичный продукт или в) возмещение стоимости при условии соблюдения положений настоящей Ограниченной международной гарантии. Настоящая Ограниченная международная гарантия не охватывает а) естественный износ, б) небрежное обращение, в) внесение технических изменений, г) воздействие химических веществ и д) ненадлежащее использование. Если действующим законодательством не установлено иное, то а) настоящая Ограниченная международная гарантия является действительной и имеет юридическую силу независимо от страны приобретения продукта, и б) чтобы воспользоваться гарантийным обслуживанием по Ограниченной международной гарантии, необходимо зарегистрироваться на сайте www.suunto.com/mysuunto и предоставить доказательство покупки. Настоящая Ограниченная международная гарантия не затрагивает ваши законные права, определяемые действующим законодательством о продаже потребительских товаров.
Гарантийный срок
Ограниченная международная пожизненная гарантия:
Действует в отношении компасов Suunto A, M, MC, MB и Clipper.
Гарантийный срок по этой международной гарантии ограничен разумным периодом времени, по истечении которого продукт становится объективно непригодным для использования по причине естественного износа.
Ограниченная международная двухлетняя гарантия:
Действует в отношении компасов Suunto AIM, Arrow, Orca-Pioneer и KB.
Гарантийный срок по этой международной гарантии ограничен двумя годами, начиная с даты первоначальной розничной покупки продукта.
В МАКСИМАЛЬНОЙ СТЕПЕНИ, РАЗРЕШЕННОЙ ДЕЙСТВУЮЩИМ ЗАКОНОДАТЕЛЬСТВОМ, НАСТОЯЩАЯ ОГРАНИЧЕННАЯ МЕЖДУНАРОДНАЯ ГАРАНТИЯ ЯВЛЯЕТСЯ ВАШИМ ЕДИНСТВЕННЫМ И ИСКЛЮЧИТЕЛЬНЫМ СРЕДСТВОМ ПРАВОВОЙ ЗАЩИТЫ И ЗАМЕНЯЕТ СОБОЙ ЛЮБЫЕ ДРУГИЕ ГАРАНТИИ, ЯВНЫЕ ИЛИ ПОДРАЗУМЕВАЕМЫЕ. КОМПАНИЯ SUUNTO НЕ НЕСЕТ ОТВЕТСТВЕННОСТЬ ЗА ЛЮБЫЕ ОСОБЫЕ, СЛУЧАЙНЫЕ, ШТРАФНЫЕ ИЛИ СОПУТСТВУЮЩИЕ УБЫТКИ. КОМПАНИЯ SUUNTO НЕ НЕСЕТ ОТВЕТСТВЕННОСТЬ ЗА ЗАДЕРЖКИ ПРИ ПРОВЕДЕНИИ ГАРАНТИЙНОГО ОБСЛУЖИВАНИЯ.
Отремонтируйте продукт Suunto, отправив сервисную заявку через Интернет. Раскройте вкладку сервисной онлайн-заявки ниже, чтобы проверить доступность этой услуги в вашей стране.
Если ваша страна не указана в списке, или же в обслуживании нуждается компас или точный прибор, найдите ближайший сервисный центр с помощью  средства поиска дилерского центра Suunto  — просто выберите сервисный центр и категорию изделия.
Находясь в одной из следующих стран, вы можете отправить сервисную заявку через Интернет. Если ваша страна не указана в списке, или же в обслуживании нуждается компас или точный прибор, найдите ближайший сервисный центр с помощью средства поиска дилерского центра Suunto — просто выберите сервисный центр и категорию изделия.
ВАЖНО!
Ремонт занимает примерно семь рабочих дней. Если гарантийный срок продукта истек, мы отправим вам оценку стоимости предстоящего ремонта, прежде чем приступать к нему. Если вы отклоните эту оценку, мы возвратим вам продукт и выставим вам счет на фиксированную сумму за анализ неполадок и транспортные расходы. Сумма по счету может различаться в зависимости от страны.
Инструкция по отправке сервисной заявки через Интернет:
  • 1. Вам потребуется действующий адрес электронной почты, серийный номер устройства и принтер.
  • 2. Выберите свою страну из списка.
  • 3. Введите необходимую информацию. Будут автоматически созданы транспортно-сопроводительные документы, которые нужно распечатать. Отправляя нам устройство, приложите к нему эти документы.
  • 4. Получив подтверждение, позвоните курьеру по указанному номеру телефона, и он заберет ваше устройство.
  • 5. Не отправляйте нам руководство пользователя, инструкции по эксплуатации или упаковку. Мы не сможем их вернуть.
  • 6. Если на устройство не распространяется гарантия, мы вышлем условия оплаты по электронной почте. Оплата производится с помощью защищенного платежа PayPal.
  • 7. Отремонтированное устройство будет возвращено по адресу, указанному вами при заполнении сервисной заявки.
Австралия
Австрия
Бельгия
Болгария
Хорватия
Кипр
Чехия
Дания
Эстония
Финляндия
Франция
Германия
Греция
Венгрия
Ирландия
Италия
Латвия
Литва
Люксембург
Малайзия
Мальта
Нидерланды
Новая Зеландия
Норвегия
Польша
Португалия
Румыния
Сингапур
Словакия
Словения
Испания
Швеция
Швейцария
Великобритания
США
Suunto имеет широкую сеть авторизованных сервисных центров в разных странах, чтобы помочь вам с ремонтом и техническим обслуживанием. Вы можете найти ближайший к вам сервисный центр, используя Инструмент поиска дилерского центра Suunto — просто выберите сервисный центр и категорию продукции.
Вы также можете обратиться в службу поддержки клиентов Suunto, чтобы найти оптимальный способ обслуживания для вашего устройства.
