Share
REF SS014443010 / Выпуск этого продукта прекращен
Suunto Core Alu Alu
Essential outdoor functions in an aluminium case, aluminium strap
Every great adventure starts from within. From a drive to seek out new places and discover new experiences. Your passion is our inspiration. Suunto Core is the essential outdoor watch with a pioneering spirit designed to bring out the explorer in you.
The award-winning Suunto Core gathers a range of data to help you navigate your way through the wilder parts of the world.
Altimeter
The altimeter features a range up to 9000 m (29 500 ft). It is ideally suited for all activities where knowing your altitude and ascent and descent rates is essential. The Core altimeter sports an altitude difference measurement that allows you to track your progress in terms of altitude climbed. The log recorder stores all your movements in altitude between the start and stop times, so you can re-live your trip at home - view graphs of changes in altitude during your treks, find out how much you climbed, the duration of ascents and descents, average ascent and descent speed and more.
Barometer
Suunto Core displays the current sea level pressure as a detailed graph, showing recording of the last 24 hours with a recording interval of 30 minutes. The weather trend indicator is a useful feature providing quick reference to check upcoming weather conditions. The storm alarm notifies you of a sudden drop in air pressure, which may be related to worsening weather conditions.
Automatic Alti/Baro switch
Suunto Core sports an Automatic Alti/Baro switch, a smart feature that senses your movement or lack thereof, switching between altimeter and barometer accordingly. When you’re climbing, it records changes in elevation. And when you stop to rest, it records changes in barometric pressure. A drop in air pressure while you’re sleeping under the stars will be recorded for what it really is: a change in barometric pressure, not altitude
Compass
The digital compass displays the cardinal or half-cardinal point and the North. The declination adjustment function allows you to correct the difference between the true North and magnetic North. You can also set it to track a certain bearing, which helps you follow a chosen direction in the terrain. The compass features a rotating bezel for traditional use (most variants), or a one-touch function that allows you to sight lock and follow a bearing.
Depth meter
Intended for snorkeling, the Suunto Core depth meter provides information on current depth and the maximum depth reached during your snorkeling dive. The maximum depth of the device is 10 m (32,8 ft).
Watch
Watch functions include time, dual time, date, alarm, sports chronograph, countdown timer and predicted times for sunrise and sunset for over 400 locations worldwide.
Suunto Core is available in a range of styles and materials.
ОСОБЕННОСТИ МОДЕЛИ
  • Альтиметр, барометр, компас
  • Функции погоды
  • Использование при восхождениях и в повседневной жизни
14  Продукты
  • Altimeter with altitude log memory and altitude difference measurement
  • Barometer with storm alarm and weather trend indicator
  • Automatic Alti / Baro switch
  • Compass with semi automatic calibration and a digital bearing
  • Depth meter
  • Multiple watch, date and alarm functions with dual time and countdown timer
  • Sunrise/Sunset times for over 400 locations worldwide
  • Digital thermometer
  • Menu based user interface in English, German, French and Spanish
  • Available in a range of styles
  • Accessory straps
  • User-replaceable battery
Размеры 49,1  x  49,1  x  14,5  мм
Вес 102 г
Размеры 1,93  x  1,93 x  0,57 "
Вес 3,6 у
Материал безеля: Алюминий
Материал стекла: Минеральный хрусталь
Материал корпуса: Композит
Материал ремешка: Силикон
Suunto Core Alu Alu – Технические характеристики
Вес 102 г / 3,6 у
Водостойкий 30 м (в соответствии с ISO 6425)
Время работы батареи в режиме времени 12 месяцев
Тип батареи CR2032
Сменная батарея
Время, дата
Будильник 1 ежедневная подача сигнала
Время для двух часовых поясов
Таймер обратного отсчета
Секундомер
Языки Английский, немецкий, испанский, французский
Подсветка электролюминесцентная
Настраиваемая подсветка активация: 1 кнопка, все кнопки
Блокировка кнопок
Тип дисплея матричный
Индикатор заряда батареи индикатор низкого заряда батареи
Метрическая и британская системы измерения
Цифровой компас
Шкала направления градусы
Стрелка указатель направления на север
Фиксация курса с индикатором ориентирования
Точность компаса
Дискретность компаса
Рабочая температура от -20 °C до +60 °C
Температура хранения от -30 °C до +60 °C
ФУНКЦИИ ДЛЯ ПОГРУЖЕНИЯ
Глубиномер для подводного плавания с трубкой 10 м
ФУНКЦИИ ДЛЯ АКТИВНОГО ОТДЫХА
Барометрический альтиметр
График высот над уровнем моря
Общий подъем/спуск на основании атмосферного давления
Автопереключение профиля высотомера и барометра
Перепад высот над уровнем моря
Интервал регистрации в журнале 1, 5, 10, 30, 60 с
Дискретность 1 м
Диапазон -500 – 9 000 м
Атмосферное давление
График изменения атмосферного давления
Индикатор прогноза погоды
Термометр
Диапазон отображения температуры от -20 °C до +60 °C
Время восхода/захода солнца
Штормовое предупреждение
Дискретность давления 1 гПа / 0,76 мм рт. ст.
Дискретность температуры
Макс. продолжительность регистрации погоды 7 дней
РУКОВОДСТВА ПОЛЬЗОВАТЕЛЯ
Руководства пользователя содержат комплексный обзор возможностей продуктов, инструкции по использованию, рекомендации по эксплуатации и хранению, а также технические характеристики.
Для просмотра руководства используйте Adobe Reader.
Загрузить PDF
ОБУЧАЮЩИЕ ВИДЕОРОЛИКИ
Исследуйте новые функции, получите полезные советы, просмотрите пошаговые инструкции и узнайте, как другие пользуются устройствами Suunto.
Посмотрите наши видеоролики.
СРЕДСТВО ПОИСКА ДИЛЕРОВ И СЕРВИС-ЦЕНТРОВ
Найдите ближайший к вам авторизованный сервисный или дилерский центр Suunto.
Открыть средство поиска дилеров.
НАПИШИТЕ НАМ
Мы оказываем поддержку на следующих языках: китайский, английский, испанский, итальянский, немецкий, русский, финский, французский, шведский и японский.
1. Связаться через MySuunto.
ВХОД
РЕГИСТРАЦИЯ
Что такое MySuunto?
2. Оставить сообщение ниже (регистрация не требуется)
ЗАДАТЬ ВОПРОС
Мы приложим все усилия, чтобы ответить вам в ближайшие дни. Однако, если вам требуется срочная помощь, позвоните нам.
ПОЗВОНИТЬ
Круглосуточная поддержка на английском языке:
Служба поддержки работает с 9:00 до 17:00 по местному времени (только рабочие дни):
Если ваша страна здесь не представлена, телефонные звонки подлежат оплате по международному тарифу вашего оператора связи. Ваш телефонный звонок может быть записан или прослушан в целях контроля качества обслуживания или обучения сотрудников.
МЕЖДУНАРОДНАЯ ОГРАНИЧЕННАЯ ГАРАНТИЯ SUUNTO - Спортивные часы, компьютеры для погружений и высокоточные приборы
Компания Suunto гарантирует, что в течение гарантийного срока компания Suunto или авторизованный сервисный центр Suunto (в дальнейшем называемый Сервисным центром) будет бесплатно устранять дефекты в материалах или сборке одним из следующих способов, выбранных по своему усмотрению: а) ремонт, б) замена, в) возмещение стоимости устройства при условии соблюдения положений данной ограниченной гарантии. Данная международная ограниченная гарантия действует и применяется независимо от страны приобретения. Международная ограниченная гарантия не влияет на ваши права, определенные обязательным к применению национальным законодательством о продаже потребительских товаров.
Срок действия гарантии
Отсчет срока международной ограниченной гарантии начинается с даты первоначальной розничной покупки.
Продолжительность гарантийного срока для Устройств и Передатчиков для погружений составляет два (2) года, если не указано иное.
Продолжительность гарантийного срока составляет один (1) год для принадлежностей, включая без ограничений беспроводные датчики, зарядные устройства, кабели, перезаряжаемые аккумуляторные батареи, ремешки, браслеты и шланги.
Для всех часов Suunto Spartan, приобретенных в 2016 году, гарантийный период продлен до трех (3) лет.
Исключения и ограничения
Настоящая международная ограниченная гарантия не охватывает:
  1. a) обычный износ, например, царапины, потертости и изменения цвета и (или) материала неметаллических ремешков, б) дефекты, вызванные неосторожным обращением, и в) дефекты и повреждения, вызванные неправильной или противоречащей инструкциям эксплуатацией устройства, ненадлежащим уходом, небрежным обращением и авариями, такими как падение или раздавливание устройства;
  2. печатные материалы и упаковку;
  3. дефекты и предполагаемые дефекты, вызванные совместным использованием с любым продуктом, принадлежностью, программным обеспечением и/или услугой, которые не были произведены / не поставлялись компанией Suunto;
  4. батареи, не поддерживающие перезарядку.
Suunto не гарантирует, что эксплуатация Устройства или принадлежности будет происходить без сбоев или ошибок, или что Устройство или принадлежность будут совместимы с каким-либо оборудованием или программным обеспечением сторонних производителей.
Настоящая международная ограниченная гарантия на устройство или принадлежность перестает действовать в следующих случаях:
  1. вскрытия устройства с нарушением правил использования;
  2. ремонта устройства с использованием неутвержденных запасных частей; модификации или ремонта в сервисных центрах, не являющихся авторизованными Сервисными центрами;
  3. удаления, изменения, порчи серийного номера устройства или иных действий, делающих его нечитаемым; решение по этому вопросу принимается по усмотрению компании Suunto; либо
  4. воздействие на устройство химических веществ, включая, без ограничений, солнцезащитный крем и репеллент от насекомых.
Обращение за гарантийным обслуживанием Suunto
Чтобы воспользоваться гарантийным обслуживанием Suunto, необходимо предоставить документы, подтверждающие приобретение устройства. Следует также зарегистрировать продукт онлайн на сайте www.suunto.com/mysuunto, чтобы получать услуги международной гарантии по всему миру. Дополнительные сведения о получении гарантийных услуг можно узнать на странице www.suunto.com/warranty, у местного официального розничного продавца Suunto или позвонив в контактный центр Suunto.
Ограничение ответственности
В максимальной степени, допускаемой применимым законодательством, настоящая международная ограниченная гарантия является единственным и исключительным средством судебной защиты и заменяет собой все остальные явно выраженные или подразумеваемые гарантии. Компания Suunto не несет ответственности за специфические, случайные, штрафные или косвенные убытки, включая, помимо прочего, потерю предполагаемой прибыли, потерю данных, утрату возможности эксплуатации, стоимость капитала, стоимость любого заместительного оборудования или заместительных средств, претензии третьих лиц, ущерб собственности, нанесенный в результате приобретения или использования данного изделия или в результате нарушения условий гарантии, договора, небрежности, строгого правонарушения или любого другого юридического или объективного обоснования, даже если компании Suunto было известно о вероятности возникновения такого ущерба. Компания Suunto не несет ответственности за задержки в предоставлении гарантийного обслуживания.
МЕЖДУНАРОДНАЯ ОГРАНИЧЕННАЯ ГАРАНТИЯ SUUNTO - Полевые компасы
Suunto гарантирует, что в течение гарантийного срока компания Suunto или авторизованный сервисный центр Suunto будут бесплатно устранять дефекты материалов и ошибки сборки одним из следующих способов, выбранных по своему усмотрению: а) ремонт б) замена в) возмещение стоимости устройства при условии соблюдения положений настоящей международной ограниченной гарантии. Настоящая международная ограниченная гарантия не охватывает а) естественный износ б) небрежное обращение в) внесение технических изменений г) воздействие химических веществ д) ненадлежащее использование. Если действующим законодательством не установлено иное, а) настоящая международная ограниченная гарантия действует и имеет законную силу независимо от страны приобретения изделия б) чтобы воспользоваться гарантийным обслуживанием согласно настоящей международной ограниченной гарантии, необходимо зарегистрироваться на сайте www.suunto.com/mysuunto и предоставить доказательство покупки. Настоящая международная ограниченная гарантия не затрагивает ваши законные права, определенные действующим законодательством о реализации потребительских товаров.
Международная ограниченная пожизненная гарантия
Распространяется на компасы Suunto серий A, M, MC, MB и Clipper.
Период действия международной гарантии ограничен разумным периодом времени, по истечении которого продукт становится объективно непригодным для использования по причине естественного износа.
Международная ограниченная двухлетняя гарантия
Распространяется на компасы Suunto серий AIM, Arrow, Orca-Pioneer и KB.
Период действия международной ограниченной гарантии составляет два года, начиная с даты розничной покупки товара.
В МАКСИМАЛЬНОЙ СТЕПЕНИ, РАЗРЕШЕННОЙ ДЕЙСТВУЮЩИМ ЗАКОНОДАТЕЛЬСТВОМ, НАСТОЯЩАЯ МЕЖДУНАРОДНАЯ ОГРАНИЧЕННАЯ ГАРАНТИЯ ЯВЛЯЕТСЯ ВАШИМ ЕДИНСТВЕННЫМ И ИСКЛЮЧИТЕЛЬНЫМ СРЕДСТВОМ ПРАВОВОЙ ЗАЩИТЫ И ЗАМЕНЯЕТ СОБОЙ ЛЮБЫЕ ДРУГИЕ ГАРАНТИИ, ЯВНЫЕ ИЛИ ПОДРАЗУМЕВАЕМЫЕ. КОМПАНИЯ SUUNTO НЕ НЕСЕТ ОТВЕТСТВЕННОСТИ ЗА ЛЮБЫЕ ОСОБЫЕ, СЛУЧАЙНЫЕ, ШТРАФНЫЕ ИЛИ СОПУТСТВУЮЩИЕ УБЫТКИ. КОМПАНИЯ SUUNTO НЕ НЕСЕТ ОТВЕТСТВЕННОСТИ ЗА ЗАДЕРЖКИ В ПРОЦЕССЕ ПРЕДОСТАВЛЕНИЯ ГАРАНТИЙНОГО ОБСЛУЖИВАНИЯ.
ОГРАНИЧЕННАЯ МЕЖДУНАРОДНАЯ ГАРАНТИЯ SUUNTO
Suunto гарантирует, что в течение определенного ниже Гарантийного срока компания Suunto или Авторизованный сервисный центр Suunto будут бесплатно устранять дефекты, вызванные низким качеством материалов или изготовления, одним из следующих способов, выбранных по своему усмотрению: а) ремонт, б) замена на аналогичный продукт или в) возмещение стоимости при условии соблюдения положений настоящей Ограниченной международной гарантии. Настоящая Ограниченная международная гарантия не охватывает а) естественный износ, б) небрежное обращение, в) внесение технических изменений, г) воздействие химических веществ и д) ненадлежащее использование. Если действующим законодательством не установлено иное, то а) настоящая Ограниченная международная гарантия является действительной и имеет юридическую силу независимо от страны приобретения продукта, и б) чтобы воспользоваться гарантийным обслуживанием по Ограниченной международной гарантии, необходимо зарегистрироваться на сайте www.suunto.com/mysuunto и предоставить доказательство покупки. Настоящая Ограниченная международная гарантия не затрагивает ваши законные права, определяемые действующим законодательством о продаже потребительских товаров.
Гарантийный срок
Ограниченная международная пожизненная гарантия:
Действует в отношении компасов Suunto A, M, MC, MB и Clipper.
Гарантийный срок по этой международной гарантии ограничен разумным периодом времени, по истечении которого продукт становится объективно непригодным для использования по причине естественного износа.
Ограниченная международная двухлетняя гарантия:
Действует в отношении компасов Suunto AIM, Arrow, Orca-Pioneer и KB.
Гарантийный срок по этой международной гарантии ограничен двумя годами, начиная с даты первоначальной розничной покупки продукта.
В МАКСИМАЛЬНОЙ СТЕПЕНИ, РАЗРЕШЕННОЙ ДЕЙСТВУЮЩИМ ЗАКОНОДАТЕЛЬСТВОМ, НАСТОЯЩАЯ ОГРАНИЧЕННАЯ МЕЖДУНАРОДНАЯ ГАРАНТИЯ ЯВЛЯЕТСЯ ВАШИМ ЕДИНСТВЕННЫМ И ИСКЛЮЧИТЕЛЬНЫМ СРЕДСТВОМ ПРАВОВОЙ ЗАЩИТЫ И ЗАМЕНЯЕТ СОБОЙ ЛЮБЫЕ ДРУГИЕ ГАРАНТИИ, ЯВНЫЕ ИЛИ ПОДРАЗУМЕВАЕМЫЕ. КОМПАНИЯ SUUNTO НЕ НЕСЕТ ОТВЕТСТВЕННОСТЬ ЗА ЛЮБЫЕ ОСОБЫЕ, СЛУЧАЙНЫЕ, ШТРАФНЫЕ ИЛИ СОПУТСТВУЮЩИЕ УБЫТКИ. КОМПАНИЯ SUUNTO НЕ НЕСЕТ ОТВЕТСТВЕННОСТЬ ЗА ЗАДЕРЖКИ ПРИ ПРОВЕДЕНИИ ГАРАНТИЙНОГО ОБСЛУЖИВАНИЯ.
Отремонтируйте продукт Suunto, отправив сервисную заявку через Интернет. Раскройте вкладку сервисной онлайн-заявки ниже, чтобы проверить доступность этой услуги в вашей стране.
Если ваша страна не указана в списке, или же в обслуживании нуждается компас или точный прибор, найдите ближайший сервисный центр с помощью  средства поиска дилерского центра Suunto  — просто выберите сервисный центр и категорию изделия.
Находясь в одной из следующих стран, вы можете отправить сервисную заявку через Интернет. Если ваша страна не указана в списке, или же в обслуживании нуждается компас или точный прибор, найдите ближайший сервисный центр с помощью средства поиска дилерского центра Suunto — просто выберите сервисный центр и категорию изделия.
ВАЖНО!
Ремонт занимает примерно семь рабочих дней. Если гарантийный срок продукта истек, мы отправим вам оценку стоимости предстоящего ремонта, прежде чем приступать к нему. Если вы отклоните эту оценку, мы возвратим вам продукт и выставим вам счет на фиксированную сумму за анализ неполадок и транспортные расходы. Сумма по счету может различаться в зависимости от страны.
Инструкция по отправке сервисной заявки через Интернет:
  • 1. Вам потребуется действующий адрес электронной почты, серийный номер устройства и принтер.
  • 2. Выберите свою страну из списка.
  • 3. Введите необходимую информацию. Будут автоматически созданы транспортно-сопроводительные документы, которые нужно распечатать. Отправляя нам устройство, приложите к нему эти документы.
  • 4. Получив подтверждение, позвоните курьеру по указанному номеру телефона, и он заберет ваше устройство.
  • 5. Не отправляйте нам руководство пользователя, инструкции по эксплуатации или упаковку. Мы не сможем их вернуть.
  • 6. Если на устройство не распространяется гарантия, мы вышлем условия оплаты по электронной почте. Оплата производится с помощью защищенного платежа PayPal.
  • 7. Отремонтированное устройство будет возвращено по адресу, указанному вами при заполнении сервисной заявки.
Австралия
Австрия
Бельгия
Болгария
Хорватия
Кипр
Чехия
Дания
Эстония
Финляндия
Франция
Германия
Греция
Венгрия
Ирландия
Италия
Латвия
Литва
Люксембург
Малайзия
Мальта
Нидерланды
Новая Зеландия
Норвегия
Польша
Португалия
Румыния
Сингапур
Словакия
Словения
Испания
Швеция
Швейцария
Великобритания
США
Suunto имеет широкую сеть авторизованных сервисных центров в разных странах, чтобы помочь вам с ремонтом и техническим обслуживанием. Вы можете найти ближайший к вам сервисный центр, используя Инструмент поиска дилерского центра Suunto — просто выберите сервисный центр и категорию продукции.
Вы также можете обратиться в службу поддержки клиентов Suunto, чтобы найти оптимальный способ обслуживания для вашего устройства.
