Share
REF SS014587000 / 此产品已停产
Suunto Cobra3
Advanced air-integrated dive computer with electronic 3D compass
Suunto Cobra3 is an all-in-one console-mounted dive computer. It features air-integration, an electronic 3D compass, an easy-to-read matrix display, and simplified four-button operation.
Air integration
Suunto Cobra3 monitors and displays your tank pressure, tracks your rate of air consumption, and continuously calculates your remaining air time. It also provides visual and audible alarms for depth and pressure and warns you when you're running low on air.
Clear navigation
Suunto Cobra3 features a unique electronic 3D compass that can be tilted up to 45 degrees in any direction, making it easier to read the figures clearly and accurately under water.
Effortless operation
The easy-to-read dot matrix display and electro-luminescent backlight mean all your dive-critical information – including bearing, tank pressure, depth, and dive time – will all be shown clearly. And with the simplified four-button operation, the computer is easy to operate even when wearing gloves.
Multi-mode versatility
With its Nitrox, Air, and Gauge modes and gas-switching capabilities, Suunto Cobra3 delivers everything you need to maximize bottom time and make the most of every dive. When using enriched air, Suunto Cobra3 can be programmed for nitrox mixtures between 21% and 100% oxygen. You can also adjust oxygen partial pressure between 0.5 and 1.6 bar. In Gauge mode, it can also be used as a depth gauge and timer with profile memory.
Flexible decompression
Using the Suunto Deep Stop RGBM algorithm, Suunto Cobra3 enables continuous decompression for optimal ascent time. For deeper dives, the Deep Stop option adds further protection with a series of deep stops between your maximum depth and ceiling.
When in Nitrox mode, you can accelerate decompression by switching to a gas mix with a higher oxygen percentage. With Suunto Cobra3 it's quick and easy to switch between enabled gas mixes while diving.
Plan and review
You can test upcoming dives and view no-decompression and decompression time data for different depths before getting in the water with the built-in dive simulator. When the dive is over, get detailed graphical logs and dive data on your computer using Suunto DM4 software.
产品亮点
空气、高氧和仪表模式 3D 指南针 Suunto RGBM 易于阅读的矩阵显示屏
  • Air integrated for tank pressure information
  • Tiltable electronic 3D compass to keep you on course
  • User-friendly design featuring easy-to-read matrix display and simplified four-button operation
  • Three dive modes and gas-switching capability for a range of dive situations
  • Continuous decompression with the Suunto RGBM algorithm
  • Built-in dive simulator for planning upcoming dives
  • Optional computer interface for detailed graphical logbooks and dive data analysis
尺寸 73  x  165  x  35  毫米
重量 210
尺寸 2.87  x  6.5 x  1.38 "
重量 7.41 盎司
仪表盖材质: 合成材料
镜面材质 亚克力
外壳材质: 合成材料
表带材质: 人造橡胶
磁偏角修正
Suunto Cobra3 – 技术规格
仪表盖材质: 合成材料
镜面材质 亚克力
外壳材质: 合成材料
表带材质: 人造橡胶
重量 210 克 / 7.41 盎司
防水性 100 米 (ISO 13319)
时间模式下电池续航时间 3 年
电池寿命 100 次潜水/年 1.5 年
电池类型 CR 2450
用户可更换电池
时间、日期
闹钟 1 个日常警报
语言 英文
背光灯 电荧光
可配置背光 持续时间: 5、10、20、30、60 秒
显示屏类型 矩阵
显示屏分辨率 49 x 22
电池指示器 电量低指示器
公制和英制单位
数据传输 USB 线缆(可选)
兼容 DM5
兼容 Suunto Movescount 借助 DM5
数字指南针
倾斜补偿 最高 45°
方向刻度
指针 罗盘
全球平衡
方位锁定,带方向指示器
指南针精确度 10°
指南针分辨率
工作温度 0° C 至 +40° C / +32° F 至 +104° F
存放温度 -20 ° C 至 +50 ° C / -4° F 至 +122° F
潜水功能
最大工作深度 (EN 13319) 100 米
高氧(和空气)
仪表
潜水时间 0 至 999 分钟
水面时间 0 至 99 小时 59 分钟
禁飞时间
安全停留
深度停留
上升时间显示 0 - 99 分钟(99 后 - - )
CNS/OTU (OLF) 计算
软管气瓶残压指示
减压模型 SUUNTO RGBM
个人调整 0 - 2
海拔调整 0 - 300 米 / 300 -1500 米 / 1500 - 3000 米
气体 多达 2 种气体(氧气 21 - 99%)
气体最大 pO2 1.2 - 1.6
气体切换
免减压计划器
日志存储空间 约 42 小时(20 秒样本速度)
日志书签
日志采样率 1、10、20、30、60 秒
潜水记录 终身
潜水时间
最大深度
罐压
高 pO2(高氧)
过快上升
减压上限违反
CNS/OTU (OLF) 80% / 100%
气体切换(提供更好的气体)
户外功能
温度显示范围 -20° C 至 +50° C (+/- 2° C) / -9° C 至 +122° F (+/- 3.6° F)
温度分辨率 1° C / 1.5° F
温度
用户指南
用户指南提供对产品功能、使用方法、操作指南和技术规格的全面概述。
使用 Adobe Reader 查看。
下载 PDF
用法视频
搜索新功能,获取有用提示,观看分步说明并了解他人如何使用 Suunto 产品。
观看我们的视频。
经销商及服务中心定位器
查找附近的授权服务中心或 Suunto 经销商。
开启经销商定位器
潜水电脑和其他设备的电池更换
Suunto 建议由获授权的服务中心更换潜水电脑和其他设备的电池。您可以使用 Suunto 经销商定位器找到最近的服务中心 – 只需选择服中心和产品类别。您也可以通过在线服务申请修理您的 Suunto 产品。在线服务申请页面列出了可提供服务的国家。
使用获授权的 Suunto 服务中心的优势包括:
  • 除电池外,还会更换磨损或受损的 O 型圈、垫圈和其他机械零件。
  • 更换的电池是全新的(满容量),零件符合 Suunto 规格,确保电池如所规定般持久续航,产品完整无缺。
  • 因为电池是在安全的静电放电(ESD)环境下进行更换的,所以潜水电脑不会因为突然静电放电而受损。
  • 维修后会对产品进行测试,确保产品能正常工作并且防水。
  • 维修由受过 Suunto 训练的人员进行,使用合适的工具和 Suunto 原始备件,确保电脑得到最好的护理。
  • 由授权服务提供商修理的 Suunto 产品享有三(3)个月保修期,从修理之日起计算。
Suunto DM5 可以规划和跟踪潜水活动 — PC 版和 MAC 版
Suunto DM5 可帮助您下载潜水日志供进行高级分析,还可将详细潜水计划上传到潜水电脑。本程序提供免费下载。Suunto DM5 提供英语、荷兰语、法语、芬兰语、德语、日语、韩语、西班牙语和中文版本。最低操作系统要求:Mac 10.7 或 Windows XP。详细了解 DM5
使用 Suunto DM5 的优点包括:
  • 借助 Suunto DM5 图形化潜水规划器,可以轻松创建潜水档案、管理潜水用气以及备份计划。创建完毕后,可以将规划的潜水用气和其他关键潜水信息传输至潜水电脑(仅限特定型号)。此外,还可以从 DM5 打印气体混合说明。
  • 潜水结束后,可以将潜水日志传输到 DM5。潜水信息都存储在日志中,从中可以按日期、模式和装备来查看、分析、整理潜水活动。而善用标签功能,可以根据个人偏好来轻松标记和整理潜水活动。此外,您还可以选择多个潜水活动来互相比较。
  • 您也可以在 Suunto Movescount 中保存您的潜水活动并与好友分享。
在此免费下载 Suunto DM5:
WINDOWS 版
MAC 版
致函我们
获取中文、英语、芬兰语、法语、德语、意大利语、日语、俄语、西班牙语或瑞典语支持。
1. 通过 MySuunto 联系我们
登录
注册
什么是 MySuunto?
2. 或在下面留言(无需注册)
提交问题
我们将竭尽所能争取在未来几日内回复您。 而如果您需要紧急帮助,欢迎随时来电垂询。
致电我们
全天候提供英语支持。
工作日当地时间上午 9 点到下午 5 点提供支持服务:
如果您所在的国家/地区未在列,将按您运营商的国际费率收取通话费用。为保证服务质量和日后供培训使用,您的通话可能会被监听或录音。
Suunto 国际有限保修
Suunto 保证,在保修期内,Suunto 或 Suunto 授权服务中心(以下简称“服务中心”)有权在本国际有限保修的条款和条件限制范围内,单方面酌情选择下列方式免费补救材料或工艺中的瑕疵:a) 维修,或者 b) 更换,或者 c) 退款。无论产品购买于任何国家/地区,本国际有限保修均有效并具有强制效力。本国际有限保修不影响适用于消费品销售的强制性国家法律所授予您的法律权利。
保修期限
本国际有限保修期限自原始零售购买之日起计算。
除非另有规定,否则产品和潜水传送器的保修期限为两 (2) 年。
配件(包括但不限于:无线传感器、充电器、线缆、可充电电池、腕带、手链和软管)的保修期限为一 (1) 年。
对于所有 2016 年购买的 Suunto Spartan 腕表,保修期延长为三 (3) 年。
例外和限制
本国际有限保修不包括:
  1. a) 正常磨损,例如非金属腕带颜色和/或材料的刮损、磨损或改变,b) 粗暴操作造成的瑕疵,或 c) 因应用于非设计用途或建议用途、保养不当、疏忽以及掉落或挤压等意外而造成的瑕疵或损坏;
  2. 印刷材料和包装;
  3. 将本产品与非 Suunto 制造或提供的任何产品、配件、软件和/或服务一起使用而造成的瑕疵或声称的瑕疵;
  4. 非可充电电池。
Suunto 未保证本产品或配件的工作将是不间断或不会发生错误的,也未保证本产品或配件将能够与第三方提供的任何硬件或软件兼容使用。
当产品或配件存在下列情况时,本国际有限保修不具有强制效力:
  1. 非因预期用途而打开产品或配件;
  2. 使用非授权备件维修产品或配件;由授权服务中心之外的任何人改动或维修产品或配件;
  3. 产品或配件序号已被去除、改动或以任何方式变得无法辨认 — 而且这种情形将由 Suunto 完全自由裁量认定;或
  4. 产品或配件曾暴露在包括但不限于防晒霜和驱蚊剂的化学物质中。
访问 Suunto 保修服务
您必须提供购买凭据才能获得 Suunto 保修服务。您还必须在 www.suunto.com/mysuunto 注册您的产品,以便在全球获取国际保修服务。关于如何获取保修服务的说明,请访问www.suunto.com/warranty联系您当地的授权 Suunto 零售商致电 Suunto 客服中心
责任范围
在适用的强制法律允许的最大范围内,本国际有限保修是向您提供的唯一和专用补救方案,将替代所有其他明示或暗示的保修。对于特殊、偶发、惩罚性或继发性的损失,包括但不限于:由于购买或使用本产品而导致的,或者因违反保修条款、违约、疏忽、严格侵权、违反任何法律或平衡原则而造成的预期利益损失、数据丢失、效用损失、资本成本、任何替代设备或设施的成本、第三方索赔以及财产的损坏,即使 Suunto 已获知发生此类损失的可能性,Suunto 亦不承担任何责任。对于提供所述保修服务过程中出现的迟延,Suunto 不承担任何责任。
Suunto 国际有限保修
Suunto 保证,在下文规定的保修期内,Suunto 或 Suunto 授权服务中心有权在本国际有限保修的条款和条件限制范围内,单方面酌情选择下列方式免费补救材料或工艺中的瑕疵:a) 维修,或者 b) 更换类似产品,或者 c) 退款。本国际有限保修不包括 a) 磨损,b) 粗暴装卸,c) 改装,d) 化学品暴露,或 e) 使用不当造成的缺陷。除非适用的强制性法规另有规定,a) 否则无论产品购买于任何国家/地区,本国际有限保修均有效并具有强制效力,并且 b) 要获取国际有限保修服务,需要在 www.suunto.com/mysuunto 进行注册和提供购买凭据。本国际有限保修不影响适用于消费品销售的强制性法律所授予您的法律权利。
保修期限
国际有限终生保修:
适用于 Suunto A、M、MC、MB 和 Clipper 指南针。
国际保修期限制为至产品因磨损而无法再正常使用的合理时间为止。
国际有限 2 年保修:
适用于 Suunto AIM、Arrow、Orca-Pioneer 和 KB 指南针。
国际有限保修期为自原始零售购买之日起两 (2) 年。
责任范围
在适用的强制法律允许的最大范围内,本国际有限保修是向您提供的唯一和专用补救方案,将替代所有其他明示或暗示的保修。对于任何特殊、意外、惩罚性或间接损失,Suunto 概不负责。对于延迟提供保修服务,Suunto 亦不承担责任。
通过我们的在线服务申请维修您的 Suunto 产品。展开下方的在线服务申请选项卡,了解在您的国家/地区是否提供此服务。
如果您所在的国家/地区不包含在内,或者您的问题涉及指南针或精密仪器,请使用 Suunto 经销商查找工具来寻找距离您最近的服务中心 - 只需选择服务中心和产品类别即可。
下列国家/地区的用户可使用我们的在线服务申请。如果您所在的国家/地区不包含在内,或者您的问题涉及指南针或精密仪器,请使用 Suunto 经销商查找工具来寻找距离您最近的服务中心 - 只需选择服务中心和产品类别即可。
重要提示:
完成维修工作大约需要七个工作日。如果产品已不在保修期内,我们将在开始维修前告知您预估费用。如果您拒绝我们的预估费用,我们会将产品送还给您,并向您收取固定数额的诊断和邮寄费用,具体金额可能因国家/地区而异。
在线服务申请的填写说明如下:
  • 1. 您需要准备好有效的电子邮件地址、产品序列号,同时连接好打印机。
  • 2. 从列表中选择您所在的国家/地区。
  • 3. 填写必填信息。将自动创建一份寄运单据供您打印。将打印好的单据与要寄送给我们的产品放在一起。
  • 4. 收到确认后,按照所提供的号码致电快递公司,快递公司将揽收您的寄件。
  • 5. 不要随产品寄送用户指南、说明书或销售包装。我们无法退回这些物品。
  • 6. 如果所需解决方案不在保修范围内,我们将通过电子邮件向您告知付款详细信息。您可通过 PayPal 安全付款。
  • 7. 产品维修结束后,将寄还至您在填写服务申请时所指定的地址。
澳大利亚
奥地利
比利时
保加利亚
克罗地亚
塞浦路斯
捷克共和国
丹麦
爱沙尼亚
芬兰
法国
德国
希腊
匈牙利
爱尔兰
意大利
拉脱维亚
立陶宛
卢森堡
马来西亚
马耳他
荷兰
新西兰
挪威
波兰
葡萄牙
罗马尼亚
新加坡
斯洛伐克
斯洛文尼亚
西班牙
瑞典
瑞士
英国
美国
Suunto 在不同的国家建立了广泛的授权服务中心网络,以针对您的所有维修和维护需要提供帮助。您可以使用 Suunto 经销商定位器 找到最近的服务中心 – 只需选择服中心和产品类别。
您也可以联系Suunto 客户支持找到为产品提供服务的最佳方式。
