查找经销商/服务中心
Suunto Traverse 用户指南 - 2.0
路线
您可以使用 Suunto Movescount 中的路线计划助手或将记录活动的行踪导出到计划助手中。
若要添加路线:
  1. 前往 Suunto Movescount 并登录。
  2. Plan & Create 下,浏览至 Routes,搜索并添加现有路线,或者浏览至 Route Planner,创建自己的路线。
  3. 保存路线并选择“Use this route in my…”(在我的…中使用此路线)选项。
  4. 使用 Suunto Movescount App 应用程序(请参阅 与移动应用程序同步)或使用 Moveslink 和提供的 USB,同步 Suunto Traverse 与 Suunto Movescount。
路线也可通过 Suunto Movescount 删除。
若要删除路线:
  1. 转至 www.movescount.com 并登录。
  2. Plan & Create 下,浏览至 Route Planner
  3. MY ROUTES 下,单击要删除的路线,然后单击 DELETE
Navigating a route
You can navigate a route you have transferred to your Suunto Traverse from Movescount (see 3.20 Routes) or from a log in your logbook with GPS data. You get a preview of the route based on the route list or logbook selection.
If you are using the compass for the first time, you need to calibrate it (see Calibrating compass). After activating the compass, the watch will begin searching for a GPS signal. After the watch acquires a GPS signal, you can begin to navigate a route.
To navigate a route:
  1. Press START to enter the start menu.
  2. Scroll to NAVIGATION with START and press NEXT.
  3. Scroll to Routes or NAVIGATION and press NEXT to enter .
  4. Scroll to the route you want to navigate with START or LIGHT and press NEXT.
  5. Press NEXT to select Navigate. All navigating is recorded. If you watch has more than one sport mode, you are prompted to select one.
  6. Select Forwards or Backwards to chose the direction you want to navigate (from the first waypoint or the last).
route select direction
  1. Start navigating. The watch informs you when you are approaching the beginning of the route.
route begin
  1. The watch informs you when you have arrived at your destination.
You can also start navigating while recording an activity (see Recording activities).
导航期间
在导航期间,按 VIEW 可滚动浏览以下视图:
  • 显示整条路线的完整行踪视图
  • 路线的放大行踪视图:默认情况下,放大视图采用 100 米(0.1 英里)的比例;如果您距离路线过远,也可以采用更大的比例。
行踪视图
完整的行踪视图将显示以下信息:
  • (1) 箭头指明当前位置,并指向前进方向。
  • (2) 路线的起点和终点
  • (3) 以图标形式显示最近的 POI。
  • (4) 行踪视图的比例
route track view
注释:
在完整的行踪视图中,北方始终朝上。
地图方向
您可在 导航 » 设置 » 地图 » 方向 下的选项菜单中更改地图方向。
  • 前方朝上:前进方朝上显示放大地图。
  • 正北朝上:正北方朝上显示放大地图。
上升模式视图
上升模式视图显示以下信息:
  1. 剩余上升
  2. 实时海拔剖面图
  3. 剩余下降
ascent profile Traverse
如果您偏离路线行踪过远,此模式视图将不会更新。而 偏离路线 的字眼会显示在图形下方。您需要返回行踪以获得准确的上升计算。
