A point of interest, or POI, is a special location, such as camping spot or vista along a trail, you can save and navigate to later. You can create POIs in your watch by saving your current location.
Each POI is defined by:
You can store up to 250 POIs in your watch.
You can navigate to any POI that is in your watch POI list.
When navigating to a POI, your watch uses full power GPS.
To navigate to a POI:
To stop navigating, press the upper button again at any time.
While you are moving, the POI navigation has two views:
POI view with direction indicator and distance to the POI
map view showing your current location relative to the POI and your breadcrumb trail (the track you have traveled)
Press the middle button to switch between views. If you stop moving, the watch cannot determine which direction you are going based on GPS.
While in the POI view, tap on the screen to see additional information in the lower row such as altitude difference between current position and POI and estimated time of arrival (ETA) or en route (ETE).
In the map view, other POIs nearby are shown in gray. Press the upper left button to switch between the overview map and a more detailed view. In the detailed view, you adjust the zoom level by pressing the middle button and then zooming in and out with the upper and lower buttons.
While navigating, press the lower right button to open a list of shortcuts. The shortcuts give you quick access to POI details and actions such as saving your current location or selecting another POI to navigate to, as well as ending navigation.
The following POI types are available in Suunto 5:
![]() | generic point of interest |
![]() | Bedding (animal, for hunting) |
![]() | Begin (start of a route or trail) |
![]() | Big game (animal, for hunting) |
![]() | Bird (animal, for hunting) |
![]() | Building, home |
![]() | Cafe, food, restaurant |
![]() | Camp, camping |
![]() | Car, parking |
![]() | Cave |
![]() | Cliff, hill, mountain, valley |
![]() | Coast, lake, river, water |
![]() | Crossroad |
![]() | Emergency |
![]() | End (end of a route or trail) |
![]() | Fish, fishing spot |
![]() | Forest |
![]() | Geogache |
![]() | Hostel, hotel, lodging |
![]() | Info |
![]() | Meadow |
![]() | Peak |
![]() | Prints (animal tracks, for hunting) |
![]() | Road |
![]() | Rock |
![]() | Rub (animal marking, for hunting) |
![]() | Scrape (animal marking, for hunting) |
![]() | Shot (for hunting) |
![]() | Sight |
![]() | Small game (animal, for hunting) |
![]() | Stand (for hunting) |
![]() | Trail |
![]() | Trail cam (for hunting) |
![]() | Waterfall |
You can add a POI by saving your current location in the watch.
If you are outside with your watch and come across a spot you want to save as a POI, you can add the location directly in your watch.
To add a POI with your watch:
You can remove a POI by deleting the POI from the POI list in the watch.
To delete a POI in your watch:
