Suunto Nautic User Guide
Suunto app
With the Suunto app, you can further enrich your Suunto Nautic experience. Pair your device with the mobile app to sync your dives, get weather and tide info or download maps.
You cannot pair anything if airplane mode is on. Turn off airplane mode before pairing.
To pair your device with Suunto app:
  1. Ensure your device Bluetooth is on. Under the settings menu, go to Connectivity » Discovery and enable it if it is not already.
  2. Download and install Suunto app on your compatible mobile device from the iTunes App Store, Google Play in addition to several popular app stores in China.
  3. Start Suunto app and turn on Bluetooth if it is not on already.
  4. Tap the watch icon in the upper-left of the app screen and then tap “PAIR” to pair your device.
  5. Verify the pairing by typing the code that is displayed on your dive computer in the app.
Some features require an internet connection over Wi-Fi or mobile network. Carrier data connection fees may apply.
Dive logs in Suunto app
In the Suunto app, you can add and edit additional details for each dive of your dive log.
You can edit the following fields:
  • Dive weights
  • Dive suit
  • Dive buddy
  • Dive center
  • Visibility
  • Current
  • Environmental features
  • Marine encounters
  • Comfort
  • Buoyancy
  • State of mind
The Weights field allows you to record the amount of weight used during the dive. Other fields let you select one or more options from predefined lists. Some fields also allow you to add your own custom values or remove existing ones.
The list of selectable values is shared across all dive logs. If you delete a value from one dive log, it will also be removed from all other dive logs.
