Size
Satisfied or your money back
Follow context-based weather insights and warnings during your outdoor activity. Keep alert with storm alarms, measure water temperature or notice if your hike is going past the sunset. Feature available under SuuntoPlus™.
*Available only for Suunto 9 Baro
Keep track of your effort while hiking up a mountain, rock climbing, doing hill repeats in your backyard or running up stairs. Feature available under SuuntoPlus™. Climbs can be viewed afterwards in the Suunto app.
Automatic location-based lap insights help you analyze the stats for each loop. Excellent feature when running on a track or cross-country skiing the same loop. Feature available under SuuntoPlus™. Loops can be viewed afterwards in the Suunto app.
Quick access to your GPS coordinates and other key information of your current location as well as your starting point. Useful when sharing your location with a friend, when you need to radio for help or navigating back to your car. Feature available under SuuntoPlus™.
Navigate on the go. Choose your target direction, get the bearing and off you go! You can also define your target distance and altitude. Great orienteering tool for mountains and forests.
Running pace / Cycling power
Track sprints automatically while running or cycling to see the number, distance, and time of each interval during your training session. Sprints are identified based on the changes of your running pace or cycling power. Feature available under SuuntoPlus™. Sprints can be viewed afterwards in the Suunto app.
See key insights of your surroundings while getting ready for your adventures. The design is inspired by Suunto’s heritage with marine compasses.
Getting ready for the race? The Wings for Life World Run feature simulates the Catcher Car to motivate your daily workouts and help you train for the race. Feature available under SuuntoPlus™.
When heading to a new place or route, it’s often hard to figure out where to start. Check out popular starting points in the Suunto app to easily know where to start your adventure from.
Getting bored of running the same trails but not sure where to go? We made finding new routes easy for you by adding popular routes to the Suunto app. These routes are generated from the exercises of the Suunto community.
See your own personal heatmap with a daily, monthly, and current year view. You can also compare your tracks with the most popular routes for your sport.
Improved Suunto app home page will give you direct access to your calendar, activity totals and map.
Find your next trip from Sportihome, check the best routes with Wikiloc or view your tracks with Land. Suunto partners give you tools for your next trail run or mountain trip. Learn more from suunto.com/partners.
Suunto equips you for your outdoor adventures – discover new trails, stay confident in the wilderness and train for longer explorations.
Update the Suunto 9 software to the latest version to receive these new features and functionalities.
When you have your mind set on a certain goal or adventure, you want to make sure your watch can also go the distance. With up to 120 hours of continuous exercise tracking Suunto 9 is built to last – just like you!
See the whole story
The Suunto 9 with a barometer gives you more accurate altitude information because it combines GPS data with barometric altitude information (FusedAlti™). Based on data from the barometer, it also provides outdoor information like sea level air pressure and has a storm alarm. The other Suunto 9 models still deliver altitude information, but they are based on GPS readings.
Measurements | {{ productDimensionsInGrams }} mm / {{ productDimensionsInInches }} " |
Weight | {{ selectedProductSpecifications.ProductWeightGrams }} g / {{ selectedProductSpecifications.ProductWeightOunces }} oz |
Bezel material: | {{ selectedProductSpecifications.BezelMaterial }} |
Glass material: | {{ selectedProductSpecifications.LensMaterial }} |
Case material: | {{ selectedProductSpecifications.CaseMaterial }} |
Strap material: | {{ selectedProductSpecifications.StrapMaterial }} |
What's in the box? |
Learn more about using our digital services as a Suunto Spartan or Suunto 9 user.
How do I use maps and routes with the Suunto app?
SuuntoPlus™ - a solution that brings new features to your Suunto watch and enhances your experience.
Learn how to use battery modes and prolong battery life during long trainings.
This video shows you step-by-step how to set your personal pace and power zones in the settings menu.
This video shows you step-by-step:
How to activate a power target for exercise.
How to use the real-time guidance within your target during exercise.
How to activate a pace target for exercise.
Learn how to install the latest software on your watch using SuuntoLink. Download SuuntoLink
Learn how to pair your Suunto watch with the Suunto app for iOS and how to get started with the app.
Learn how to pair your Suunto watch with the Suunto app for Android and how to get started with the app.
Clean your Suunto watch regularly with lukewarm water and mild soap.
{{ row }}
*Your actual battery life may vary depending on usage and conditions. If you enable the Ultra battery mode it will increase battery life, but deactivate wrist heart rate tracking. In Endurance battery mode, battery life is 40 hours with wrist heart rate and 50 hours with HR belt. Touch is disabled during exercise, but you can activate it in your custom mode.
See accuracy of our data monitoring and accuracy of wrist-based heart rate.
Learn more about the best practices for measuring heart rate from wrist.
{{ comment.Title }}
{{ comment.SubmissionTime | dateToUTCString }}
{{ row }}
{{ row.Date | dateToUTCString }}
{{ response }}{{ row.Name }}
