Suunto EON Steel - Features - Movescount mobile app
Find a dealer/service center
Suunto EON Steel User Guide - 1.6
With the Suunto Movescount App, you can easily transfer your dive logs to Movescount where you can follow and share your diving adventures.
To pair with Suunto Movescount App on iOS:
  1. Download and install Suunto Movescount App on your compatible Apple device from the iTunes App Store. The app description includes the latest compatibility information.
  2. Start Suunto Movescount App and turn on Bluetooth if it is not on already. Leave the app running in the foreground.
  3. If you have not yet set up your Suunto EON Steel, do so now (see Getting started).
  4. Tap the settings icon in the upper right and tap on the ' + ' icon to add a new device.
  5. Tap on your dive computer from the list of found devices and enter the passkey shown on the Suunto EON Steel display.
To pair with Suunto Movescount App on Android:
  1. Download and install Suunto Movescount App on your compatible Android device from Google Play. The app description includes the latest compatibility information.
  4. A pop-up screen opens on your Android device. Select Pair.
  5. Enter the passkey shown on your dive computer display into the paring request field on your mobile device and tap OK.
Syncing with mobile app
If you have paired your Suunto EON Steel with Suunto Movescount App, new logs are automatically synced when the Bluetooth connection is active. The Bluetooth icon on your Suunto EON Steel flashes when data is being synced.
If your mobile device has an active data connection and your app is connected to your Movescount account, logs are synced with your account. If there is no data connection, syncing is delayed until a connection is available.
Unsynced logs recorded with your Suunto EON Steel are listed in the app, but you cannot view the move details until they are synced with your Movescount account.
If you want to pair your Suunto EON Steel with a different mobile device, unpair the current device from the settings menu under General / Connectivity / Unpair.
Carrier data connection fees may apply when syncing between Suunto Movescount App and your Movescount account.
