Suunto EON Steel - Features - Calendar clock
Suunto EON Steel User Guide - 1.6
Calendar clock
Calendar clock
Time and date settings are found under General / Device settings / Time & date.
Time and date formats are found under General / Device settings / Units and formats.
To change time and date
  1. Keep the middle button pressed to enter menu.
  2. Browse to General / Device settings / Time & date.
  3. Scroll to Set time or Set date with the upper or lower button.
  4. Press the middle button to enter the setting.
  5. Adjust the setting with the upper or lower button.
  6. Press the middle button to move to the next setting.
  7. Press again the middle button when last value is set to save and go back to Time & date menu.
  8. Keep middle button pressed to exit when done.
To change time and date formats
  2. Browse to General / Device settings / Units and formats.
  3. Scroll to Time format or Date format with the upper or lower button.
  4. Follow steps 5-8 as above to change and save formats.
