Suunto Wing 2 User Guide
Buttons
Suunto Wing 2 has three buttons you can use to switch song, adjust volume and answer or end phone calls.
buttons
  1. multifunction button
  2. + and power button
  3. – button
Switching on/off the device
  • keep the + button pressed for 3 seconds to switch the device on or off
Listening to audio
  • press the multifunction button once to start or stop playing the audio
  • press the multifunction button twice to skip to the next track
  • press the multifunction button three times to return to the previous track
  • press the + button to increase volume
  • press the – button to decrease volume
  • keep the multifunction button and the + button pressed simultaneously for 3 seconds to switch sound mode
Making a phone call
  • press the multifunction button once to answer or end a call
Adjusting settings when the device is on
  • keep the – button pressed for 3 seconds to switch the LED lights on
  • keep the – button pressed again for 3 seconds to switch between 5 light modes
  • keep the multifunction button and the – button pressed simultaneously for 3 seconds to enable Head Movement Control
  • in pairing mode, keep the multifunction button and the + button pressed simultaneously for 3 seconds to enable dual device connection
