Interval workouts are a common form of training consisting of repetitive sets of high and low intensity efforts. With Suunto 3/Suunto 3 Fitness, you can define your own interval training for each sport mode.
When defining your intervals, you have four items to set:
Keep in mind that if you use distance to define your intervals, you need to be in a sport mode that measures distance. The measurement can be based on mobile assisted GPS, wrist based speed or from a foot or bike POD, for example.
To train with intervals:
Toggle intervals on and adjust the settings described above.
Scroll up to Back and confirm with the middle button.
Press the lower left button to change the view to intervals display and press the upper right button when you are ready to start your interval training.
If you want to stop the interval training before you have completed all your repetitions, keep the middle button pressed to open the sport mode options and toggle off Intervals.
While you are in the intervals display, buttons work as normal, for example, pressing the upper right button pauses the exercise recording, not just the interval training.
After you have stopped your exercise recording, interval training is automatically toggled off for that sport mode. The other settings, however, are maintained so you can easily start the same workout the next time you use the sport mode.
