Changing time settings
To access the time settings:
- Keep pressed to enter the options menu.
- Press to enter general.
- Scroll to Time/date using and enter with .
Setting time
The current time is shown in the middle row of the Time mode display.
To set the time:
- In the options menu, go to general, then to Time/date and Time.
- Change the hour and minute values with and . Accept with .
- Go back to the settings with , or keep pressed to exit the options menu.
Setting date
The current date is shown on the top row of the Time mode display.
To set the date:
- In the options menu, go to general, then to Time/date and Date.
- Change the year, month and day values with and . Accept with .
Setting dual time
Dual time allows you to keep track of the current time in a second time zone, for example, when travelling. Dual time is displayed on the bottom row of the Time mode display and you can access it by pressing .
To set the dual time:
- In the options menu, go to general, then to Time/date and Dual time.
Setting alarm
You can use your Suunto Ambit2 S as an alarm clock.
To access the alarm clock and set the alarm:
- In the options menu, go to General, then to Time/date and Alarm.
- Set the alarm on or off with or . Accept with .
- Set the hours and minutes with and . Accept with .
When the alarm is switched on, the alarm symbol is shown on most of the displays.
When the alarm sounds, you can:
- Select Snooze by pressing . The alarm stops and restarts every 5 minutes until you stop it. You can snooze up to 12 times for a total of 1 hour.
- Select Stop by pressing . The alarm stops and restarts the same time the following day, unless you switch the alarm off in the settings.
When snoozing, the alarm icon blinks in TIME mode.
